Dear all,
I have installed on a cluster intel mpi. I run ./sshconnectivity.exp machines.LINUX
on a cluster with on master and 3 nodes. using the following machines.LINUX
gotpeumet-node01
gotpeumet-node02
gotpeumet-node03
gotpeumet-node04
Than I installed mpi on all the nodes using the install.sh.
Everything went great...apparently
It's three days that I am trying to figure out what is going wrong, because if I run a simple code like testf90 (taken the test.f90 source) on one of the nodes it works perfectly, while if i try to run
mpirun -d -n 2 -machinefile ~/machine_file -genvall ./test/testf90
I get the following
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
testf90 000000000046FC79 Unknown Unknown Unknown
testf90 000000000046E5F0 Unknown Unknown Unknown
testf90 0000000000440282 Unknown Unknown Unknown
testf90 0000000000424D73 Unknown Unknown Unknown
testf90 0000000000403A4B Unknown Unknown Unknown
libpthread.so.0 0000003E1DA0F710 Unknown Unknown Unknown
libmpi.so.4 00007F310A7C612E Unknown Unknown Unknown
libmpi.so.4 00007F310A860B24 Unknown Unknown Unknown
libmpi.so.4 00007F310A85F035 Unknown Unknown Unknown
libmpi.so.4 00007F310A860847 Unknown Unknown Unknown
libmpi.so.4 00007F310A70FC90 Unknown Unknown Unknown
libmpi.so.4 00007F310A84F69D Unknown Unknown Unknown
libmpi.so.4 00007F310A825E7F Unknown Unknown Unknown
libmpi.so.4 00007F310A819D18 Unknown Unknown Unknown
libmpigf.so.4 00007F310ACE331F Unknown Unknown Unknown
testf90 000000000040307B Unknown Unknown Unknown
testf90 0000000000403036 Unknown Unknown Unknown
libc.so.6 0000003E1D61ED1D Unknown Unknown Unknown
testf90 0000000000402F29 Unknown Unknown Unknown
libpthread.so.0 000000301100F710 Unknown Unknown Unknown
libmpi.so.4 00007F0DC63D712E Unknown Unknown Unknown
libmpi.so.4 00007F0DC6471B24 Unknown Unknown Unknown
libmpi.so.4 00007F0DC6470035 Unknown Unknown Unknown
libmpi.so.4 00007F0DC6471847 Unknown Unknown Unknown
libmpi.so.4 00007F0DC6320C90 Unknown Unknown Unknown
libmpi.so.4 00007F0DC646069D Unknown Unknown Unknown
libmpi.so.4 00007F0DC6436E7F Unknown Unknown Unknown
libmpi.so.4 00007F0DC642AD18 Unknown Unknown Unknown
libmpigf.so.4 00007F0DC68F431F Unknown Unknown Unknown
libc.so.6 0000003010C1ED1D Unknown Unknown Unknown
while the -d option give me the following information:
host: gotpeumet-node01
host: gotpeumet-node02
host: gotpeumet-node03
host: gotpeumet-node04
mpiexec options:
  Base path: /opt/intel/impi/4.1.3.045/intel64/bin/
  Launcher: ssh
  Debug level: 1
  Enable X: -1
  Global environment:
    I_MPI_PERHOST=allcores
    LD_LIBRARY_PATH=/opt/intel/impi/4.1.3.045/intel64/lib:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64:/opt/intel/impi/4.1.3.045/intel64/lib:/opt/intel/impi/4.1.3.045/mic/lib
    MKLROOT=/opt/intel/composer_xe_2013_sp1.1.106/mkl
    MANPATH=/opt/intel/impi/4.1.3.045/man:/opt/intel/composer_xe_2013_sp1.1.106/man/en_US:/opt/intel/composer_xe_2013_sp1.1.106/man/en_US:/usr/local/share/man:/usr/share/man/overrides:/usr/share/man/en:/usr/share/man:
    HOSTNAME=gotpeumet-node01
    SELINUX_ROLE_REQUESTED=
    INTEL_LICENSE_FILE=/opt/intel/composer_xe_2013_sp1.1.106/licenses:/opt/intel/licenses:/home/giulio/intel/licenses
    SHELL=/bin/bash
    TERM=ansi
    HISTSIZE=1000
    SSH_CLIENT=169.143.244.115 24708 22
    GDBSERVER_MIC=/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/target/mic/bin/gdbserver
    LIBRARY_PATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64
    SELINUX_USE_CURRENT_RANGE=
    QTDIR=/usr/lib64/qt-3.3
    QTINC=/usr/lib64/qt-3.3/include
    SSH_TTY=/dev/pts/2
    MIC_LD_LIBRARY_PATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/mic
    USER=giulio
    LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.tbz=01;31:*.tbz2=01;31:*.bz=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:
    CPATH=/opt/intel/composer_xe_2013_sp1.1.106/mkl/include
    NLSPATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/share/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64/py26/share/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/intel64/locale/%l_%t/%N
    PATH=/opt/intel/impi/4.1.3.045/intel64/bin:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/bin:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64/py26/bin:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64_mic:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gui/intel64:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/dell/srvadmin/bin:/home/giulio/bin
    MAIL=/var/spool/mail/giulio
    PWD=/home/giulio
    IDB_HOME=/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64
    LANG=en_US.UTF-8
    GDB_CROSS=/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/bin/gdb-mic
    SELINUX_LEVEL_REQUESTED=
    HISTCONTROL=ignoredups
    HOME=/home/giulio
    SHLVL=2
    LOGNAME=giulio
    CVS_RSH=ssh
    QTLIB=/usr/lib64/qt-3.3/lib
    LC_CTYPE=UTF-8
    SSH_CONNECTION=169.143.244.115 24708 10.67.135.11 22
    LESSOPEN=|/usr/bin/lesspipe.sh %s
    INCLUDE=/opt/intel/composer_xe_2013_sp1.1.106/mkl/include
    G_BROKEN_FILENAMES=1
    I_MPI_ROOT=/opt/intel/impi/4.1.3.045
    _=/opt/intel/impi/4.1.3.045/intel64/bin/mpiexec.hydra
  Hydra internal environment:
    MPICH_ENABLE_CKPOINT=1
    GFORTRAN_UNBUFFERED_PRECONNECTED=y
    Proxy information:
      [1] proxy: gotpeumet-node01 (1 cores)
      Exec list: ./test/testf90 (1 processes);
      [2] proxy: gotpeumet-node02 (1 cores)
[mpiexec@gotpeumet-node01] Timeout set to -1 (-1 means infinite)
[mpiexec@gotpeumet-node01] Got a control port string of gotpeumet-node01:40839
Proxy launch args: /opt/intel/impi/4.1.3.045/intel64/bin/pmi_proxy --control-port gotpeumet-node01:40839 --debug --pmi-connect lazy-cache --pmi-aggregate -s 0 --rmk slurm --launcher ssh --demux poll --pgid 0 --enable-stdin 1 --retries 10 --control-code 2011340091 --proxy-id
[mpiexec@gotpeumet-node01] PMI FD: (null); PMI PORT: (null); PMI ID/RANK: -1
Arguments being passed to proxy 0:
--version 1.4.1p1 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname gotpeumet-node01 --global-core-map 0,1,1 --filler-process-map 0,1,1 --global-process-count 2 --auto-cleanup 1 --pmi-rank -1 --pmi-kvsname kvs_27468_0 --pmi-process-mapping (vector,(0,4,1)) --topolib ipl --ckpointlib blcr --ckpoint-prefix /tmp --ckpoint-preserve 1 --ckpoint off --ckpoint-num -1 --global-inherited-env 42 'I_MPI_PERHOST=allcores' 'LD_LIBRARY_PATH=/opt/intel/impi/4.1.3.045/intel64/lib:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64:/opt/intel/impi/4.1.3.045/intel64/lib:/opt/intel/impi/4.1.3.045/mic/lib' 'MKLROOT=/opt/intel/composer_xe_2013_sp1.1.106/mkl' 'MANPATH=/opt/intel/impi/4.1.3.045/man:/opt/intel/composer_xe_2013_sp1.1.106/man/en_US:/opt/intel/composer_xe_2013_sp1.1.106/man/en_US:/usr/local/share/man:/usr/share/man/overrides:/usr/share/man/en:/usr/share/man:' 'HOSTNAME=gotpeumet-node01' 'SELINUX_ROLE_REQUESTED=' 'INTEL_LICENSE_FILE=/opt/intel/composer_xe_2013_sp1.1.106/licenses:/opt/intel/licenses:/home/giulio/intel/licenses' 'SHELL=/bin/bash' 'TERM=ansi' 'HISTSIZE=1000' 'SSH_CLIENT=169.143.244.115 24708 22' 'GDBSERVER_MIC=/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/target/mic/bin/gdbserver' 'LIBRARY_PATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64' 'SELINUX_USE_CURRENT_RANGE=' 'QTDIR=/usr/lib64/qt-3.3' 'QTINC=/usr/lib64/qt-3.3/include' 'SSH_TTY=/dev/pts/2' 