Intel® MPI Library
Intel MPI
wanghw
Hi, I want use I-MPI to use my own implemented services through UCX. Now there are several questions: 1) Instead of using MLX services, I can execute my services through UCX, If I could, what should I do?; 2) Where can I get the I-MPI source code?Thanks.
ShivaniK_Intel
Thanks for posting in the Intel forums.
Could you please elaborate on what you are actually trying to achieve which would help us to understand clearly?
 Thanks & Regards
 Shivani
ShivaniK_Intel
As we did not hear back from you could you please respond to my previous post?
Thanks & Regards
Shivani
wanghw
I apologize for not responding to your message in a timely manner.
My purpose is to use my own implemented UCX service via I-MPI.
Now I did this by modifying the libfabric library to adapt.
 Thanks & Regards
ShivaniK_Intel
>>>"Instead of using MLX services, I can execute my services through UCX, If I could, what should I do"
From your previous response "Now I did this by modifying the libfabric library to adapt" we understand that you are able to execute your services
through UCX.If yes, could you please let us know whether we can close this issue?
>>>"Where can I get the I-MPI source code"
Sorry for the inconvenience Intel MPI is a closed source, the source code is not available.
Thanks & Regards
Shivani
ShivaniK_Intel
Since we didn't hear back from you, we assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
