Intel® MPI Library
2285 Discussions
Intel MPI 2021 update8 support DSA, how to enable DSA and what's the performance improvement w/ DSA?
Dennis
I am investigating the DSA usage scenarios and I see MPI support the DSA but I can't find any information to introduce how to enable DSA and what's the performance improvement w/ DSA.
Really appreciate for any help.
Thanks a lot and best regareds,
Dennis Wu
Intel® MPI Library 2021 Update 8
  • Intel® MPI library provides initial support for the Intel® Data Center GPU MAX Series (formerly code-named Ponte Vecchio) utilizing XE Link for direct GPU to GPU communications
  • Intel® MPI Library speeds cluster application performance by utilizing the new embedded Data Streaming Accelerator in 4th Generation Xeon Scalable Processors (formerly code-named Sapphire Rapids).
  • Intel® MPI Library 2021.8 has implemented performance optimizations for Intel GPUs and Intel® Xeon® CPU Max Series.
  • Bug fixes.
SantoshY_Intel
Thanks for posting in the Intel communities.
Could you please go through the below articles & get back to us if you still have any queries?
URL for Intel DSA Architecture specification: https://www.intel.com/content/www/us/en/develop/articles/intel-data-streaming-accelerator-architecture-specification.html
URL for Intel DSA user guide: https://cdrdv2-public.intel.com/759709/353216-data-streaming-accelerator-user-guide-2.pdf
Thanks & Regards,
Santosh
Dennis
I have enabled the DSA and got the raw performance with https://github.com/intel/dsa-perf-micros . As the release note, the IntelMPI support the DSA, I would like to make the IntelMPI work with DSA and without DSA, then I would like to know how the DSA improvement the performance of IntelMPI.
If you already have some document for the environment setup, performance data w DSA vs W/o DSA, please share me.
Thank you
SantoshY_Intel
Thank you for your feedback. We have provided your feedback to the relevant team. At this moment there is no visibility of when it will be implemented and available for use. Please let me know if we can go ahead and close this case.
Thanks & Regards,
Santosh