'MIC_LD_LIBRARY_PATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/mic' 'USER=giulio' 'LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.tbz=01;31:*.tbz2=01;31:*.bz=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:' 'CPATH=/opt/intel/composer_xe_2013_sp1.1.106/mkl/include' 'NLSPATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/share/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64/py26/share/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/intel64/locale/%l_%t/%N' 'PATH=/opt/intel/impi/4.1.3.045/intel64/bin:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/bin:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64/py26/bin:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64_mic:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gui/intel64:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/dell/srvadmin/bin:/home/giulio/bin' 'MAIL=/var/spool/mail/giulio' 'PWD=/home/giulio' 'IDB_HOME=/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64' 'LANG=en_US.UTF-8' 'GDB_CROSS=/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/bin/gdb-mic' 'SELINUX_LEVEL_REQUESTED=' 'HISTCONTROL=ignoredups' 'HOME=/home/giulio' 'SHLVL=2' 'LOGNAME=giulio' 'CVS_RSH=ssh' 'QTLIB=/usr/lib64/qt-3.3/lib' 'LC_CTYPE=UTF-8' 'SSH_CONNECTION=169.143.244.115 24708 10.67.135.11 22' 'LESSOPEN=|/usr/bin/lesspipe.sh %s' 'INCLUDE=/opt/intel/composer_xe_2013_sp1.1.106/mkl/include' 'G_BROKEN_FILENAMES=1' 'I_MPI_ROOT=/opt/intel/impi/4.1.3.045' '_=/opt/intel/impi/4.1.3.045/intel64/bin/mpiexec.hydra' --global-user-env 0 --global-system-env 2 'MPICH_ENABLE_CKPOINT=1' 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --genv-prop all --proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 1 --exec-local-env 0 --exec-wdir /home/giulio --exec-args 1 ./test/testf90
Arguments being passed to proxy 1:
--version 1.4.1p1 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname gotpeumet-node02 --global-core-map 1,1,0 --filler-process-map 1,1,0 --global-process-count 2 --auto-cleanup 1 --pmi-rank -1 --pmi-kvsname kvs_27468_0 --pmi-process-mapping (vector,(0,4,1)) --topolib ipl --ckpointlib blcr --ckpoint-prefix /tmp --ckpoint-preserve 1 --ckpoint off --ckpoint-num -1 --global-inherited-env 42 'I_MPI_PERHOST=allcores' 'LD_LIBRARY_PATH=/opt/intel/impi/4.1.3.045/intel64/lib:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64:/opt/intel/impi/4.1.3.045/intel64/lib:/opt/intel/impi/4.1.3.045/mic/lib' 'MKLROOT=/opt/intel/composer_xe_2013_sp1.1.106/mkl' 'MANPATH=/opt/intel/impi/4.1.3.045/man:/opt/intel/composer_xe_2013_sp1.1.106/man/en_US:/opt/intel/composer_xe_2013_sp1.1.106/man/en_US:/usr/local/share/man:/usr/share/man/overrides:/usr/share/man/en:/usr/share/man:' 'HOSTNAME=gotpeumet-node01' 'SELINUX_ROLE_REQUESTED=' 'INTEL_LICENSE_FILE=/opt/intel/composer_xe_2013_sp1.1.106/licenses:/opt/intel/licenses:/home/giulio/intel/licenses' 'SHELL=/bin/bash' 'TERM=ansi' 'HISTSIZE=1000' 'SSH_CLIENT=169.143.244.115 24708 22' 'GDBSERVER_MIC=/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/target/mic/bin/gdbserver' 'LIBRARY_PATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64' 'SELINUX_USE_CURRENT_RANGE=' 'QTDIR=/usr/lib64/qt-3.3' 'QTINC=/usr/lib64/qt-3.3/include' 'SSH_TTY=/dev/pts/2' 'MIC_LD_LIBRARY_PATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/mic' 'USER=giulio' 'LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.tbz=01;31:*.tbz2=01;31:*.bz=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:' 'CPATH=/opt/intel/composer_xe_2013_sp1.1.106/mkl/include' 'NLSPATH=/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/share/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64/py26/share/locale/%l_%t/%N:/opt/intel/composer_xe_2013_sp1.1.106/debugger/intel64/locale/%l_%t/%N' 