Intel® MPI Library
2285 Discussions
Inter ifort.exe could not link impimt.lib
dingjun_chencmgl_ca
Hi, James,
I am trying to use a makefile to generate a hybrid MPI/OpenMP application imex.exe. But I failed to do it and please see the following linking results:
U:\\imex\\bin\\opt64_hybridMPIOpenMP>clearmake -k -V imex.exe
        insert_string.exe -d -v  -c  -f \\imex\\imex.lib\\simver.f > simver.f
        ifort.exe /Qauto /cm /nologo /w /MT  /Qfpp  /DIFL_IA32 /DWIN_X64 /Qopenmp -c simver.f
        dir imex.exe > imex.exe &&  del /f imex.exe &&  ifort.exe /Qauto /cm /nologo /w /MT  /Qopenmp /4Yportlib *.obj mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib Wsock32.lib User32.lib shell
32.lib Advapi32.lib Gdi32.lib    libsecure.lib rlmclient.lib  binarrayfile.lib   /link /LARGEADDRESSAWARE /incremental:no /STACK:4000000 /out:imex.exe &&  mt.exe -manifest ReqExecLevelInvoker.manifest
 -outputresource:imex.exe;1 &&  echo 'Done.'
   Creating library imex.lib and object imex.exp
imex.obj : error LNK2019: unresolved external symbol MPI_INIT_THREAD referenced in function TMLOOP
imex.obj : error LNK2019: unresolved external symbol MPI_COMM_RANK referenced in function TMLOOP
imex.obj : error LNK2019: unresolved external symbol MPI_COMM_SIZE referenced in function TMLOOP
imex.obj : error LNK2019: unresolved external symbol MPI_FINALIZE referenced in function TMLOOP
imex.exe : fatal error LNK1120: 4 unresolved externals
*** Error code 1120
clearmake: Error: Build script failed for "imex.exe"
by the way, please see the envoirment variable settings attached below.  I guess I have set  intel MPI include and library ready.
Could you tell me how this happened? Thanks indeed in advance.
Dingjun
/********** Envorimental variable settings on my computer ***********/
ALLUSERSPROFILE=C:\\ProgramData
APPDATA=C:\\Users\\dingjun\\AppData\\Roaming
ARCH_PATH=intel64
ARCH_PATH_MPI=em64t
BIN_ROOT=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\bin\\
BUNDLE_NAME=Intel® Parallel Studio XE 2011 Update 1
CCASE_IP_VERSION=4
CCP_HOME=C:\\Program Files\\Microsoft Compute Cluster Pack\\
CMG_HOME=C:\\Program Files (x86)\\CMG
CMG_LIC_HOST=rlmserv
CommandPromptType=Native
CommonProgramFiles=C:\\Program Files\\Common Files
CommonProgramFiles(x86)=C:\\Program Files (x86)\\Common Files
CommonProgramW6432=C:\\Program Files\\Common Files
COMPUTERNAME=DINGJUNC
ComSpec=C:\\Windows\\system32\\cmd.exe
CPRO_PATH=C:\\Program Files (x86)\\Intel\\ComposerXE-2011
CPU=i386
C_EM64T_REDIST12=C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\
C_IA32_REDIST12=C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\
C_TARGET_ARCH=intel64
DEFLOGDIR=C:\\ProgramData\\McAfee\\DesktopProtection
envsdk_regkey=9.0
FP_NO_HOST_CHECK=NO
Framework35Version=v3.5
FrameworkDir=C:\\Windows\\Microsoft.NET\\Framework64
FrameworkDIR64=C:\\Windows\\Microsoft.NET\\Framework64
FrameworkVersion=v4.0.30319
FrameworkVersion64=v4.0.30319
FSHARPINSTALLDIR=C:\\Program Files (x86)\\Microsoft F#\\v4.0\\
F_EM64T_REDIST12=C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\
F_IA32_REDIST12=C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\
HOMEDRIVE=C:
HOMEPATH=\\Users\\dingjun
ICPP_COMPILER12=C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\
IFORT_COMPILER12=C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\
IMPI_BIN=C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\\\em64t\\bin;
INCLUDE=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\compiler\\include;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\compiler\\include\\intel64;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\INCLUDE;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\ATLMFC\\INCLUDE;C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\include;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\ipp\\include;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\mkl\\include;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\tbb\\bin\\..\\include;C:\\Program Files\\Microsoft Visual Studio\\DF98\\IMSL\\INCLUDE;C:\\Program Files\\Microsoft Visual Studio\\DF98\\INCLUDE;C:\\Program Files\\Microsoft Visual Studio\\VC98\\INCLUDE;C:\\Program Files (x86)\\Microsoft Visual Studio 9.0\\VC\\include;C:\\Program Files (x86)\\Microsoft Visual Studio 9.0\\VC\\atlmfc\\include;C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\em64t\\include;C:\\Program Files\\MPICH2\\include
INSPECTOR_XE_2011_DIR=C:\\Program Files (x86)\\Intel\\Inspector XE 2011\\
INTEL_LICENSE_FILE=C:\\Program Files (x86)\\Common Files\\Intel\\Licenses
IPPROOT=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\ipp
IPP_TARGET_ARCH=intel64
I_MPI_ROOT=C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\
KMP_AFFINITY=compact,1
LIB=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\compiler\\lib;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\compiler\\lib\\intel64;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\LIB\\amd64;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\ATLMFC\\LIB\\amd64;C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\lib\\x64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\ipp\\lib\\intel64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\ipp\\..\\compiler\\lib\\intel64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\mkl\\lib\\intel64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\compiler\\lib\\intel64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\tbb\\bin\\..\\lib\\intel64\\vc10;C:\\Program Files\\Microsoft Visual Studio\\DF98\\IMSL\\LIB;C:\\Program Files\\Microsoft Visual Studio\\DF98\\LIB;C:\\Program Files\\Microsoft Visual Studio\\VC98\\LIB;C:\\Program Files (x86)\\Microsoft Visual Studio 9.0\\VC\\lib\\amd64;C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\em64t\\lib;C:\\Program Files\\MPICH2\\lib
LIBMPI=C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\em64t\\lib
LIBPATH=C:\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319;C:\\Windows\\Microsoft.NET\\Framework64\\v3.5;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\LIB\\amd64;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\ATLMFC\\LIB\\amd64;
LINK_F90=imsl.lib imsls_err.lib imslmpistub.lib impimt.lib
LOCALAPPDATA=C:\\Users\\dingjun\\AppData\\Local
LOGONSERVER=\\\\NTSVR1
MKLROOT=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\mkl
MKL_LP64_ILP64=lp64
MKL_TARGET_ARCH=intel64
MOD_NAME=mod
MPICHHOME=C:\\Program Files\\MPICH2
MSVS_VAR_SCRIPT="C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\Common7\\Tools\\..\\..\\VC\\vcvarsall.bat"
NUMBER_OF_PROCESSORS=12
OMP_SCHEDULE=static,1
OS=Windows_NT
Path=C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\\\em64t\\bin;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\bin\\intel64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\compiler;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\BIN\\amd64;C:\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319;C:\\Windows\\Microsoft.NET\\Framework64\\v3.5;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\VCPackages;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\Common7\\IDE;C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\Common7\\Tools;C:\\Program Files (x86)\\HTML Help Workshop;C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\bin\\NETFX 4.0 Tools\\x64;C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\bin\\x64;C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\bin;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\ipp\\..\\redist\\intel64\\ipp;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\ipp\\..\\redist\\intel64\\compiler;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\mkl;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\compiler;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\tbb\\bin\\..\\..\\redist\\intel64\\tbb\\vc10;C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\em64t\\bin;C:\\Program Files (x86)\\Intel\\MPI\\4.0.3.009\\ia32\\bin;C:\\Program Files (x86)\\CMG\\LAUNCHER\\2011.20\\Win32\\exe;C:\\Program Files\\MPICH2\\bin;C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\redist\\ia32\\tbb\\vc10;C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\redist\\intel64\\tbb\\vc10;C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\redist\\intel64\\ipp;C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\redist\\ia32\\ipp;C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\redist\\intel64\\mkl;C:\\Program Files (x86)\\Intel\\Composer XE 2011 SP1\\redist\\ia32\\mkl;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\mpirt;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\ia32\\mpirt;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\ia32\\compiler;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\intel64\\compiler;C:\\Program Files (x86)\\Common Files\\Intel\\Shared Libraries\\redist\\ia32\\compiler; C:\\Program Files (x86)\\CMG\\LAUNCHER\\2011.01\\Win32\\exe;C:\\Program Files (x86)\\CMG\\LAUNCHER\\2009.13\\Win32\\exe;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Microsoft SQL Server\\90\\Tools\\binn\\;C:\\Program Files (x86)\\IBM\\RationalSDLC\\ClearCase\\bin;C:\\Program Files (x86)\\IBM\\RationalSDLC\\common;c:\\program files (x86)\\winxs32\\bin;c:\\pfe;c:\\windiff;C:\\Program Files (x86)\\Common Files\\Roxio Shared\\DLLShared\\;C:\\Program Files (x86)\\Common Files\\Roxio Shared\\10.0\\DLLShared\\;C:\\Program Files\\Microsoft Compute Cluster Pack\\Bin\\;D:\\tools;D:\\tools\\dist;C:\\Program Files (x86)\\Intel\\Compiler\\11.1\\051\\bin\\intel64;C:\\Program Files (x86)\\Microsoft Visual Studio 9.0\\VC\\bin;C:\\Program Files (x86)\\Microsoft Visual Studio 9.0\\VC\\bin\\amd64;C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\mpirt;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
Platform=X64
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 44 Stepping 2, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=2c02
PRODUCT_NAME=Intel® Composer XE 2011
PRODUCT_NAME_FULL=Intel® Composer XE 2011 Update 3 (package 175)
ProgramData=C:\\ProgramData
PROMPT=$P$G
PSModulePath=C:\\Windows\\system32\\WindowsPowerShell\\v1.0\\Modules\\
PUBLIC=C:\\Users\\Public
RATIONAL_ICU4J_DIR=C:\\Program Files (x86)\\IBM\\RationalSDLC\\common\\java\\icu
RATIONAL_ICU4J_VERSION=3_8_1
REDIST=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist
RoxioCentral=C:\\Program Files (x86)\\Common Files\\Roxio Shared\\10.0\\Roxio Central36\\
SCRIPT_NAME=compilervars_arch.bat
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\\Windows
TARGET_ARCH=intel64
TARGET_VS=vs2010
TARGET_VS_ARCH=amd64
TBB30_BIN_DIR=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\tbb\\bin\\
TBB30_INSTALL_DIR=C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\tbb\\bin\\..
