Intel® MPI Library
MPI peformance snapshot
Pravesh_G_
Hello team,
I am using mps(mpi performance snapshot) for analyzing. I installed intel mpi 5.0.3, itac 9.0.3 and intel compiler 15.0.3. I have already created stats.txt and app_stat.txt files but when I am using mps command for analyzing these text files, I am facing issue:
mps command not found
Please suggest me..
Pravesh Goyal
Artem_R_Intel1
Hello Pravesh,
Please make sure that you have set all the necessary environments - see the MPI Performance Snapshot for Linux* OS User's Guide.
Pay attention that MPI Performance Snapshot tool is called 'mpi_perf_snapshot' in ITAC 9.0.3 (it has been renamed to 'mps' since ITAC 9.1).
Pravesh_G_
Hello sir,
I have set all environment varraiable but same problem persist.
source /gpfs1/opt/intel/parallel_studio_xe_2015_update3/itac/9.0.3.051/bin/mpi_perf_snapshot_vars.sh
source /gpfs1/opt/intel/parallel_studio_xe_2015_update3/impi/5.0.3.048/bin64/mpivars.sh
source /gpfs1/opt/intel/parallel_studio_xe_2015_update3/composer_xe_2015.3.187/bin/compilervars.sh intel64
Please suggest me.
Pravesh Goyal
Artem_R_Intel1
Hi Pravesh,
Could you please specify the whole command which causes the mentioned error "mps command not found"?
BTW I'd recommend to source the environment scripts in the same order as specified in the MPI Performance Snapshot for Linux* OS User's Guide.
Pravesh_G_
When I am using this command
mps ./stats.txt ./app_stat.txt
-bash: mps: command not found
I have already sourced the environment scripts in the same order as specified in the MPI Performance Snapshot for Linux* OS User's Guide but same problem persist.
Pravesh Goyal
Artem_R_Intel1
Could you please try to run:
$ mpi_perf_snapshot ./stats.txt ./app_stat.txt
The MPI Performance Snapshot tool is called 'mpi_perf_snapshot' in ITAC 9.0.3 (it has been renamed to 'mps' in ITAC 9.1).
Pravesh_G_
Problem is resolved now.
Thanks for your support.
Pravesh Goyal
