Intel® MPI Library
2296 Discussions
Intel MPI Hydra Hetero Operating System Cluster
jcappelletti
I have a hetero operating system cluster
I have some nodes running Windows and others running Linux
I saw there is a Local Option '-hostos' in the Hydra process manager
to specify the operating system of each individual host
but it was removed in an update release in 2019 (I think update #5, see attachment)
was there any replacement for this?
This link shows the -hostos option
http://cali2.unilim.fr/intel-mpi/doc/Reference_Manual/Hetero_OS_Cluster_Support.htm
This link shows how its used (at the bottom of the page)
https://lost-contact.mit.edu/afs/pdc.kth.se/roots/ilse/v0.7/pdc/vol/i-compilers/2015/impi/5.0.1.035/doc/Reference_Manual/Local_Options.htm
This link, on page 2 as numbered in the document, shows the option was removed
https://www.intel.com/content/dam/develop/external/us/en/documents/intelmpi-2019u5-developer-reference-windows.pdf
Is there any equivalent replacement for the -hostos option?
Is there any simple way to run an MPI job on a cluster with different operating systems?
Is there a place I can download specific older versions of the Intel MPI library?
Thank you very much!
ShivaniK_Intel
To access older releases you need a version that includes Intel Priority Support, the free versions do not include this.
Here is a link to the online store where you can get a commercially supported version https://softwarestore.intel.com/
We are working on your other queries and will get back to you soon.
Thanks & Regards
Shivani
ShivaniK_Intel
Thank you for your patience.
Officially, hetero operating system support is no longer available.
It might be possible that the following command works. So, could you please try using the below command?
mpiexec.hydra –bootstrap ssh -genv FI_PROVIDER tcp -env I_MPI_ROOT <windows_installdir> -env PATH <windows_installdir>\<arch>\bin -host <win_host> -n 2 <windows_installdir>\<arch>\bin\IMB-MPI1 : -host <lin_host> -n 3 <linux_installdir>/<arch>/bin/IMB-MPI1
Another workaround may be to use MPI_Comm_connect/MPI_Comm_accept. However, no more documentation is available in this context.
Thanks & Regards
Shivani
jcappelletti
If it was officially supported before, there has to be a way!
I will try it and will report back here how it goes!
ShivaniK_Intel
>>"I will try it and will report back here how it goes!"
Could you please let us know whether it worked for you?
Thanks & Regards
Shivani
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We haven't heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