TBB_ARCH_PLATFORM=intel64\\vc10
TBB_CXX=icl.exe
TBB_TARGET_ARCH=intel64
TBB_TARGET_VS=vc10
TEMP=C:\\Users\\dingjun\\AppData\\Local\\Temp
TMP=C:\\Users\\dingjun\\AppData\\Local\\Temp
USERDNSDOMAIN=CGY.CMGL.CA
USERDOMAIN=CMGL
USERNAME=dingjun
USERPROFILE=C:\\Users\\dingjun
VCINSTALLDIR=C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\
VNI_F90_MSG=C:\\Program Files\\Microsoft Visual Studio\\DF98\\IMSL\\MESSAGE
VS100COMNTOOLS=C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\Common7\\Tools\\
VSEDEFLOGDIR=C:\\ProgramData\\McAfee\\DesktopProtection
VSINSTALLDIR=C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\
VTUNE_AMPLIFIER_XE_2011_DIR=C:\\Program Files (x86)\\Intel\\VTune Amplifier XE 2011\\
windir=C:\\Windows
WindowsSdkDir=C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\
WIN_TITLE=Intel® Composer XE 2011 Intel® 64 Visual Studio 2010
WIN_TITLE_ARCH=Intel® 64
WIN_TITLE_VS=Visual Studio 2010
James_T_Intel
Hi Dingjun,
Please try adding impimt.lib to your link line.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
dingjun_chencmgl_ca
Hi again, James,
I have tried to do it and failed. I have attached below my makefile. Could you see it and tell me where to add it?
Thanks indeed.
Dingjun
James_T_Intel
Hi Dingjun,
The file did not attach, please try again.  Or if you want to email it directly to me, that will work as well.
Sincerely,
James Tullos
dingjun_chencmgl_ca
# ------------------------------------------------------------------------------------------- # | | # | UNIX MAKEFILE for IMEX | # | ---------------------- | # | | # | Usage: | # | | # | clearmake | # | ..........................to make an imex executable: imex.exe | # | | # | clearmake imex.exe | # | ..........................to make an imex executable: imex.exe | # | | # | clearmake fgmx.dll | # | ..........................to make an FORMEX dll (see note 1): fgmx.dll | # | | # | clearmake mxsrc.split | # | ..........................to make IMEX split source code | # | | # | clearmake imex.src | # | ..........................to make IMEX secure source code (see note 5) | # | | # | clearmake fgmxsrc.split | # | ..........................to make PC FORMEX IMEX split source code | # | | # | clearmake fx.src | # | ..........................to copy PC FORMEX IMEX split source code | # | | # | Notes: | # | | # | Note 1: to make FGMX.DLL: in Makefile.options uncomment | # | imex.o := SED_PROCESSOR = 's/^c.fg//;s/^ program imex//' | # | There are some other Makefile.options changes - see Makefile_pc_fmo.options | # | for optimized code and Makefile_pc-fmd.options for debug code. | # | | # | Note 2: Do not delete source code files that are generated by a build rule | # | (e.g., 'imex2_aloc.f' for target 'imex2.inc'). | # | Unlike MAKE, CLEARMAKE checks for the existence of these intermediate | # | files. It is also good to have them for debugging purposes. | # | Note 3: When using CLEARMAKE, put the element-dependent compile options | # | in the file 'Makefile.options'. | # | Note 4: The macro SED_PROCESSOR is the 'sed' command to enable | # | platform-specific code, etc. It is set to null by default, | # | but should be assigned for the required element | # | in 'Makefile.options'. | # | Note 5: The target imex.src for UNIX platforms builds a secure source in a non-vob | # | directory. A build of imex.exe in /imex/bin must be done first. | # | For pc target platform, imex.src builds a source build (non-secure) in a | # | non-vob directory, including dll's and lib's. These files may be copied | # | to the pc, compiled and then copied back along with the .o's. The following | # | source files must then be deleted: | # | aimptr.f avmult.f forbkv.f genluv.f jdump.f minvsq.f order.f prepro.f | # | presym.f pstpro.f scalp.f solver.f symfcv.f mxslvr.f mxslvr_aloc.f | # | mxslvr1_aloc.f callap.f callls.f callsc.f callsl.f simver.f mxprsl_mod.f | # | | # ------------------------------------------------------------------------------------------- # This version for the hybrid MPI/OpenMP #-- Over-all Defaults FC = f90 FFLAGS = CFLAGS = LIBS = UXKEY = SED_PROCESSOR = PLATFORM = D = \ O = obj COPY = cp -f COPY_PREPRO = cp -f PREPRO = fpp /P DELETE = rm -f CAT = cat CHDIR = cd SED = /bin/sed MOVE = mv LINK_OUT = -o $(N) XDR_TYPE = ux EOC = ; SECURE_INC = OPENMP_DLL = LSDIR = dir REDIR = VIEW = D2U = MISSING_IMPORTS = impimt.lib LICENSE_LIB = libsecure.a REPR_LIB = librlm.a BLD_HOST_TYPE = win32 BINREADER_LIB = libbinarrayfile.a BINREADER_DLL = binarrayfile.dll MANIFEST = mt.exe ReqExecLevelInvoker.manifest MANIFEST_EXEC= mt.exe -manifest ReqExecLevelInvoker.manifest -outputresource:imex.exe;1 COMPVER_SRC= compver.f XDRMOD_SRC = xdrint_mod.f XDRMOD = $(XDRMOD_SRC:.f=.$(O)) PC_XDR_LIB =impimt.lib # setup large ints to be 4 or 8 bytes LARGE_INT_MOD_SRC = large_int4_mod.f # f90 style allocate's ALOC = $(@:_mod.f=_aloc.f) F90_DEPENDENCY = $(F90_MOD_OBJS) # --------------------------------------------- # | | # | L I B R A R Y M A C R O S | # | | # --------------------------------------------- #-- IMEX Library # ------------- IMEX_BIN = $(VIEW)$(D)imex$(D)bin$(D) #-- Dependencies Library # -------------------- MAKE_OPTS = $(MAKEFILE).options IMEX_LIB = $(VIEW)$(D)imex$(D)imex.lib$(D) IMEX_OBJS = \ imex.$(O) \ allcat.$(O) \ asignv.$(O) \ dynamx.$(O) \ dygrck.$(O) \ dbgpar.$(O) \ aqcal.$(O) \ anmist.$(O) \ begin.$(O) \ bryflw.$(O) \ callap.$(O) \ calljb.$(O) \ calllp.$(O) \ callls.$(O) \ callsc.$(O) \ callsl.$(O) \ callst.$(O) \ callwm.$(O) \ call_eqtpar.$(O) \ chkcmx.$(O) \ cldate.$(O) \ clday.$(O) \ compak.$(O) \ conv.$(O) \ cubeq.$(O) \ cvgptv.$(O) \ datini.$(O) \ datum.$(O) \ dbrent.$(O) \ denogs.$(O) \ dicrak.$(O) \ diform.$(O) \ diltab.$(O) \ dmndmx.$(O) \ dnpntr.$(O) \ dpdzwb.$(O) \ dvzcal.$(O) \ dwlayr.$(O) \ endmci.$(O) \ endpts.$(O) \ eqnmfc.$(O) \ eqnsa.$(O) \ eqnsav.$(O) \ eqnsfv.$(O) \ expiry.$(O) \ ffrict.$(O) \ fluxsct.$(O) \ flxscout.$(O) \ fluxsfm.$(O) \ frcmoody.$(O) \ genbis.$(O) \ grgetsim.$(O) \ hystst.$(O) \ incomp.$(O) \ indasr.$(O) \ indata.$(O) \ indatm.$(O) \ indbug.$(O) \ indt.$(O) \ indynm.$(O) \ inendpt_recur.$(O) \ ineqil.$(O) \ infohd.$(O) \ inhert_gm.$(O) \ iniblks.$(O) \ inini1.$(O) \ inini2.$(O) \ ininit.$(O) \ inio.$(O) \ iniord.$(O) \ innum.$(O) \ inrel.$(O) \ inres.$(O) \ inres_fsct.$(O) \ intplt.$(O) \ intwrt.$(O) \ inwell.$(O) \ inwint.$(O) \ jbuild.$(O) \ jst.$(O) \ krochk.$(O) \ krolup.$(O) \ lay1mx.$(O) \ lescal.$(O) \ lessr2.$(O) \ levstr.$(O) \ linint.$(O) \ lstpar.$(O) \ lstpro.$(O) \ matbal.$(O) \ matinv.$(O) \ maxchg.$(O) \ mcinit.$(O) \ mnbrak.$(O) \ multi1.$(O) \ md2sur.$(O) \ mxasin.$(O) \ mxcent.$(O) \ mxcspf.$(O) \ mxdmnew.$(O) \ mxeos.$(O) \ mxgetf.$(O) \ mxinit.$(O) \ mxitfg.$(O) \ mxptos.$(O) \ mxrops.$(O) \ mxsetf.$(O) \ mxsrwg.$(O) \ mxwskp.$(O) \ ndarcy.$(O) \ nondarcy.$(O) \ opprnt.$(O) \ outin.$(O) \ outv.$(O) \ outflux.$(O) \ pcmnmx.$(O) \ phswch.$(O) \ plawln.$(O) \ plawrg.$(O) \ plchi.$(O) \ pldchi.$(O) \ pormci.$(O) \ porcrb.$(O) \ portab.$(O) \ poten.$(O) \ power.$(O) \ prkrpc.$(O) \ prnbgn.$(O) \ propc.$(O) \ propi.$(O) \ proppc.$(O) \ propsn.$(O) \ propsp.$(O) \ propwb.$(O) \ prpsat.$(O) \ psdobb.$(O) \ psdocm.$(O) \ psdoi.$(O) \ psdosb.$(O) \ psfcal.$(O) \ pthresh.$(O) \ pvtchk.$(O) \ qquit.$(O) \ rdprn.$(O) \ regm2.$(O) \ relpmc.$(O) \ resid.$(O) \ resolve_cons.$(O) \ resolve_ipr.$(O) \ resolve_link.$(O) \ resolve_op.$(O) \ restrd.$(O) \ restwt.$(O) \ rk4wb.$(O) \ rk4mom.$(O) \ rkintdf.$(O) \ rkintmo.$(O) \ rkintw.$(O) \ rkqcwb.$(O) \ rkqmom.$(O) \ rhows.$(O) \ rstrcn.$(O) \ rstrdd.$(O) \ rstrdw.$(O) \ rstsec.$(O) \ satlrt.$(O) \ satrbl.$(O) \ save.$(O) \ savejb.$(O) \ sbasin.$(O) \ sctcal.$(O) \ secout.$(O) \ secsr2.$(O) \ secwel.$(O) \ setpfc.$(O) \ setprf.$(O) \ settbp.$(O) \ setupv.$(O) \ shif.$(O) \ simdim.$(O) \ sltsmo.$(O) \ slvint.$(O) \ solpas.$(O) \ sorland.$(O) \ spcchr.$(O) \ spcsrf.$(O) \ spline.$(O) \ splinl.$(O) \ splint.$(O) \ splinw.$(O) \ srfint.$(O) \ srfout.$(O) \ srgrid.$(O) \ stab.$(O) \ strat.$(O) \ strsr2.$(O) \ swtsmo.$(O) \ sur2md.$(O) \ tabsat.$(O) \ tblint.$(O) \ tblchk.$(O) \ thswch.$(O) \ timsum.$(O) \ totpi.$(O) \ trap.$(O) \ trmcrb.$(O) \ tsbomb.$(O) \ tsconv.$(O) \ tshead.$(O) \ tsio.$(O) \ tswcnv.$(O) \ tswell.$(O) \ tswlap.$(O) \ unitcn.$(O) \ upkcyc.$(O) \ validk.$(O) \ varass.$(O) \ velcty.$(O) \ vrec.$(O) \ watrvs.$(O) \ wbcomp.$(O) \ wecho.$(O) \ welbr1.$(O) \ welbr2.$(O) \ welbr3.$(O) \ welbr4.$(O) \ welbr5.$(O) \ welbr7.$(O) \ welbrn.$(O) \ welcum.$(O) \ welhed.$(O) \ well.$(O) \ wellcs.$(O) \ welmom.$(O) \ welout.$(O) \ welpis.$(O) \ welscl.$(O) \ welsrf.$(O) \ whpcal.$(O) \ wlmpas.$(O) \ wlrate.$(O) \ wpinit.$(O) \ wpnter.$(O) \ wdpntr.$(O) \ wscout.$(O) \ xfcalc.$(O) #-- AIMSOL Library # -------------- AIMSOL_LIB = $(VIEW)$(D)aimsol$(D)aimsol.lib$(D) AIMSOL_OBJS = \ aimptp.