Intel® MPI Library
2301 Discussions
Issue when using intel MPI through my debugger (mdb)
tommmm
Background and summary of problem
I am the developer of a debugging tool called mdb (https://github.com/TomMelt/mdb?tab=readme-ov-file)
This tool is written in Python but it is essentially a wrapper around various debugging backends. It currently works with gdb, cuda-gdb and lldb.
I mostly use openMPI but I have collaborators that use intel oneapi MPI.
When I was testing my tool (mdb) with intel MPI I get a crash when I try to step over the initialization of MPI (when launched with intel MPI's mpirun). E.g.,
MPI_Init(NULL, NULL);
The error I get is:
0:      Continuing.
0:      [cli_0]: write_line error; fd=9 buf=:cmd=init pmi_version=1 pmi_subversion=1
0:      :
0:      system msg for write_line failure : Bad file descriptor
0:      [cli_0]: Unable to write to PMI_fd
0:      [cli_0]: write_line error; fd=9 buf=:cmd=get_appnum
0:      :
0:      Abort(1090831) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
0:      MPIR_Init_thread(176):
0:      MPID_Init(1439)......:
0:      MPIR_pmi_init(131)...: PMI_Get_appnum returned -1
0:      [cli_0]: write_line error; fd=9 buf=:cmd=abort exitcode=1090831
0:      :
0:
0:      Program received signal SIGSEGV, Segmentation fault.
0:      MPIR_Err_return_comm (comm_ptr=0x7ffff61f3a60 <_IO_stdfile_2_lock>, fcname=0x7fffffff3ff0 "system msg for write_line failure : Bad file descriptor\n", errcode=1090831) at ../../src/mpi/errhan/errutil.c:309
 For my debug wrapper to work it runs gdb as a subprocess. This seems to work when using openMPI but it fails for intel MPI. I have no idea why. Is there an env variable I could set to make it work?
This was using intel-oneapi-mpi install via spack with the following settings:
[email protected]+envmods~external-libfabric~generic-names~ilp64 build_system=generic
I am currently investigating it on my local laptop (running Ubuntu 22.04) but I have also tested on our local HPC cluster and it also doesn't work there.
Steps to re-create error:
Download and install mdb (optional but you may want to create a venv first):
git clone https://github.com/TomMelt/mdb.git
cd mdb
pip install -e .[termgraph]
Build sample c++ MPI binary:
cd examples
mpicxx -g -O0 -c  simple-mpi-cpp.cpp -o simple-mpi-cpp.o
From one terminal run the launcher:
mdb launch -n 2 -t simple-mpi-cpp.exe
It will output some text, something like:
running on host: 127.0.1.1
to connect to the debugger run:
mdb attach -h 127.0.1.1 -p 2000
connecting to debuggers ... (2/2)
all debug clients connected
In another terminal copy paste the mdb attach command:
You should then be able to step through the code, using the command "command n". This will send the next command ("n") to all processes. The output will look something like:
mdb - mpi debugger - built on various backends. Type ? for more info. To exit interactive mode type "q", "quit", "Ctrl+D" or "Ctrl+]".
(mdb 0-1) command n
0:      24        var = 0.;
1:      24        var = 0.;
(mdb 0-1)
0:      26        MPI_Init(NULL, NULL);
1:      26        MPI_Init(NULL, NULL);
(mdb 0-1)
0:      :
0:      :
0:      :
0:
0:      MPIR_Err_return_comm (comm_ptr=0x7ffff61f3a60 <_IO_stdfile_2_lock>, fcname=0x7fffffff3fd0 "system msg for write_line failure : Bad file descriptor\n", errcode=1090831) at ../../src/mpi/errhan/errutil.c:309
0:      309     ../../src/mpi/errhan/errutil.c: No such file or directory.
