Intel® MPI Library
2300 Discussions
MPI_f08 with polymorphic argument CLASS(*)
hakostra1
New Contributor II
Over in the Fortran forum here I reported a bug last summer. It was originally about calling some MPI_f08 functions, but ifx gave compilation errors. @Steve_Lionel helped me boil it down to a code snippet that did not depend on MPI, the bug was fixed in version 2024.1 of the Intel Fortran compiler.
However, my original MPI code still does not compile. I have now boiled it down to the following example:
SUBROUTINE test(baz, dtype)
    USE MPI_f08
    IMPLICIT NONE (type, external)
    ! Subroutine arguments
    CLASS(*) :: baz
    TYPE(MPI_Datatype) :: dtype
    ! Local variables
    TYPE(MPI_Request) :: recvreq
    CALL MPI_Irecv(baz, 1, dtype, 0, 0, MPI_COMM_SELF, recvreq)
END SUBROUTINE test
Compiling this with mpiifx gives:
example-2.F90(12): error #8769: If the actual argument is unlimited polymorphic, the corresponding dummy argument must also be unlimited polymorphic.   [BAZ]
compilation aborted for example-2.F90 (code 1)
The version of the compiler and MPI library is:
$ mpiifx --version
ifx (IFX) 2024.1.0 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
$ mpirun --version
Intel(R) MPI Library for Linux* OS, Version 2021.12 Build 20240213 (id: 4f55822)
Copyright 2003-2024, Intel Corporation.
Since the compiler bug is apparently solved in the compiler version I use now, I wonder if there could be a bug somewhere in the MPI_f08 bindings? Please refer to the original post in the Fortran part of the forum for more information on the original problem.
Both GFortran + OpenMPI and NAG Fortran compiler + MPICH compile the above example code just fine without any errors or warnings.
Thanks in advance for all help.
TobiasK
@hakostra1
We will fix it with the next release.
In case you cannot modify the installation folder, you can of course just recompile the module files in a folder of your choice and add that folder to your compile / link line.
TobiasK
@hakostra1
we made some changes in the F08 bindings recently, let me check this.
TobiasK
@hakostra1
thanks for reporting this. Are you using Windows or Linux?
hakostra1
New Contributor II
Thanks for looking into this. I'm using Linux.
TobiasK
@hakostra1
for Linux please try (after setting up the oneapi 2024.1 environment)
cd $I_MPI_ROOT/opt/mpi/binding
tar -xf intel-mpi-binding-kit.tar.gz
cd f08
make MPI_INST=${I_MPI_ROOT} F90=ifx NAME=ifx
cd include/ifx
mkdir ${I_MPI_ROOT}/include/mpi/back
cp ${I_MPI_ROOT}/include/mpi/* ${I_MPI_ROOT}/include/mpi/back
cp * ${I_MPI_ROOT}/include/mpi/
and try your example again.
Best
Tobias
hakostra1
New Contributor II
Yes, the example compiles now. Thanks. I guess this means there is a problem with the included MPI_f08 module files, then?
Is there any plans to update/fix these in a future release? Because this is a quite tedious fix to apply to every computer and workstation where I want to compile my software. In many cases I do not even have the necessary privileges to conduct this fix...
Anyways, thanks for the help so far!
TobiasK
@hakostra1
hakostra1
New Contributor II
Great to hear it will be fixed! That makes life so much easier for everyone!
Thanks a lot for looking into this!
hakostra1
New Contributor II
For reference: I just tried the 2024.2 oneAPI packages that recently came out, and this problem does not appear to be solved in this release:
$ mpiifx example-2.F90
example-2.F90(13): error #8769: If the actual argument is unlimited polymorphic, the corresponding dummy argument must also be unlimited polymorphic.   [BAZ]
    CALL MPI_Irecv(baz, 1, dtype, 0, 0, MPI_COMM_SELF, recvreq, ierr)
$ mpiifx --version
ifx (IFX) 2024.2.0 20240602
$ mpirun --version
Intel(R) MPI Library for Linux* OS, Version 2021.13 Build 20240515 (id: df72937)
TobiasK
unfortunately, it was decided that backwards combability is more important than the fix for this problem, so the solution is still to rebuild the bindings with 2024.1 or newer to get rid of the fix.
hakostra1
New Contributor II
Ok, thanks for the info. Is there any timeline at all (e.g. 2025.x ???) for fixing this? Imho. this is a quite serious bug that severely limit the usability of the Intel MPI library for modern Fortran applications.