$(O) \ aimptr.$(O) \ avmulp.$(O) \ avmult.$(O) \ eqtpar.$(O) \ forbkp.$(O) \ forbkv.$(O) \ genlup.$(O) \ genluv.$(O) \ gmresp.$(O) \ jdump.$(O) \ mindeg.$(O) \ minsqp.$(O) \ minvsq.$(O) \ order.$(O) \ orderp.$(O) \ parasol.$(O) \ prepro.$(O) \ preprp.$(O) \ presym.$(O) \ presyp.$(O) \ pstpro.$(O) \ pstprp.$(O) \ rdsord.$(O) \ scalp.$(O) \ scalpp.$(O) \ solver.$(O) \ symfcp.$(O) \ symfcv.$(O) #-- GRID Library # -------------- GRID_LIB = $(VIEW)$(D)shared$(D)grid.lib$(D) GRID_OBJS = \ grappk.$(O) \ graqui.$(O) \ grcell.$(O) \ grcnc1.$(O) \ grcnc2.$(O) \ grcnc4.$(O) \ grcnc5.$(O) \ grcnc6.$(O) \ grcnc7.$(O) \ grcnc8.$(O) \ grsrcd.$(O) \ grcnc8nb.$(O) \ grcorn2nd.$(O) \ grcncb.$(O) \ grcnct.$(O) \ grwritecn.$(O) \ gradrg.$(O) \ grcncx.$(O) \ grcncw.$(O) \ grcnmp.$(O) \ grcnnp.$(O) \ grcorn.$(O) \ grdbas.$(O) \ grdbug.$(O) \ grdbst.$(O) \ grinit.$(O) \ grlast.$(O) \ grload.$(O) \ grmai1.$(O) \ grmain.$(O) \ grmess.$(O) \ grnhrt.$(O) \ grpdgd.$(O) \ grpkpt.$(O) \ grmkpt.$(O) \ grptcs.$(O) \ grrgtl.$(O) \ grrdap.$(O) \ grrdar.$(O) \ grrdcp.$(O) \ grrdg2.$(O) \ grrdg3.$(O) \ grrdg4.$(O) \ grrdg5.$(O) \ grrdg6.$(O) \ gramal.$(O) \ grptwtsr.$(O) \ grrdgr.$(O) \ grrdpa.$(O) \ grrdrg.$(O) \ grread.$(O) \ grresr.$(O) \ grrev1.$(O) \ grrev2.$(O) \ grrevu.$(O) \ grscan.$(O) \ grspec.$(O) \ grspt1.$(O) \ grspt2.$(O) \ grspt3.$(O) \ grspt4.$(O) \ grspt5.$(O) \ grspt6.$(O) \ grspt5nb.$(O) \ grspt6nb.$(O) \ grsptl.$(O) \ grtrnf.$(O) \ grunit.$(O) \ grutil.$(O) \ grvar1.$(O) \ grvar2.$(O) \ grvarm.$(O) \ igrlnk.$(O) # grife1.$(O) \ # grife2.$(O) \ #-- MXGM Library # ------------ MXGM_LIB = $(VIEW)$(D)shared$(D)mxgm.lib$(D) MXGM_OBJS = \ blksat.$(O) \ condpt.$(O) \ dtbinp.$(O) \ dwodgo.$(O) \ gasden.$(O) \ kro3p.$(O) \ mcdeps.$(O) \ mcdpfn.$(O) \ mcdpit.$(O) \ mcsort.$(O) \ mdqcin.$(O) \ oilden.$(O) \ pcgwoc.$(O) \ rk4in.$(O) \ rk4in2.$(O) \ rk4st2.$(O) \ rk4stp.$(O) \ rkqci2.$(O) \ rkqcin.$(O) \ rmbgin.$(O) \ satsmc.$(O) \ tbintg.$(O) \ watden.$(O) \ welprm.$(O) #-- PARASOL Library # --------------- PARASOL_LIB = $(VIEW)$(D)aimsol$(D)parasol.lib$(D) PARASOL_OBJS = \ pschbd.$(O) \ psgnbs.$(O) \ pslvds.$(O) \ pslvst.$(O) \ pspldn.$(O) \ psreor.$(O) \ psrtls.$(O) \ psslds.$(O) \ ps2dds.$(O) \ ps2dds_regular.$(O) \ ps2dds_general.$(O) \ ps2dds_actpls.$(O) \ ps2dds_wrkbalance.$(O) \ ps2dds_auxil.$(O) \ psspa2.$(O) \ psspg1.$(O) \ psvrtx.$(O) #-- POINTER Library # --------------- POINTER_LIB = $(VIEW)$(D)shared$(D)pointer.lib$(D) POINTER_OBJS = \ acopy.$(O) \ aucopy.$(O) \ cginit.$(O) \ cstfun.$(O) \ cstijk.$(O) \ cstuba.$(O) \ dpnter.$(O) \ ijktps.$(O) \ inuba.$(O) \ ipftpm.$(O) \ ipmtpf.$(O) \ prtbln.$(O) \ prtcon.$(O) \ prtset.$(O) \ pstsv.$(O) \ ptasin.$(O) \ ptcsva.$(O) \ ptprn.$(O) \ ptwtsr.$(O) \ ubatcs.$(O) #-- REPORT Library # --------------- REPORT_LIB = $(VIEW)$(D)shared$(D)report.lib$(D) REPORT_OBJS = \ rpfmln.$(O) rppmul.$(O) rptabl.$(O) #-- SR2 Library # ----------- SR2_LIB = $(VIEW)$(D)shared$(D)sr2.lib$(D) SR2_OBJS = \ sratcp.$(O) \ srclos.$(O) \ srcpin.$(O) \ srdict.$(O) \ srfrwd.$(O) \ srgeta.$(O) \ srinit.$(O) \ srnckl.$(O) \ srprec.$(O) \ srrdea.$(O) \ srrdin.$(O) \ srrdt2.$(O) \ srrdt2c.$(O) \ srrdt3.$(O) \ srrdt4.$(O) \ srrdt5.$(O) \ srrdtm.$(O) \ srrkls.$(O) \ srscan.$(O) \ srsclr.$(O) \ srscrr.$(O) \ srscxd.$(O) \ srseta.$(O) \ srskip.$(O) \ srskt2.$(O) \ srvrat.$(O) \ srwkls.$(O) \ srwkni.$(O) \ srwpar.$(O) \ srwpt2.$(O) \ srwret.$(O) \ srwrfn.$(O) \ srwrt1.$(O) \ srwrt2.$(O) \ srwrt2c.$(O) \ srwrt3.$(O) \ srwrt4.$(O) \ srwrt5.$(O) \ srwrt6.$(O) \ srwrtm.$(O) SR2_C_OBJS = xdrint.$(O) #-- TOOLS Library # ------------- TOOLS_LIB = $(VIEW)$(D)shared$(D)tools.lib$(D) TOOLS_OBJS = \ aiqual.$(O) \ cdatim.$(O) \ chtoin.$(O) \ chtoup.$(O) \ cmg_sleep.$(O) \ cmgtar.$(O) \ cpack.$(O) \ datime.$(O) \ date_to_days.$(O) \ dbtoch.$(O) \ exxit.$(O) \ getcpu.$(O) \ getdpr.$(O) \ getclk.$(O) \ gethost.$(O) \ getlen.$(O) \ getwrd.$(O) \ header.$(O) \ hepsrt.$(O) \ ihpsrt.$(O) \ inaray.$(O) \ inuary.$(O) \ infile.$(O) \ in8toch.$(O) \ inltoch.$(O) \ intabl.$(O) \ intoch.$(O) \ kyobls.$(O) \ kyskip.$(O) \ kwget.$(O) \ kwset.$(O) \ lnb.$(O) \ messag.$(O) \ parse.$(O) \ procstat.$(O) \ rcaray.$(O) \ rcdpr.$(O) \ rdaray.$(O) \ rdline.$(O) \ retoch.$(O) \ rltoch.$(O) \ setio.$(O) \ setio5.$(O) \ sigcl1.$(O) \ sigft1.$(O) \ siggst.$(O) \ str_delim.$(O) \ string.$(O) \ tearwd.$(O) \ wsallc.$(O) \ wscall.$(O) \ wschck.$(O) \ wsfree.$(O) \ wsinit.$(O) \ wsprnt.$(O) TOOLS_C_OBJS = #-- WELMAN Library # -------------- WELMAN_LIB = $(VIEW)$(D)shared$(D)welman.lib$(D) WELMAN_OBJS = \ wmalin.$(O) \ wmbdin.$(O) \ wmbrwi.$(O) \ wmbwit.$(O) \ wmcent.$(O) \ wmcgin.$(O) \ wmcknm.$(O) \ wmclin.$(O) \ wmcmpi.$(O) \ wmcmpp.$(O) \ wmcmsg.$(O) \ wmcnvt.$(O) \ wmcsin.$(O) \ wmcsvi.$(O) \ wmcwsi.$(O) \ wmcwst.$(O) \ wmdvin.$(O) \ wmdwsm.$(O) \ wmfmiw.$(O) \ wmfmpw.$(O) \ wmfwin.$(O) \ wmgcci.$(O) \ wmgccp.$(O) \ wmgccv.$(O) \ wmgcin.$(O) \ wmgdri.$(O) \ wmgdrp.$(O) \ wmget.$(O) \ wmgetf.$(O) \ wmgetll.$(O) \ wmghyd.$(O) \ wmghyi.$(O) \ wmgimr.$(O) \ wmglin.$(O) \ wmglls.$(O) \ wmgpmr.$(O) \ wmgrai.$(O) \ wmgrap.$(O) \ wmgrcn.$(O) \ wmgrin.$(O) \ wmgrls.$(O) \ wmgydi.$(O) \ wmgydr.$(O) \ wmgyfi.$(O) \ wmgyfs.$(O) \ wmhfpin.$(O) \ wmhydi.$(O) \ wmhydr.$(O) \ wmhyfs.$(O) \ wmhymd.$(O) \ wmhysi.$(O) \ wmichc.$(O) \ wmigai.$(O) \ wmigap.$(O) \ wmilst.$(O) \ wmimap.$(O) \ wminit.$(O) \ wminmr.$(O) \ wminsr.$(O) \ wminje.$(O) \ wminpt.$(O) \ wmipai.$(O) \ wmipap.$(O) \ wmisin.$(O) \ wmisum.$(O) \ wmitin.$(O) \ wmitlu.$(O) \ wmlbin.$(O) \ wmlcin.$(O) \ wmlgci.$(O) \ wmlgcp.$(O) \ wmlgin.$(O) \ wmlifd.$(O) \ wmlift.$(O) \ wmllin.$(O) \ wmllrc.$(O) \ wmlmpsetlysm.$(O) \ wmlyid.$(O) \ wmlynm.$(O) \ wmlopd.$(O) \ wmlypr.$(O) \ wmlimc.$(O) \ wmlioc.$(O) \ wmlpmc.$(O) \ wmlpoc.$(O) \ wmlsin.$(O) \ wmlsrt.$(O) \ wmlyad.$(O) \ wmlyif.$(O) \ wmlypn.$(O) \ wmmain.$(O) \ wmmani.$(O) \ wmmanp.$(O) \ wmmcni.$(O) \ wmmcon.$(O) \ wmmimr.$(O) \ wmmirt.$(O) \ wmmirz.$(O) \ wmmisi.$(O) \ wmmnti.$(O) \ wmmpmr.$(O) \ wmmprt.$(O) \ wmmprz.$(O) \ wmmpsi.$(O) \ wmmsnt.$(O) \ wmmssm.$(O) \ wmmtri.$(O) \ wmmtrt.$(O) \ wmmwpr.$(O) \ wmmxit.$(O) \ wmmxth.$(O) \ wmncch.$(O) \ wmncci.$(O) \ wmndpn.$(O) \ wmndti.$(O) \ wmocni.$(O) \ wmocon.$(O) \ wmopnl.$(O) \ wmopnw.$(O) \ wmotin.$(O) \ wmowwi.$(O) \ wmowwp.$(O) \ wmpchc.$(O) \ wmpiin.$(O) \ wmplri.$(O) \ wmplrt.$(O) \ wmplst.$(O) \ wmprin.$(O) \ wmprmr.$(O) \ wmprn1.$(O) \ wmprn3.$(O) \ wmprn4.$(O) \ wmprnt.$(O) \ wmprod.$(O) \ wmpsum.$(O) \ wmptin.$(O) \ wmptlu.$(O) \ wmpwwo.$(O) \ wmqimx.$(O) \ wmqpmx.$(O) \ wmrcal.$(O) \ wmrcit.$(O) \ wmrcyc.$(O) \ wmrgin.$(O) \ wmrkai.$(O) \ wmrkap.$(O) \ wmrlin.$(O) \ wmrllr.$(O) \ wmrlnl.$(O) \ wmropn.$(O) \ wmrsrd.$(O) \ wmrswt.$(O) \ wmrtgi.$(O) \ wmrtgp.$(O) \ wmrtzo.$(O) \ wmrzth.$(O) \ wmrzoi.$(O) \ wmscan.$(O) \ wmscin.$(O) \ wmscpm.$(O) \ wmset.$(O) \ wmsetf.$(O) \ wmsr2h.$(O) \ wmsr2m.$(O) \ wmsrln.$(O) \ wmtrch.$(O) \ wmtrin.$(O) \ wmtrst.$(O) \ wmtrte.$(O) \ wmtrwt.$(O) \ wmupcm.$(O) \ wmvldk.$(O) \ wmvpin.$(O) \ wmwain.$(O) \ wmwbhp.$(O) \ wmwfri.$(O) \ wmwfrg.$(O) \ wmwfrp.$(O) \ wmwgfp.$(O) \ wmwhin.$(O) \ wmwhsm.$(O) \ wmwhyd.$(O) \ wmwlin.$(O) \ wmwlls.$(O) \ wmwlpn.$(O) \ wmwlsr.$(O) \ wmwlwt.$(O) \ wmwtin.$(O) #-- BINARRAY Library # ---------------- BINARRAY_LIB = $(VIEW)$(D)shared$(D)binarrayfile.lib IMPI_LIB = C:$(D)Program Files (x86)$(D)Intel$(D)MPI$(D)4.0.3.009$(D)em64t$(D)lib$(D)impimt.lib #-- CMG License Library # ------------------- CMGSECURE_LIB = $(VIEW)$(D)shared$(D)secure.lib$(D)cmgsecure$(D) #-- Reprise License Library # ----------------------- REPRISELM_LIB = $(VIEW)$(D)shared$(D)secure.lib$(D)repriselm$(D) #-- Binary Pool # ----------- BINARY_POOL = $(VIEW)$(D)imex$(D)binary_pool$(D) BINARY_OBJS = $(IMEX_OBJS) simver.$(O) compver.$(O) \ $(F90_ALOC_OBJS) \ $(AIMSOL_OBJS) \ $(GRID_OBJS) \ $(MXGM_OBJS) \ $(PARASOL_OBJS) \ $(POINTER_OBJS) \ $(REPORT_OBJS) \ $(SR2_OBJS) \ $(SR2_C_OBJS) \ $(TOOLS_OBJS) \ $(TOOLS_C_OBJS) \ $(WELMAN_OBJS) BINARY_OBJS_LNK = $(BINARY_OBJS) BINARY_MX_OBJS = $(BINARY_OBJS) BINARY_MX_OBJS_LNK = $(BINARY_MX_OBJS) F90_DEPENDENCY_LNK = $(F90_DEPENDENCY) IMEX_INCS = mxeqnloc.inc mxthpr.inc TOOLS_INCS = wscoin.inc F90_INCS = mxeqnloc.inc mxthpr.inc wscoin.inc IMEX_MOD_SRC = \ imex1_mod.f \ imex2_mod.f \ imex3_mod.f \ mxgr01_mod.f \ mxinit_mod.f \ mxslvr1_mod.f \ mxslvr_mod.f \ mxprsl_mod.f \ mxwell_mod.f \ params_mod.f \ sector_mod.f IMEX_ALOC_SRC = $(IMEX_MOD_SRC:_mod.f=_aloc.f) AIMSOL_MOD_SRC = aimint_mod.f aimloc_mod.f eqtpar_mod.f AIMSOL_ALOC_SRC = eqtpar_aloc.f GRID_MOD_SRC = grmod0_mod.f grmod1_mod.f grmod2_mod.f grife1_mod.f grife2_mod.f GRID_ALOC_SRC = grmod0_aloc.f grmod1_aloc.f grmod2_aloc.f GRID_ALOC_OBJS = $(GRID_ALOC_SRC:.f=.