Intel® MPI Library
Intel MPI utilize multiple NICs
zhang__eric
I meet some problems to use two NICs with Intel MPI (2018.3.222). I have two mellnox IB FDR NICs. So I try to bind process to different NICs with the following script
 [ $MPI_LOCALRANKID -eq 0 ]; then
    IB_NUMBER=0
else
    IB_NUMBER=1
fi
# export I_MPI_FABRICS=shm:ofa I_MPI_OFA_NUM_ADAPTERS=1 I_MPI_OFA_ADAPTER_NAME=mlx4_${IB_NUMBER}
export FI_VERBS_IFACE=mlx4_${IB_NUMBER}
export I_MPI_HYDRA_IFACE=mlx4_${IB_NUMBER}
echo $IB_NUMBER
./IMB-MPI1 -include Sendrecv Allreduce
MPI startup(): shm:ofa fabric is unknown or has been removed from the product, please use ofi or shm:ofi instead                [0] MPI startup(): libfabric version: 1.8.0a1-impi
[0] MPI startup(): libfabric provider: sockets
[0] MPI startup(): Rank    Pid      Node name  Pin cpu        [0] MPI startup(): 0       51688    i1         {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,52,53,54,55,                                              56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77}        [0] MPI startup(): 1       51689    i1         {26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,78                                    ,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103}                                         [0] MPI startup(): 2       27108    i2         {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,52,53,54,55,                                            56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77}        [0] MPI startup(): 3       27109    i2         {26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,78
[0] MPI startup(): 4       53516    i3         {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,52,53,54,55,
[0] MPI startup(): 5       53517    i3         {26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,78
[0] MPI startup(): 6       44894    i4         {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,52,53,54,55,
[0] MPI startup(): 7       44895    i4         {26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,78
[0] MPI startup(): I_MPI_ROOT=/opt/spack/spack-avx512/opt/spack/linux-debian9-x86_64/gcc-8.2.0/intel-mpi-2019.3.199-ooicvtdn7kvu2yr7dzoggbn4tizn5eri/compilers_and_libraries_2019.3.199/linux/mpi
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_HYDRA_IFACE=mlx4_0
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_FABRICS=shm:ofa
[0] MPI startup(): I_MPI_DEBUG=5
[0] MPI startup(): I_MPI_OFA_NUM_ADAPTERS variable has been removed from the product, its value is ignored
[0] MPI startup(): I_MPI_OFA_ADAPTER_NAME variable has been removed from the product, its value is ignored
[0] MPI startup(): I_MPI_OFA_NUM_ADAPTERS environment variable is not supported.
[0] MPI startup(): I_MPI_OFA_ADAPTER_NAME environment variable is not supported.
[0] MPI startup(): Similar variables:
         I_MPI_ADJUST_SCATTER_NODE
[0] MPI startup(): To check the list of supported variables, use the impi_info utility or refer to https://software.intel.com/en-us/mpi-library/documentation/get-started.
#    Intel(R) MPI Benchmarks 2019 Update 3, MPI-1 part
# Date                  : Sun Jun 16 14:52:23 2019
# Machine               : x86_64
# System                : Linux
# Release               : 4.9.0-7-amd64
# Version               : #1 SMP Debian 4.9.110-1 (2018-07-05)
# MPI Version           : 3.1
# MPI Thread Environment:
Results are same as single FDR and far away from 56Gb*2 IB bandwidth.
#-----------------------------------------------------------------------------        [124/1982]
# Benchmarking Sendrecv
# #processes = 2
# ( 6 additional processes waiting in MPI_Barrier)
       #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]   Mbytes/sec
        65536          640        14.86        14.86        14.86      8822.22
       131072          320        27.31        27.32        27.31      9596.69
       262144          160        57.10        57.13        57.12      9177.00
       524288           80       145.31       145.60       145.45      7201.97
      1048576           40       299.75       301.67       300.71      6951.85
      2097152           20       577.48       586.55       582.01      7150.82
      4194304           10      1373.00      1388.52      1380.76      6041.42
# #processes = 4
# ( 4 additional processes waiting in MPI_Barrier)
        65536          640        62.04        62.13        62.08      2109.51
       131072          320        95.83        95.97        95.91      2731.60
       262144          160       183.33       184.00       183.74      2849.39
       524288           80       356.31       359.86       358.58      2913.82
      1048576           40     11500.00     11517.56     11510.18       182.08
I wonder how should I bind process to different NICs. And is there better way to make full use of two NICs, such as one process utilize two NICs simultaneously?
Yury_K_Intel
Hello Eric,
Could you make another run with
export I_MPI_DEBUG=6
export FI_LOG_LEVEL=debug
and provide output to here?
Also please remove OFA related environment variables, OFA is not supported starting Intel MPI Library 2019.
BTW, you report issue against Intel MPI 2018.3.222, but I_MPI_ROOT points to 2019.3.199. Please check your environment that it doesn't overlapped from different Intel MPI versions.
Thank you.
Best regards, Yury.
zhang__eric
Hello Kiryanov,
Thanks for your quick reply. I am going to take a double check later.
And could you please introduce how to properly utilize two NICs in IMPI 2019?
Alexandre_Chauvin
I am facing a similiar problem. Is there any cookbook to enable the use of multiple adapters with Intel MPI 2019 ? (intel-mpi-rt-2019.7-217-2019.7-217.x86_64)
Kind regards
