Intel® MPI Library
2302 Discussions
Intel Micro Benchmark Result Problem with PCI-passthrough via FDR infiniband
phonlawat_k_
Hi everyone, I still evaluate cluster performance. For now, i move on virtualization with PCI-passthrough via FDR infiniband on KVM hypervisor.
My problem is Sendrecv throughput that decrease by half when compare with physical machine and i use 1 rank/node. For example
Node           Bare-metal (MB/s)               PCI-passthrough (MB/s)
    2                14,600                                        13,000
   4                 14,500                                        12,000
  16                14,300                                        11,000
  32                14,290                                        10,000
  64                14,200                                         7,100
What do you think about this behavior ? Is it about mellanox software or other things or overhead ?
Thank you
Cartridge Carl
James_T_Intel
I'll check with our developers and see if they have any ideas.
James_T_Intel
What fabric are you using?  Can you attach output with I_MPI_DEBUG=5?
phonlawat_k_
I use openmpi so this is one reason for this problem which i cannot attatch output with I_MPI_DEBUG=5. Anyway i use Mellanox ConnectX-3 FDR Infiniband HCA (56 Gbps)