$(O)) PARASOL_MOD_SRC = domain2dproc_mod.f POINTER_MOD_SRC = point_mod.f ptlocal_mod.f prtcm_mod.f POINTER_ALOC_SRC = $(POINTER_MOD_SRC:_mod.f=_aloc.f) SR2_MOD_SRC = sr2com_mod.f $(XDRMOD_SRC) SR2_ALOC_SRC = $(SR2_MOD_SRC:_mod.f=_aloc.f) TOOLS_MOD_SRC = cmgfile_mod.f globstore_mod.f kwcom1_mod.f toolsint_mod.f wscom1_mod.f TOOLS_MOD_SPEC_SRC = large_int_mod.f TOOLS_ALOC_SRC = cmgfile_aloc.f kwcom1_aloc.f wscom1_aloc.f WELMAN_MOD_SRC = wmcom1_mod.f wmcom2_mod.f wmcom4_mod.f wmcom5_mod.f WELMAN_ALOC_SRC = $(WELMAN_MOD_SRC:_mod.f=_aloc.f) WELMAN_ALOC_OBJS = $(WELMAN_MOD_OBJS:_mod.$(O)=_aloc.$(O)) F90_MOD_SRC = $(IMEX_MOD_SRC) \ $(AIMSOL_MOD_SRC) \ $(GRID_MOD_SRC) \ $(PARASOL_MOD_SRC) \ $(POINTER_MOD_SRC) \ $(SR2_MOD_SRC) srdict_mod.f \ $(TOOLS_MOD_SPEC_SRC) \ $(TOOLS_MOD_SRC) \ $(WELMAN_MOD_SRC) IMEX_MOD_OBJS = $(IMEX_MOD_SRC:_mod.f=_mod.$(O)) AIMSOL_MOD_OBJS = $(AIMSOL_MOD_SRC:_mod.f=_mod.$(O)) GRID_MOD_OBJS = grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grife1_mod.$(O) grife2_mod.$(O) PARASOL_MOD_OBJS = $(PARASOL_MOD_SRC:_mod.f=_mod.$(O)) POINTER_MOD_OBJS = point_mod.$(O) ptlocal_mod.$(O) prtcm_mod.$(O) SR2_MOD_OBJS = sr2com_mod.$(O) $(XDRMOD) srdict_mod.$(O) TOOLS_MOD_OBJS = cmgfile_mod.$(O) globstore_mod.$(O) kwcom1_mod.$(O) large_int_mod.$(O) toolsint_mod.$(O) wscom1_mod.$(O) WELMAN_MOD_OBJS = wmcom1_mod.$(O) wmcom2_mod.$(O) wmcom4_mod.$(O) wmcom5_mod.$(O) F90_MOD_OBJS = $(IMEX_MOD_OBJS) \ $(AIMSOL_MOD_OBJS) \ $(GRID_MOD_OBJS) \ $(PARASOL_MOD_OBJS) \ $(POINTER_MOD_OBJS) \ $(SR2_MOD_OBJS) \ $(TOOLS_MOD_OBJS) \ $(WELMAN_MOD_OBJS) F90_ALOC_OBJS = \ cmgfile_aloc.$(O) \ eqtpar_aloc.$(O) \ grmod0_aloc.$(O) \ grmod1_aloc.$(O) \ grmod2_aloc.$(O) \ imex1_aloc.$(O) \ imex2_aloc.$(O) \ imex3_aloc.$(O) \ kwcom1_aloc.$(O) \ mxgr01_aloc.$(O) \ mxinit_aloc.$(O) \ mxprsl_aloc.$(O) \ mxslvr_aloc.$(O) \ mxslvr1_aloc.$(O) \ mxwell_aloc.$(O) \ point_aloc.$(O) \ prtcm_aloc.$(O) \ ptlocal_aloc.$(O) \ sector_aloc.$(O) \ sr2com_aloc.$(O) \ wmcom1_aloc.$(O) \ wmcom2_aloc.$(O) \ wmcom5_aloc.$(O) \ wscom1_aloc.$(O) # not req'd for now: grife1_aloc.$(O) grife2_aloc.$(O) F90_ALOC_SRC = $(F90_ALOC_OBJS:.$(O)=.f) #Dynamic dimensioning changes to Makefile. #Rules for include files. # dyndim.exe removed from dependency list due to spurious # rebuild problem on IBM 3CT $(IMEX_INCS): $(COPY) $(IMEX_LIB)$@ $@ $(D2U) $(IMEX_MOD_SRC): $(COPY_PREPRO) $(IMEX_LIB)$@ $@ $(D2U) $(IMEX_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) $(AIMSOL_MOD_SRC): $(COPY_PREPRO) $(AIMSOL_LIB)$@ $@ $(D2U) $(AIMSOL_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) $(GRID_MOD_SRC): $(COPY_PREPRO) $(GRID_LIB)$@ $@ $(D2U) $(GRID_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) $(PARASOL_MOD_SRC): $(COPY_PREPRO) $(PARASOL_LIB)$@ $@ $(D2U) $(POINTER_MOD_SRC): $(COPY_PREPRO) $(POINTER_LIB)$@ $@ $(D2U) $(POINTER_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) $(SR2_MOD_SRC): $(COPY_PREPRO) $(SR2_LIB)$@ $@ $(D2U) $(SR2_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) pcxdr.lib: $(COPY) $(SR2_LIB)$@ $@ $(TOOLS_INCS): $(COPY) $(TOOLS_LIB)$@ $@ $(D2U) $(TOOLS_MOD_SRC): $(COPY_PREPRO) $(TOOLS_LIB)$@ $@ $(D2U) $(TOOLS_MOD_SPEC_SRC): $(COPY_PREPRO) $(TOOLS_LIB)$(LARGE_INT_MOD_SRC) $@ $(D2U) $(TOOLS_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) $(MANIFEST): $(COPY) $(TOOLS_LIB)$@ $@ $(WELMAN_MOD_SRC): $(COPY_PREPRO) $(WELMAN_LIB)$@ $@ $(D2U) $(WELMAN_ALOC_SRC): $$(@:_aloc.f=_mod.f) mod_to_aloc.exe $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ mod_to_aloc.exe -f $(@:_aloc.f=_mod.f) $(D2U) #-- Files for source builds. # ------------------------ IMEX_SRC = $(IMEX_OBJS:.$(O)=.f) AIMSOL_SRC = $(AIMSOL_OBJS:.$(O)=.f) GRID_SRC = $(GRID_OBJS:.$(O)=.f) MXGM_SRC = $(MXGM_OBJS:.$(O)=.f) PARASOL_SRC = $(PARASOL_OBJS:.$(O)=.f) POINTER_SRC = $(POINTER_OBJS:.$(O)=.f) REPORT_SRC = $(REPORT_OBJS:.$(O)=.f) SR2_SRC = $(SR2_OBJS:.$(O)=.f) TOOLS_SRC = $(TOOLS_OBJS:.$(O)=.f) WELMAN_SRC = $(WELMAN_OBJS:.$(O)=.f) MXGM_SRC_TMP = $(MXGM_SRC:.f=.tmp) POINTER_SRC_TMP = $(POINTER_SRC:.f=.tmp) REPORT_SRC_TMP = $(REPORT_SRC:.f=.tmp) TOOLS_SRC_TMP = $(TOOLS_SRC:.f=.tmp) SR2_SRC_TMP = $(SR2_SRC:.f=.tmp) SR2_C_SRC = $(SR2_C_OBJS:.$(O)=.c) TOOLS_C_SRC = $(TOOLS_C_OBJS:.$(O)=.c) ##-- Binary Pool ## ----------- # ALL_F_SRC = $(IMEX_SRC) \ $(AIMSOL_SRC) \ $(GRID_SRC) \ $(MXGM_SRC) \ $(PARASOL_SRC) \ $(POINTER_SRC) \ $(REPORT_SRC) \ $(SR2_SRC) \ $(TOOLS_SRC) \ $(WELMAN_SRC) \ $(F90_ALOC_SRC) \ $(F90_MOD_SRC) ALL_MX_F_SRC = $(ALL_F_SRC) SECURE_SRCS =$(IMEX_SRC) \ $(GRID_SRC) \ $(MXGM_SRC) \ $(PARASOL_SRC) \ $(POINTER_SRC) \ $(REPORT_SRC) \ $(SR2_SRC) \ $(TOOLS_SRC) \ $(WELMAN_SRC) \ $(F90_ALOC_SRC) \ $(F90_MOD_SRC) # --------------------------------------------- # | | # | B U I L D R U L E S | # | | # --------------------------------------------- #-- Ultimate target is link to executable file imex.exe: $(BINARY_MX_OBJS) $(MAKEFILE) $(MAKE_OPTS) $(LICENSE_LIB) $(REPR_LIB) $(F90_DEPENDENCY) \ $(MISSING_IMPORTS) $(LICENSE_DLL) $(OPENMP_DLL) $(BINREADER_LIB) $(BINREADER_DLL) $(MANIFEST) $(PC_XDR_LIB) $(LSDIR) $@ > $@ $(EOC) \ $(DELETE) $@ $(EOC) \ $(LD) $(LINK_FLAGS) $(BINARY_MX_OBJS_LNK) $(LIBS) $(F90_DEPENDENCY_LNK) \ $(LICENSE_LIB) $(REPR_LIB) $(MISSING_IMPORTS) $(BINREADER_LIB) $(PC_XDR_LIB) $(LINK_OUT)$@ $(EOC) \ $(MANIFEST_EXEC) $(EOC) \ echo 'Done.' force_rebuild: @ $(LSDIR) simver.f > simver.f $(EOC) \ $(DELETE) simver.f simver.f: force_rebuild insert_string.exe insert_string.exe -d -v $(VER_NAME) -c $(VER_COM) -f $(IMEX_LIB)$@ > $@ $(D2U) simver.$(O): simver.f $(FC) $(FFLAGS) -c simver.f mxtool.c: $(SR2_C_SRC) @ echo All C tool and SR2 routines have been copied srcb_msg: @ echo .inc and .c files are being copied, if any is needed ... #Build macros specific to platform ALL_IMEX_INCS = $(IMEX_INCS) $(POINTER_INCS) $(SR2_INCS) $(TOOLS_INCS) \ $(WELMAN_INCS) ALL_IMEX_C_SRC = $(SR2_C_SRC) $(TOOLS_C_SRC) #-- Separated Source Code # --------------------- mxsrc.split: $(ALL_MX_F_SRC) simver.f $(COMPVER_SRC) srcb_msg $(ALL_IMEX_INCS) $(ALL_IMEX_C_SRC) \ $(LICENSE_LIB) $(REPR_LIB) $(OPENMP_DLL) $(PC_XDR_LIB) \ $(MAKEFILE) $(BINREADER_LIB) $(BINREADER_DLL) $(MISSING_IMPORTS) @ echo 'build mxsrc.split complete' > mxsrc.split $(EOC) \ echo ' Split source build mxsrc.split complete.' #-- IMEX Library # ------------- $(IMEX_SRC): $(COPY_PREPRO) $(IMEX_LIB)$@ $@ $(D2U) $(IMEX_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- AIMSOL Library # -------------- $(AIMSOL_SRC): $(COPY_PREPRO) $(AIMSOL_LIB)$@ $@ $(D2U) $(AIMSOL_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- GRID Library # -------------- $(GRID_SRC): $(COPY_PREPRO) $(GRID_LIB)$@ $@ $(D2U) $(GRID_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- MXGM Library # ------------ $(MXGM_SRC): $(COPY_PREPRO) $(MXGM_LIB)$@ $@ $(D2U) $(MXGM_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- PARASOL Library # --------------- $(PARASOL_SRC): $(COPY_PREPRO) $(PARASOL_LIB)$@ $@ $(D2U) $(PARASOL_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- POINTER Library # --------------- $(POINTER_SRC): $(COPY_PREPRO) $(POINTER_LIB)$@ $@ $(D2U) $(POINTER_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- REPORT Library # ------------ $(REPORT_SRC): $(COPY_PREPRO) $(REPORT_LIB)$@ $@ $(D2U) $(REPORT_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- TOOLS Library # ------------- $(TOOLS_SRC): $(COPY_PREPRO) $(TOOLS_LIB)$@ $@ $(D2U) $(TOOLS_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) aix_mem_info.c: $(COPY_PREPRO) $(TOOLS_LIB)$@ $@ $(D2U) aix_mem_info.$(O): $(CC) $(CFLAGS) -c $(@:.$(O)=.c) #-- Tool which inserts date, version number and version comment # into simver.f insert_string.exe: $(COPY) $(TOOLS_LIB)$(@:.exe=.f) $(@:.exe=.f) $(EOC) \ $(COPY) $(TOOLS_LIB)cmgtar.f cmgtar_is.f $(EOC) \ $(FC) $(FFLAGS) -c $(@:.exe=.f) $(EOC) \ $(FC) $(FFLAGS) -c cmgtar_is.f $(EOC) \ $(FC) $(LINK_FLAGS) insert_string.$(O) cmgtar_is.$(O) $(LINK_OUT)$@ $(EOC) \ $(DELETE) $(@:.exe=.$(O)) $(EOC) \ $(DELETE) *_is.* #-- Tool which converts mod to aloc for f90 versions mod_to_aloc.exe: $(COPY) $(TOOLS_LIB)$(@:.exe=.f) $(@:.exe=.f) $(EOC) \ $(COPY) $(TOOLS_LIB)cmgtar.f cmgtar_mta.f $(EOC) \ $(FC) $(FFLAGS) -c $(@:.exe=.f) $(EOC) \ $(FC) $(FFLAGS) -c cmgtar_mta.f $(EOC) \ $(FC) $(LINK_FLAGS) mod_to_aloc.$(O) cmgtar_mta.$(O) $(LINK_OUT)$@ $(EOC) \ $(DELETE) $(@:.exe=.$(O)) $(EOC) \ $(DELETE) *_mta.* #-- Tool which auto-generates compver.f for compiler version information compver_gen.f: $(COPY) $(TOOLS_LIB)$@ $@ $(D2U) compver_gen.exe: compver_gen.f $(FC) $(FFLAGS) compver_gen.f $(EOC) rm -f compver_gen.$(O) #-- Local text file to hold compiler version information. #-- Compile the dummy files and capture the compiler output. DUMMY_F = $(FC) -c $(TOOLS_LIB)dummy_f.f > $@ 2>&1 DUMMY_C = && $(CC) -c $(TOOLS_LIB)dummy_c.c >> $@ 2>&1 compver.txt: $(DUMMY_F) $(DUMMY_C) $(EOC) rm -f dummy_*.