1:      [cli_1]: write_line error; fd=10 buf=:cmd=init pmi_version=1 pmi_subversion=1
1:      :
1:      system msg for write_line failure : Bad file descriptor
1:      [cli_1]: Unable to write to PMI_fd
1:      [cli_1]: write_line error; fd=10 buf=:cmd=get_appnum
1:      :
1:      Abort(1090831) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
1:      MPIR_Init_thread(176):
1:      MPID_Init(1439)......:
1:      MPIR_pmi_init(131)...: PMI_Get_appnum returned -1
1:      [cli_1]: write_line error; fd=10 buf=:cmd=abort exitcode=1090831
1:      :
1:
1:      Program received signal SIGSEGV, Segmentation fault.
1:      MPIR_Err_return_comm (comm_ptr=0x7ffff61f3a60 <_IO_stdfile_2_lock>, fcname=0x7fffffff3fd0 "system msg for write_line failure : Bad file descriptor\n", errcode=1090831) at ../../src/mpi/errhan/errutil.c:309
1:      309     ../../src/mpi/errhan/errutil.c: No such file or directory.
(mdb 0-1)
 Please let me know if you have any suggestions. Thanks for taking the time to read my query and let me know if I can provide any more information.
tommmm
FWIW, I also tried running with lldb as the backend and it fails too.
To test lldb use the following launch command instead of the one above.
mdb launch -n 2 -t simple-mpi-cpp.exe -b lldb
 I get a similar error:
$ mdb attach -h 127.0.1.1 -p 2000
(mdb 0-1) command n
0:      Process 85331 stopped
0:      * thread #1, name = 'simple-mpi-cpp.', stop reason = step over
0:          frame #0: 0x0000555555555368 simple-mpi-cpp.exe`main at simple-mpi-cpp.cpp:26:11
0:         23
0:         24     var = 0.;
0:         25
0:      -> 26     MPI_Init(NULL, NULL);
0:                        ^
0:         27     MPI_Comm_size(MPI_COMM_WORLD, &size_of_cluster);
0:         28     MPI_Comm_rank(MPI_COMM_WORLD, &process_rank);
0:         29
1:      Process 85332 stopped
1:      * thread #1, name = 'simple-mpi-cpp.', stop reason = step over
1:          frame #0: 0x0000555555555368 simple-mpi-cpp.exe`main at simple-mpi-cpp.cpp:26:11
1:         23
1:         24     var = 0.;
1:         25
1:      -> 26     MPI_Init(NULL, NULL);
1:                        ^
1:         27     MPI_Comm_size(MPI_COMM_WORLD, &size_of_cluster);
1:         28     MPI_Comm_rank(MPI_COMM_WORLD, &process_rank);
1:         29
(mdb 0-1)
0:      :
0:      :
0:      :
0:      * thread #1, name = 'simple-mpi-cpp.', stop reason = signal SIGSEGV: invalid address (fault address: 0x0)
0:          frame #0: 0x00007ffff6612be1 libmpi.so.12`MPIR_Err_return_comm(comm_ptr=0x00007ffff61f3a60, fcname="system msg for write_line failure : Bad file descriptor\n", errcode=1090831) at errutil.c:309
1:      :
1:      :
1:      :
1:      * thread #1, name = 'simple-mpi-cpp.', stop reason = signal SIGSEGV: invalid address (fault address: 0x0)
1:          frame #0: 0x00007ffff6612be1 libmpi.so.12`MPIR_Err_return_comm(comm_ptr=0x00007ffff61f3a60, fcname="system msg for write_line failure : Bad file descriptor\n", errcode=1090831) at errutil.c:309
tommmm
FYI, I decided to check mpich as well.
mpich initially had the same problem and it appears it is related to https://github.com/pmodels/mpich/issues/2063.
I managed to get mpich working by adding the flag "--pmi-port".
mpich now works, but I cannot find a similar flag for intel mpi. Do you have any ideas?
tommmm
Do you have any updates on this issue?
tommmm
Hello I tried the latest version of intel MPI (2021.16.0) and still no luck. Do you have any suggestions.
