Intel® MPI Library
Intel MPI with pthread
jackyjngwn
I am trying to run a program that uses Pthread with Intel MPI. The program was compiled and linked successfully. I ran it on a dual-socket machine with two quad-core processors, but no threads seemed to be created. Below is the command I used:
mpirun -n 2 exectable
The program is supposed to generate 8 threads in one of the 2 processes. Thanks.
TimP
Quoting - jackyjngwn
Intel MPI is said to be more particular than certain other MPI implementations in requiring MPI_Init_thread to be used correctly for this case. The I_MPI_PIN_DOMAIN environment variable settings are provided (since MPI 3.2) to give some control over thread affinity.
Other than that, I doubt much can be said with the information you gave.
Gergana_S_Intel
Hi, Jacky
One other thing I would point out: when doing hybrid programming (threads + MPI), make sure you're using the thread-safe Intel MPI library. You can specify this for your Intel MPI Library compiler script (such as mpiicc, or mpiifort) by using the -mt_mpi flag. Or you can manually link with libmpi_mt.so in the lib/lib64 directory.
~Gergana
jackyjngwn
Quoting - tim18
Thanks for the reply. Do you mean that I have to use "MPI_Init_thread" in my program instead of MPI_init, or I can specifiy the thread levels using the -mt_mpl option?
Also, according to the reference manual, I_MPI_PIN_DOMAIN is for OpenMP only, isn't it?
TimP
According to my understanding, MPI_Init_thread is required, and the -mt_mpi would be needed for some of the supported threading models (perhaps not yours, except that it would be important anyway if you don't segregate threads from each other).
I_MPI_PIN_DOMAIN evidently has options to correspond with OpenMP, and may use the KMP_AFFINITY mechanism in that case to place the threads. I'm trying to refresh my installation so as to look at the current documentation on I_MPI_PIN_DOMAIN. If you care about placement of threads, you would want some mechanism such as this or taskset.
TimP
Quoting - tim18
It appears that I_MPI_PIN_DOMAIN doesn't depend on OpenMP, but you may have to figure out the option if you are trying to reserve more than half the cores to 1 process.
jackyjngwn
I've linked to mpi_mt using -lmpi_mt, and changed MPI_INIT to MPI_INIT_thread, but it seems that these tricks didn't work.
My program is this. There are two processes, one is the master, one is the slave. The slave generates 8 threads. The master process reads the input data and dispatches to thethreads of the slaves. The 8 threads are supposed to use the 8 cores of the two quad-core processors. However, from the output of "top", only two cores were used, one by the master process, and one by the slave process.
I tried to use I_MPI_PIN_DOMAIN, too. When "sock" was specified, two cores were used by the slave process. But nothing changed when other arguments were used. What does this mean? thanks!
Dmitry_K_Intel2
Hi Jacky,
Could you try to set I_MPI_PIN_DOMAIN to 'auto'. It it doesn't change the situation try to set I_MPI_PIN to 'off'.
Best wihes,
Dmitry
jackyjngwn
I've finally got it working, after I set I_MPI_PIN_MODE to node. Thank you allforthe help!