$(O) #-- Auto-generated routine which returns compiler version info. compver.f: compver.txt compver_gen.exe compver_gen.exe compver.$(O): compver.f $(FC) $(FFLAGS) -c compver.f #-- SR2 Library # ----------- byteordr.c xdr.c xdrarray.c xdrfloat.c xdrint.c xdrrefer.c xdrstdio.c: $(COPY) $(SR2_LIB)$@ $@ $(D2U) #-- FORTRAN include file generated from Source SR2 Data Dictionary dict.dat: $(COPY) $(SR2_LIB)$@ $@ srdict_mod.f: dict.dat $(SR2_LIB)gensr2inc$(D)$(BLD_HOST_TYPE)$(D)gensr2fo.exe $(SR2_LIB)dict.dat > srdict_mod.f $(D2U) $(SR2_SRC): $(COPY_PREPRO) $(SR2_LIB)$@ $@ $(D2U) $(SR2_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) byteordr.$(O) xdr.$(O) xdrarray.$(O) xdrfloat.$(O) xdrint.$(O) xdrrefer.$(O) xdrstdio.$(O): $$(@:.$(O)=.c) $(CC) $(CFLAGS) -c $(@:.$(O)=.c) #-- WELMAN Library # -------------- $(WELMAN_SRC): $(COPY_PREPRO) $(WELMAN_LIB)$@ $@ $(D2U) $(WELMAN_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- MOD, ALOC compiles $(F90_MOD_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) $(F90_ALOC_OBJS): $$(@:.$(O)=.f) $(FC) $(FFLAGS) -c $(@:.$(O)=.f) #-- CMG License Library # ------------------- libsecure.a: $(COPY) $(CMGSECURE_LIB)$(PLATFORM)$(D)$@ . libsecure.lib: $(COPY) $(CMGSECURE_LIB)$(PLATFORM)$(D)$@ . cmgsecure.lib: $(COPY) $(CMGSECURE_LIB)$(PLATFORM)$(D)$@ . cmgsecure.dll: $(COPY) $(CMGSECURE_LIB)$(PLATFORM)$(D)$@ . libiomp5md.dll: $(COPY) $(IMEX_LIB)$(PLATFORM)$(D)$@ . missing_aix_imports.imp: $(COPY) $(CMGSECURE_LIB)$(PLATFORM)$(D)$@ $@ $(D2U) #-- Reprise License Library # ----------------------- librlm.a: $(COPY) $(REPRISELM_LIB)$(PLATFORM)$(D)$@ . rlmclient.lib: $(COPY) $(REPRISELM_LIB)$(PLATFORM)$(D)$@ . rlm.dll: $(COPY) $(REPRISELM_LIB)$(PLATFORM)$(D)$@ . #-- BINARRAY Library # ---------------- binarrayfile.dll: copy $(BINARRAY_LIB)$(D)$(PLATFORM)$(D)$@ $@ $(BINREADER_LIB): copy $(BINARRAY_LIB)$(D)$(PLATFORM)$(D)$@ $@ #-- Include File Dependencies # Module dependencies for modules aimint_mod.$(O): large_int_mod.$(O) eqtpar_mod.$(O) cmgfile_mod.$(O): $(XDRMOD) domain2dproc_mod.$(O): aimloc_mod.$(O) eqtpar_mod.$(O): large_int_mod.$(O) globstore_mod.$(O): large_int_mod.$(O) grmod0_mod.$(O): large_int_mod.$(O) grmod1_mod.$(O): large_int_mod.$(O) imex1_mod.$(O): large_int_mod.$(O) imex2_mod.$(O): large_int_mod.$(O) mxslvr1_mod.$(O): large_int_mod.$(O) mxslvr_mod.$(O): large_int_mod.$(O) params_mod.$(O): large_int_mod.$(O) #-- Include file dependencies for IMEX_LIB files. allcat.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) aqcal.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) grmod1_mod.$(O) asignv.$(O): params_mod.$(O) mxslvr_mod.$(O) begin.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) point_mod.$(O) grmod1_mod.$(O) bryflw.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) sector_mod.$(O) call_eqtpar.$(O): large_int_mod.$(O) aimint_mod.$(O) imex1_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) params_mod.$(O) point_mod.$(O) callap.$(O): params_mod.$(O) aimint_mod.$(O) imex1_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) calljb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) calllp.$(O): params_mod.$(O) aimint_mod.$(O) imex1_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) mxprsl_mod.$(O) callls.$(O): large_int_mod.$(O) aimint_mod.$(O) params_mod.$(O) imex1_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) callsc.$(O): imex1_mod.$(O) imex2_mod.$(O) callsl.$(O): aimint_mod.$(O) params_mod.$(O) imex1_mod.$(O) mxinit_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) mxwell_mod.$(O) wscom1_mod.$(O) callst.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) wscom1_mod.$(O) callwm.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) chkcmx.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) cldate.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) clday.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) compak.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) kwcom1_mod.$(O) grmod1_mod.$(O) conv.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) dbgpar.$(O): params_mod.$(O) imex1_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) denogs.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) dicrak.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) kwcom1_mod.$(O) grmod1_mod.$(O) diform.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) diltab.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) dmndmx.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) dnpntr.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) dpdzwb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) dvzcal.$(O): params_mod.$(O) imex2_mod.$(O) mxwell_mod.$(O) dygrck.$(O): imex1_mod.$(O) imex2_mod.$(O) grmod1_mod.$(O) dynamx.$(O): params_mod.$(O) grmod1_mod.$(O) point_mod.$(O) endmci.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) endpts.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) eqnmfc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) eqnsa.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) eqnsav.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) eqnsfv.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) fluxsct.$(O): params_mod.$(O) sector_mod.$(O) point_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) fluxsfm.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) imex3_mod.$(O) flxscout.$(O): params_mod.$(O) sector_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) genbis.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxprsl_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) point_mod.$(O) wscom1_mod.$(O) large_int_mod.$(O) grgetsim.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) point_mod.$(O) hystst.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) imex.$(O): params_mod.$(O) imex1_mod.$(O) point_mod.$(O) wscom1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) incomp.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) sector_mod.$(O) point_mod.$(O) wscom1_mod.$(O) indasr.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) wscom1_mod.$(O) indata.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) sector_mod.$(O) wscom1_mod.$(O) indbug.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) indt.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) indynm.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) grmod1_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxprsl_mod.$(O) inendpt_recur.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) point_mod.$(O) wscom1_mod.$(O) ineqil.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) infohd.$(O): imex1_mod.$(O) imex2_mod.$(O) inhert_gm.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) sector_mod.$(O) grmod2_mod.$(O) grmod0_mod.$(O) iniblks.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) point_mod.$(O) inini1.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) inini2.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) ininit.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) point_mod.$(O) wscom1_mod.$(O) inio.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) iniord.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) innum.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) wscom1_mod.$(O) inrel.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) wscom1_mod.$(O) inres.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxwell_mod.$(O) kwcom1_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) sector_mod.$(O) grmod2_mod.$(O) inres_fsct.$(O): params_mod.$(O) point_mod.$(O) kwcom1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) sector_mod.$(O) intwrt.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) inwell.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) mxgr01_mod.$(O) grmod1_mod.$(O) grmod0_mod.$(O) grmod2_mod.$(O) inwint.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxwell_mod.$(O) point_mod.$(O) jbuild.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxeqnloc.inc jst.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) krochk.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxwell_mod.$(O) point_mod.$(O) krolup.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) lay1mx.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) lescal.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) lessr2.$(O): imex1_mod.$(O) imex2_mod.$(O) levstr.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxprsl_mod.$(O) lstpar.$(O): aimint_mod.$(O) params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxprsl_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxslvr_mod.$(O) mxslvr1_mod.$(O) large_int_mod.$(O) lstpro.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) matbal.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) maxchg.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) mcinit.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) md2sur.