Intel® MPI Library
2301 Discussions
Intel oneAPI 2022.3 MPI triggers Windows Firewall
Frank_R_1
Used system and software
Windows 10 Enterprise
Intel oneAPI 2022.3
When we start with
mpiexec -np 1 -delegate -localroot -localonly test_mpi.exe
the Windows firewall gets triggered. Why is this the case (127.0.01 listens to 0.0.0.0)?
Even if we run test_mpi.exe with out mpiexec.exe we trigger the firewall!
In Intel MPI 2018.3 only mpiexec.exe and pmi_proxy triggered firewall but not the executable!
Why is this now the case?
Best regards
Frank
ShivaniK_Intel
Thanks for posting in the Intel forums.
>>>"the Windows firewall gets triggered"
Could you please let us know how could you confirm that the firewall gets triggered?
Could you please provide the sample reproducer code to reproduce the issue at our end?
Thanks & Regards
Shivani
Frank_R_1
Steps to reproduce:
1) login to a Windows 10/11 professional/enterprise machine, restore all Windows firewall settings as administrator (this resets all in-bound and out-bound rules).
2) start an arbitrary  mpi executable (built with Intel MPI 2021.7) with mpiexec.exe -np #numcpu -delegate -localroot -localonly program
Then the Windows firewall dialog appears where you can choose "allow" or "cancel".
This happens for mpiexec.exe, hydra_pmi_proxy.exe, AND the executable (that the firewall also complains about the executable is different from old Intel MPI 2018.3 library where this does not happen).
Best regards
Frank
ShivaniK_Intel
We are working on it and will get back to you.
Thanks & Regards
Shivani
ShivaniK_Intel
If only local execution is needed:
mpirun -genv I_MPI_FABRICS=shm -delegate -localroot -localonly test_mpi.exe
Should only trigger the firewall for PMI proxy for Hydra Process manager and mpiexec but not for test_mpi.exe, also note that although
the firewall will be triggered it is ok to block access, the application will just run.
set I_MPI_FABRICS=shm
test_mpi.exe
will not trigger the firewall at all.
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you, could you please let us know whether your issue is resolved or not?
Thanks & Regards
Shivani
ShivaniK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance please post a new question.
Thanks & Regards
Shivani
