Intel® MPI Library
MPI_Parallel
KaYi_T_
   When I run the VASP calculation software, the calculation job was "okay" during one day. After that, some jobs show the following error:
[[email protected]] HYD_pmcd_pmiserv_send_signal (./pm/pmiserv/pmiserv_cb.c:221): assert (!closed) failed
[[email protected]] ui_cmd_cb (./pm/pmiserv/pmiserv_pmci.c:128): unable to send SIGUSR1 downstream
[[email protected]] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
[[email protected]] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:388): error waiting for event
[[email protected]] main (./ui/mpich/mpiexec.c:745): process manager error waiting for completion
     IMPORTANT: sometimes some of jobs are finished without error. some of them cannot be completed with above error. What should I do?
Mark_L_Intel
Could you provide outputs of
which mpirun
env | grep I_MPI
then please compile this code $I_MPI_ROOT/test/test.c as
mpiicc -o test.x test.c
And then after setting I_MPI_DEBUG=5, you can run executable as, e.g.
mpirun -verbose -np 10 ./test.x
and then please provide output
Mark