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) mxasin.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) imex3_mod.$(O) point_mod.$(O) mxcspf.$(O): point_mod.$(O) mxdmnew.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) imex3_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) wscom1_mod.$(O) mxeos.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxgetf.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxinit.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxitfg.$(O): params_mod.$(O) imex1_mod.$(O) point_mod.$(O) mxptos.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) mxrops.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxsetf.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxsrwg.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) sector_mod.$(O) wscom1_mod.$(O) point_mod.$(O) ndarcy.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) nondarcy.$(O): params_mod.$(O) imex1_mod.$(O) point_mod.$(O) wscom1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) opprnt.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxwell_mod.$(O) outflux.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) wscom1_mod.$(O) outin.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) point_mod.$(O) sector_mod.$(O) wscom1_mod.$(O) outv.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) pcmnmx.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) phswch.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) porcrb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) portab.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) poten.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) prkrpc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) prnbgn.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) grmod1_mod.$(O) mxwell_mod.$(O) wscom1_mod.$(O) propc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) propi.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) imex3_mod.$(O) proppc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) propsn.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) propsp.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) imex3_mod.$(O) point_mod.$(O) propwb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) imex3_mod.$(O) prpsat.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) psdobb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) psdocm.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) psdoi.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) psdosb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) psfcal.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) pthresh.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) pvtchk.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) imex3_mod.$(O) point_mod.$(O) qquit.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) mxwell_mod.$(O) rdprn.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) relpmc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) resid.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) resolve_cons.$(O): mxwell_mod.$(O) imex2_mod.$(O) resolve_ipr.$(O): mxwell_mod.$(O) params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) resolve_link.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxwell_mod.$(O) mxgr01_mod.$(O) resolve_op.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) restrd.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) kwcom1_mod.$(O) restwt.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) rhows.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) rk4mom.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) rk4wb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) rkintw.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) rkqcwb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) rkqmom.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) rstrcn.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) rstrdd.$(O): params_mod.$(O) grmod1_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) rstrdw.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) rstsec.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) satlrt.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) satrbl.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) save.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxthpr.inc savejb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxthpr.inc sbasin.$(O): params_mod.$(O) point_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) sctcal.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) sector_mod.$(O) wscom1_mod.$(O) secout.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) secsr2.$(O): imex1_mod.$(O) imex2_mod.$(O) secwel.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) sector_mod.$(O) setpfc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) setprf.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) setupv.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) shif.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) simdim.$(O): params_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) sltsmo.$(O): params_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) slvint.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) solpas.$(O): grmod2_mod.$(O) grmod1_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) spcchr.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) spcsrf.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxinit_mod.$(O) point_mod.$(O) wscom1_mod.$(O) splinl.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) splinw.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) srfint.$(O): imex1_mod.$(O) imex2_mod.$(O) srfout.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) wscom1_mod.$(O) grmod0_mod.$(O) srgrid.$(O): imex2_mod.$(O) mxgr01_mod.$(O) stab.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) mxeqnloc.inc strsr2.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) sur2md.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) swtsmo.$(O): params_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) tabsat.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) thswch.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) timsum.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) totpi.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) trmcrb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) tsbomb.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) tsconv.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) tshead.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) tsio.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscom1_mod.$(O) grmod1_mod.$(O) tswcnv.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) tswell.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) imex3_mod.$(O) tswlap.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) unitcn.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) upkcyc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) varass.$(O): params_mod.$(O) imex1_mod.$(O) mxslvr_mod.$(O) point_mod.$(O) velcty.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) point_mod.$(O) mxwell_mod.$(O) vrec.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxslvr_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wbcomp.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) wdpntr.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wecho.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welbr1.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxwell_mod.$(O) welbr2.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welbrn.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welcum.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welhed.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) imex3_mod.$(O) well.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welmom.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welout.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) welpis.$(O): imex1_mod.$(O) mxwell_mod.$(O) params_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) welscl.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxwell_mod.$(O) welsrf.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) whpcal.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) wlmpas.$(O): params_mod.$(O) imex2_mod.$(O) imex1_mod.$(O) mxwell_mod.$(O) wlrate.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxwell_mod.$(O) wpinit.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wpnter.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) point_mod.$(O) wscout.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) sector_mod.$(O) wscom1_mod.$(O) xfcalc.$(O): params_mod.$(O) imex1_mod.$(O) imex2_mod.$(O) imex3_mod.$(O) mxgr01_mod.$(O) mxwell_mod.$(O) #-- Include file dependencies for AIMSOL_LIB files. aimptp.$(O): large_int_mod.$(O) aimptr.