Intel® MPI Library
2301 Discussions
Intel MPI Benchmark woes on Itanium2
mkbane
Firstly apologies if there's a thread already on this (I couldn't find anything with the limited search facilities available)
The crux: I've downloaded the Intel MPI Benchmarks (IMB) and compiled on Itanium-2 chips using mpich2/icc. However I have had several problems, see below, so was hoping to share experiences with others - let me know what you've found!
The problems so far:
1) MPI-IO benchmark suite hangs just after:
Benchmarking C_IRead_Indv
# #processes = 2
# MODE: AGGREGATE
2) -time N option either doesn't seem to have an effect (no more iterations allowed even if N is increased) or gives nonsense (eg if set N very large then o/p claims it's doing very large negative iterations or gives a sensible number of iterations but completes them in '-0.00' seconds). Whilst this is reproducable, for a given N, it doesn't happen on every instance which is perhaps more worrying.
thanks, Michael
