Intel® MPI Library
MPI bad termination due to STOP
Viet-Duc
We observed a peculiar behavior of Intel MPI with exit status emitted from STOP statement.
PROGRAM hello
    USE mpi
    IMPLICIT NONE
    INTEGER :: rank, size, ierror
    CALL MPI_INIT(ierror)
    CALL MPI_COMM_SIZE(MPI_COMM_WORLD, size, ierror)
    CALL MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierror)
    PRINT *, 'rank', rank, ': Hello, World!'
    CALL MPI_FINALIZE(ierror)
    STOP 2
END
The exit status will be utilized for quick debugging purpose in our codes.
With Intel MPI 2019 Update 4, we received bad termination errors, for instance using 2 MPI ranks:
 rank           1 : Hello, World!
 rank           0 : Hello, World!
2
2
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 0 PID 167623 RUNNING AT login03
=   EXIT STATUS: 2
=   RANK 1 PID 167624 RUNNING AT login03
=   EXIT STATUS: 2
This behavior was not observed with previous versions of the library. We are not sure whether this is a bug of IMPI or an intended feature.
Ideally, we are looking for a way to suppress this bad termination error.
Anatoliy_R_Intel
Please check 2019 Update 5.  As far as I know this issue was fixed there.
Best regards, Anatoliy
Anatoliy_R_Intel
Viet-Duc
Thanks for your reply.
We have confirmed that upgrading to Update 5 resolved this issue.
Anatoliy_R_Intel
Thank you!