$(O): large_int_mod.$(O) avmulp.$(O): large_int_mod.$(O) avmult.$(O): large_int_mod.$(O) eqtpar.$(O): large_int_mod.$(O) eqtpar_mod.$(O) forbkp.$(O): large_int_mod.$(O) forbkv.$(O): large_int_mod.$(O) genlup.$(O): large_int_mod.$(O) genluv.$(O): large_int_mod.$(O) gmresp.$(O): large_int_mod.$(O) jdump.$(O): large_int_mod.$(O) mindeg.$(O): large_int_mod.$(O) order.$(O): large_int_mod.$(O) orderp.$(O): large_int_mod.$(O) parasol.$(O): large_int_mod.$(O) prepro.$(O): large_int_mod.$(O) preprp.$(O): large_int_mod.$(O) presym.$(O): large_int_mod.$(O) presyp.$(O): large_int_mod.$(O) pstpro.$(O): large_int_mod.$(O) pstprp.$(O): large_int_mod.$(O) rdsord.$(O): large_int_mod.$(O) scalp.$(O): large_int_mod.$(O) scalpp.$(O): large_int_mod.$(O) solver.$(O): large_int_mod.$(O) symfcp.$(O): large_int_mod.$(O) symfcv.$(O): large_int_mod.$(O) #-- Include file dependencies for GRID_LIB files. gradrg.$(O): grmod0_mod.$(O) grmod1_mod.$(O) gramal.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grappk.$(O): grmod0_mod.$(O) graqui.$(O): grmod1_mod.$(O) grcell.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grcnc1.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnc2.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnc4.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnc5.$(O): grmod0_mod.$(O) grcnc6.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnc7.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnc8.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnc8nb.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcncb.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grcnct.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcncw.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcncx.$(O): grmod0_mod.$(O) grcnmp.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grcnnp.$(O): grmod0_mod.$(O) grcorn.$(O): grmod0_mod.$(O) grcorn2nd.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grdbas.$(O): grmod0_mod.$(O) grdbug.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grinit.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grlast.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grload.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grmai1.$(O): grmod0_mod.$(O) grmain.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grmkpt.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grnhrt.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grpdgd.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grpkpt.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grptcs.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grptwtsr.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grrdap.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdar.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdcp.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdg2.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdg3.$(O): grmod0_mod.$(O) grrdg4.$(O): grmod0_mod.$(O) grrdg5.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grrdg6.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdgr.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdpa.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrdrg.$(O): grmod0_mod.$(O) grread.$(O): large_int_mod.$(O) grmod2_mod.$(O) grmod1_mod.$(O) grmod0_mod.$(O) grresr.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrev1.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrev2.$(O): grmod0_mod.$(O) grrevu.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grrgtl.$(O): grmod0_mod.$(O) grscan.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grspec.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) grspt1.$(O): large_int_mod.$(O) grmod0_mod.$(O) grspt3.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grspt4.$(O): grmod0_mod.$(O) grspt5.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grspt5nb.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grspt6.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grspt6nb.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grsptl.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grsrcd.$(O): grmod0_mod.$(O) grtrnf.$(O): grmod0_mod.$(O) grunit.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grutil.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grwritecn.$(O): grmod0_mod.$(O) grmod1_mod.$(O) igrlnk.$(O): grmod0_mod.$(O) grmod1_mod.$(O) grmod2_mod.$(O) #-- Include file dependencies for PARASOL_LIB files. ps2dds_actpls.$(O): aimloc_mod.$(O) domain2dproc_mod.$(O) ps2dds_auxil.$(O): aimloc_mod.$(O) domain2dproc_mod.$(O) ps2dds_general.$(O): aimloc_mod.$(O) domain2dproc_mod.$(O) ps2dds_wrkbalance.$(O): aimloc_mod.$(O) domain2dproc_mod.$(O) psgnbs.$(O): large_int_mod.$(O) pslvst.$(O): large_int_mod.$(O) psrtls.$(O): large_int_mod.$(O) psspa2.$(O): large_int_mod.$(O) psspg1.$(O): large_int_mod.$(O) psvrtx.$(O): large_int_mod.$(O) #-- Include file dependencies for POINTER_LIB files. acopy.$(O): point_mod.$(O) cginit.$(O): point_mod.$(O) cstfun.$(O): point_mod.$(O) cstijk.$(O): point_mod.$(O) cstuba.$(O): point_mod.$(O) dpnter.$(O): point_mod.$(O) ijktps.$(O): point_mod.$(O) ipftpm.$(O): point_mod.$(O) ipmtpf.$(O): point_mod.$(O) prtbln.$(O): params_mod.$(O) point_mod.$(O) ptlocal_mod.$(O) prtcon.$(O): point_mod.$(O) prtset.$(O): point_mod.$(O) prtcm_mod.$(O) pstsv.$(O): point_mod.$(O) ptasin.$(O): point_mod.$(O) ptcsva.$(O): params_mod.$(O) point_mod.$(O) ptprn.$(O): point_mod.$(O) prtcm_mod.$(O) ptwtsr.$(O): point_mod.$(O) ubatcs.$(O): point_mod.$(O) #-- Include file dependencies for SR2_LIB files. sratcp.$(O): sr2com_mod.$(O) srclos.$(O): sr2com_mod.$(O) $(XDRMOD) srcpin.$(O): sr2com_mod.$(O) srdict.$(O): srdict_mod.$(O) sr2com_mod.$(O) srfrwd.$(O): sr2com_mod.$(O) $(XDRMOD) srgeta.$(O): sr2com_mod.$(O) srinit.$(O): sr2com_mod.$(O) srnckl.$(O): sr2com_mod.$(O) srprec.$(O): sr2com_mod.$(O) srrdea.$(O): sr2com_mod.$(O) srrdin.$(O): sr2com_mod.$(O) srrdt2.$(O): sr2com_mod.$(O) toolsint_mod.$(O) srrdt3.$(O): sr2com_mod.$(O) srrdt4.$(O): sr2com_mod.$(O) srrdt5.$(O): sr2com_mod.$(O) srrdtm.$(O): sr2com_mod.$(O) srrkls.$(O): sr2com_mod.$(O) srscan.$(O): sr2com_mod.$(O) srsclr.$(O): sr2com_mod.$(O) srscrr.$(O): sr2com_mod.$(O) srscxd.$(O): sr2com_mod.$(O) srseta.$(O): sr2com_mod.$(O) toolsint_mod.$(O) cmgfile_mod.$(O) srskip.$(O): sr2com_mod.$(O) $(XDRMOD) srskt2.$(O): sr2com_mod.$(O) srvrat.$(O): sr2com_mod.$(O) srwkls.$(O): sr2com_mod.$(O) srwkni.$(O): sr2com_mod.$(O) srwpar.$(O): sr2com_mod.$(O) $(XDRMOD) toolsint_mod.$(O) srwret.$(O): sr2com_mod.$(O) srwrfn.$(O): sr2com_mod.$(O) srwrt1.$(O): sr2com_mod.$(O) srwrt2.$(O): sr2com_mod.$(O) toolsint_mod.$(O) srwrt3.$(O): sr2com_mod.$(O) srwrt4.$(O): sr2com_mod.$(O) toolsint_mod.$(O) srwrt5.$(O): sr2com_mod.$(O) srwrt6.$(O): sr2com_mod.$(O) srwrtm.$(O): sr2com_mod.$(O) #-- Include file dependencies for TOOLS_LIB files. getwrd.$(O): kwcom1_mod.$(O) infile.$(O): cmgfile_mod.$(O) inltoch.$(O): large_int_mod.$(O) kwget.$(O): kwcom1_mod.$(O) kwset.$(O): kwcom1_mod.$(O) kyskip.$(O): kwcom1_mod.$(O) messag.$(O): kwcom1_mod.$(O) rcaray.$(O): kwcom1_mod.$(O) rcdpr.$(O): kwcom1_mod.$(O) rdline.$(O): kwcom1_mod.$(O) cmgfile_mod.$(O) setio.$(O): kwcom1_mod.$(O) setio5.$(O): kwcom1_mod.$(O) wsc
dingjun_chencmgl_ca
Please see the file attached. the makefile is too long and I failed to directly paste it in the email several times.
dingjun_chencmgl_ca
Hi, James,
Did you see the makefile in my folder? If not, please let me know your email address and I will directly send it to your email box.
Dingjun
James_T_Intel
Hi Dingjun,
I cannot see your file folders.  Please use the email address on my profile, james.a.tullos@intel.com, or see http://redfort-software.intel.com/en-us/articles/how-to-attach-file-insert-code-into-forum-post/ to attach the file to a post.
Sincerely,
James Tullos
dingjun_chencmgl_ca
James,
I have already sent it to your email box.
dingjun
James_T_Intel
Hi Dingjun,
I believe that the best place to add it would be in the LIBS variable.
Sincerely,
James Tullos
dingjun_chencmgl_ca
Hi, James,
I have tried and the following is shown:
        insert_string.exe -d -v  -c  -f \imex\imex.lib\simver.f > simver.f
        ifort.exe /Qauto /cm /nologo /w /MT  /Qfpp  /DIFL_IA32 /DWIN_X64 /Qopenmp -c simver.f
clearmake: Error:  Don't know how to make "impimt.lib". Stop.
How to do next?
Dingjun
James_T_Intel
Hi Dingjun,
Is LIBS being set somewhere other than in the makefile?  What is insert_string?
Sincerely,
James Tullos
dingjun_chencmgl_ca
HI, James,
LIBS is defined as follows:
LIBS = mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib Wsock32.lib User32.lib shell32.lib Advapi32.lib Gdi32.lib
Insert_string is one of tools developed by us and it is also a .exe file.
Dingjun
dingjun_chencmgl_ca
HI, James,
Please see the followng and compiler used is define in this file.
#-- BOS (Build Options Specification) for:  PC/NT
#-- Things that don't change
#LIBS =
LIBS = mkl_intel_lp64.lib impimt.lib mkl_intel_thread.lib mkl_core.lib Wsock32.lib User32.lib shell32.lib Advapi32.lib Gdi32.lib
#LIBS = mkl_intel_lp64.lib mkl_sequential.lib mkl_core.lib Wsock32.lib User32.lib shell32.lib Advapi32.lib Gdi32.lib
PLATFORM = win_x64
FORTTARG = F90
# pc native build - for the pc link flags must follow /link
#                   /incremental:no forces a complete relink
#                   /out: is the same as the unix -o
#                   link related compiler flags are inserted
#                   using LINK_FLAGS
#                   the default type is a .exe hence /dll
#                   needs to be used for fgmx.dll
#                   with /dll, the default libraries are
#                   multi-threaded, hence use /libs:static
LCCC       = icl
CC         = icl
FC         = ifort.exe
LD         = ifort.exe
FCA        = ifort.exe
LINK_OUT     = /link /incremental:no /out:
D            = \$N
O            = obj
COPY         = copy
DELETE       = del /f
SED          = d:\tools\sed.exe
MOVE         = move
SHELL        =
EOC          = &&
LARGE_INT_MOD_SRC = large_int8_mod.f
LICENSE_LIB     = libsecure.lib
REPR_LIB        = rlmclient.lib
OPENMP_DLL      = libiomp5md.dll
BINREADER_LIB     = binarrayfile.lib
SR2_C_OBJS     = byteordr.obj xdr.obj xdrarray.obj xdrfloat.obj xdrint.obj xdrrefer.obj xdrstdio.obj
BINARY_MX_OBJS_LNK  = *.obj
insert_string.exe mod_to_aloc.exe compver_gen.exe
        := LINK_FLAGS = /4Yportlib
        := LINK_OUT   = /link /incremental:no /out:
#-- Code Preprocessor Directives
#-- To add another pre-processor, define its macro similar to
#   existing ones and add it to the list defining PP.
#initialize pre-processors
PP_CVF        =
PP_DD         =
PP_F95        =
PP_OPENMP_VER =
PP_PN         =
PP_WIN32      =
PP_IFL_IA32   =
PP_WIN_X64    =
PP_NO_BINARRAY =
PP_NO_SECURE  =
PP_NO_XDR     =
PP_RPREC      =
###-- Enable Platform Specific Code
# pc
# imex
callsc.f callsc.obj
imex.f imex.obj
imexx.f imexx.obj
inio.f inio.obj
innum.f innum.obj
qquit.f qquit.obj
resolve_link.f resolve_link.obj
cmgfile_mod.f cmgfile_mod.obj
cmgtar.f cmgtar.obj
datime.f datime.obj
getclk.f getclk.obj
header.f header.obj
rdline.f rdline.obj
sigcl1.f sigcl1.obj
sigft1.f sigft1.obj
siggst.f siggst.obj
jdump.f jdump.obj
solver.f solver.obj
parasol.f parasol.obj
srskip.f srskip.obj
srwpar.f srwpar.obj
insert_string.exe
mod_to_aloc.exe
  := PP_WIN32 = $N /DWIN32
# simver.obj just add's Win x64 as part of header
# callsc.obj has secure.inc in it
callsc.f callsc.obj
indynm.f indynm.obj
innum.f innum.obj
rdline.f rdline.obj
simver.f simver.obj
  := PP_WIN_X64 = $N /DWIN_X64
# intel ia32 fortran
callsc.f callsc.obj
cmg_sleep.f cmg_sleep.obj
cmgtar.f cmgtar.obj
getclk.f getclk.obj
getcpu.f getcpu.obj
gethost.f gethost.obj
imex.f imex.obj
procstat.f procstat.obj
qquit.f qquit.obj
rdline.f rdline.obj
sigcl1.f sigcl1.obj
sigft1.f sigft1.obj
siggst.f siggst.obj
simver.f simver.obj
srskip.f srskip.obj
srwpar.f srwpar.obj
insert_string.exe
mod_to_aloc.exe
  := PP_IFL_IA32 = $N /DIFL_IA32
#debug coupled version
#imex.obj
#  := PP_DD = $N /DDD
## openmp enabled version (special omp system calls)
indynm.f indynm.obj
innum.f innum.obj
preprp.f preprp.obj
genlup.f genlup.obj
  :=  PP_OPENMP_VER = $N /DOPENMP_VER
# /Qtcheck required in addition to /Qopenmp for thread checker plus,
#          for intermittent problem with system call omp_get_num_procs
#          add /DOPENMP_TCHECK to above (required by innum)
OMP_FLAGS            = /Qopenmp
#OMP_FLAGS           =
# disable security for ia32 tests
#callsc.obj
#rdline.obj
#  :=  PP_NO_SECURE = $N /DNO_SECURE
## disable xdr for tests
#inio.obj
#iniord.obj
#  :=  PP_NO_XDR    = $N /DNO_XDR
# to disable MKL if you do not have MKL installed - MKL is used for
# some diagnostics related to the block diagonal matrices in the
# Jacobian
#innum.obj
#jdump.obj
#  := PP_NO_MKL = $N /DNO_MKL
# new fortran (VF6.1) appears to allow F95 version for all win32 os's
# F95 standard call reports cpu time rather than elapsed time
# tested on US win95a,b, win98.1, nt4/sp4;CH win98, SP win98
getcpu.f getcpu.obj
  :=  PP_F95 = $N /DF95
## try real(16) for gmres dot products and key jbuild ops
## stab.obj - stab probably not needed
#avmulp.obj gmresp.obj jbuild.obj solver.obj
#  :=  PP_RPREC = $N /DREAL_16
# allow register use for full gmresp dot products (old default for 2002.10)
# use REAL_* for Intel fortran 8.1.019 - otherwise get wrong answers
# disable this for Intel Fortran 9.1.029 - no longer required
#  :=  PP_RPREC = $N /DREAL_8
#-- Accumulate all PP pre-processing directives
PP_1 = $(PP_CVF)$(PP_DD)$(PP_F95)$(PP_IFL_IA32)$(PP_OPENMP_VER)$(PP_WIN32)$(PP_NO_SECURE)
PP_2 = $(PP_NO_XDR)$(PP_NO_BINARRAY)$(PP_RPREC)$(PP_NO_MKL)$(PP_WIN_X64)
PP   = $(PP_1)$(PP_2)
# default to preprocessing .f files instead of copying them
COPY_PREPRO  = fpp /P$(PP)
#-- Compile Options
# /cm - disables comment reporting /CV causes problems if a scalar
#  rather than an array
# /Ap64 - enable 64 bit pointers
     PLATFORM_FLAGS = /Qauto /cm /nologo /w /MT
     RELEASE_FLAGS  = $(PLATFORM_FLAGS)
# for development/release toggle the two lines below plus toggle FFLAGS_XTRA
# blank for release and non-blank for debug
# /CB is allowed for Intel Fortran 8.0 - not for 7.1
# for 9.1 compiler: /check:uninit or /RTCu checks for unitialized variables at runtime - does not work with parallel so disable /Qopenmp and OPENMP_VER
#                   /check:bounds checks for subrange errors
#                   /Zi - supports parallel debugging
#                   /traceback required for traceback
# Thread checker does not support optimization (use /Od), thread profiler does support
# optimization, use /O2
# to set environment variables, run appropriate Intel compiler bat's followed by thcheckvars.bat "32e"
# for thread checker, tprofilevars.bat "32e" for thread profiler
# "32e" is required for x64 version, default is 32bit version
# If you want to pass these settings to Visual Studio, follow this from the same dos shell
# with devenv /useenv
# use /Zi /O2 with otherwise normal OpenMP version for Intel Performance Tuning Utility (PTU)
#    also need to build outside of clearcase
#    FFLAGS_XTRA     = /Zi /O2
#    FFLAGS_XTRA     = /Zi /Od
#    FFLAGS_XTRA     = /Zi /check:bounds /check:uninit /traceback
#    FFLAGS_XTRA     = /Zi /C /check:noarg_temp_created /Qvc10 /traceback /fpe:0
     FFLAGS_XTRA     =
     CFLAGS  = /nologo /MT /w /W0 /GX /O2 /I"$(VIEW)\shared\sr2.lib" /D"WIN64" /D"NDEBUG" /D"_WINDOWS" /D"_Windows" /D"PC" /D"IFL_IA32" /D"_PTRDIFF_T" /D"_SIZE_T_DEFINED" /D"_SIZE_T"
     FFLAGS  = $(PLATFORM_FLAGS) $(FFLAGS_XTRA) /Qfpp $(PP) $(OMP_FLAGS)
insert_string.exe:= FFLAGS  = $(PLATFORM_FLAGS) /4Yportlib /Qfpp $(PP)
mod_to_aloc.exe  := FFLAGS  = $(PLATFORM_FLAGS) /4Yportlib /Qfpp $(PP)
# Intel fortran 8.0.038 - stack overflow -fixed by moving local arrays from wmlypn to wmcom1_mod (was /STACK:2000000)
# /fixed:no required for Vtune, Thread Checker, Thread Profiler
# increases stack size required for Intel fortran 8.1.019 - default worked fine for 8.0.038
# if do not increase stack size for 8.1.019, then remote .bat (tpl) runs to Win2K AS has large number of
# runs ending in segmentation faults
# debug requires /EXPECTEDOUTPUTSIZE:100000000
# /Qopenmp_profile required instead of /Qopenmp for thread profiler
imex.exe        := LINK_FLAGS = $(PLATFORM_FLAGS) $(FFLAGS_XTRA) $(OMP_FLAGS) /4Yportlib
#imex.exe        := LINK_FLAGS = $(PLATFORM_FLAGS) $(FFLAGS_XTRA) /Qopenmp_profile /4Yportlib
imex.exe        := LINK_OUT   = /link /LARGEADDRESSAWARE /incremental:no /STACK:4000000 /out:
#imex.exe        := LINK_OUT   = /link /LARGEADDRESSAWARE /fixed:no /EXPECTEDOUTPUTSIZE:100000000 /STACK:4000000 /incremental:no /out:
# Workaround for Fortran/C++ 10.1.021 / 11.0.066 (windows) compiler problem
xdrint.obj
   := CFLAGS = /nologo /MT /w /W0 /GX /Zi /O1 /I"$(VIEW)\shared\sr2.lib" /D"WIN64" /D"NDEBUG" /D"_WINDOWS" /D"_Windows" /D"PC" /D"IFL_IA32" /D"_PTRDIFF_T" /D"_SIZE_T_DEFINED" /D"_SIZE_T"
#-- Portability library routines
getcpu.obj sigcl1.obj srskip.obj srwpar.obj
   := FFLAGS  = $(PLATFORM_FLAGS) $(FFLAGS_XTRA) /4Yportlib /Qfpp $(PP) $(OMP_FLAGS)
#-- Turn off vectorization for selected routines
gmresp.obj solver.obj tsio.obj
   := FFLAGS  = $(PLATFORM_FLAGS) $(FFLAGS_XTRA) /Qfpp $(PP) $(OMP_FLAGS) /Qvec-
************ end ***************
Please advise me how to update above compiler options. Thanks again.
Dingjun
dingjun_chencmgl_ca
Hi, James,
Thank you so much! I have added impimt.lib in the following LIBS and succeed to pass linking.
LIBS = mkl_intel_lp64.lib mkl_intel_thread.lib impimt.lib mkl_core.lib Wsock32.lib User32.lib shell32.lib Advapi32.lib Gdi32.lib
Have a good day
Dingjun
James_T_Intel
Hi Dingjun,
Add impimt.lib to the LIBS variable in this file.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
James_T_Intel
Hi Dingjun,
Good, I'm glad to hear it working now.
Sincerely,
James Tullos