'PATH=/opt/intel/impi/4.1.3.045/intel64/bin:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/mpirt/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/bin:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64/py26/bin:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64:/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64_mic:/opt/intel/composer_xe_2013_sp1.1.106/debugger/gui/intel64:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/dell/srvadmin/bin:/home/giulio/bin' 'MAIL=/var/spool/mail/giulio' 'PWD=/home/giulio' 'IDB_HOME=/opt/intel/composer_xe_2013_sp1.1.106/bin/intel64' 'LANG=en_US.UTF-8' 'GDB_CROSS=/opt/intel/composer_xe_2013_sp1.1.106/debugger/gdb/intel64_mic/py26/bin/gdb-mic' 'SELINUX_LEVEL_REQUESTED=' 'HISTCONTROL=ignoredups' 'HOME=/home/giulio' 'SHLVL=2' 'LOGNAME=giulio' 'CVS_RSH=ssh' 'QTLIB=/usr/lib64/qt-3.3/lib' 'LC_CTYPE=UTF-8' 'SSH_CONNECTION=169.143.244.115 24708 10.67.135.11 22' 'LESSOPEN=|/usr/bin/lesspipe.sh %s' 'INCLUDE=/opt/intel/composer_xe_2013_sp1.1.106/mkl/include' 'G_BROKEN_FILENAMES=1' 'I_MPI_ROOT=/opt/intel/impi/4.1.3.045' '_=/opt/intel/impi/4.1.3.045/intel64/bin/mpiexec.hydra' --global-user-env 0 --global-system-env 2 'MPICH_ENABLE_CKPOINT=1' 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --genv-prop all --proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 1 --exec-local-env 0 --exec-wdir /home/giulio --exec-args 1 ./test/testf90
[mpiexec@gotpeumet-node01] Launch arguments: /opt/intel/impi/4.1.3.045/intel64/bin/pmi_proxy --control-port gotpeumet-node01:40839 --debug --pmi-connect lazy-cache --pmi-aggregate -s 0 --rmk slurm --launcher ssh --demux poll --pgid 0 --enable-stdin 1 --retries 10 --control-code 2011340091 --proxy-id 0
[mpiexec@gotpeumet-node01] Launch arguments: /usr/bin/ssh -x -q gotpeumet-node02 /opt/intel/impi/4.1.3.045/intel64/bin/pmi_proxy --control-port gotpeumet-node01:40839 --debug --pmi-connect lazy-cache --pmi-aggregate -s 0 --rmk slurm --launcher ssh --demux poll --pgid 0 --enable-stdin 1 --retries 10 --control-code 2011340091 --proxy-id 1
[mpiexec@gotpeumet-node01] STDIN will be redirected to 1 fd(s): 9
[proxy:0:0@gotpeumet-node01] Start PMI_proxy 0
[proxy:0:0@gotpeumet-node01] STDIN will be redirected to 1 fd(s): 15
[proxy:0:0@gotpeumet-node01] got pmi command (from 10): init
pmi_version=1 pmi_subversion=1
[proxy:0:0@gotpeumet-node01] PMI response: cmd=response_to_init pmi_version=1 pmi_subversion=1 rc=0
[proxy:0:0@gotpeumet-node01] got pmi command (from 10): get_maxes
[proxy:0:0@gotpeumet-node01] PMI response: cmd=maxes kvsname_max=256 keylen_max=64 vallen_max=1024
[proxy:0:0@gotpeumet-node01] got pmi command (from 10): barrier_in
[mpiexec@gotpeumet-node01] [pgid: 0] got PMI command: cmd=barrier_in
[proxy:0:0@gotpeumet-node01] forwarding command (cmd=barrier_in) upstream
[proxy:0:1@gotpeumet-node02] Start PMI_proxy 1
[proxy:0:1@gotpeumet-node02] got pmi command (from 6): init
[proxy:0:1@gotpeumet-node02] PMI response: cmd=response_to_init pmi_version=1 pmi_subversion=1 rc=0
[proxy:0:1@gotpeumet-node02] got pmi command (from 6): get_maxes
[proxy:0:1@gotpeumet-node02] PMI response: cmd=maxes kvsname_max=256 keylen_max=64 vallen_max=1024
[mpiexec@gotpeumet-node01] PMI response to fd 6 pid 6: cmd=barrier_out
[mpiexec@gotpeumet-node01] PMI response to fd 7 pid 6: cmd=barrier_out
[proxy:0:1@gotpeumet-node02] got pmi command (from 6): barrier_in
[proxy:0:1@gotpeumet-node02] forwarding command (cmd=barrier_in) upstream
[proxy:0:0@gotpeumet-node01] PMI response: cmd=barrier_out
[proxy:0:0@gotpeumet-node01] got pmi command (from 10): get_ranks2hosts
[proxy:0:0@gotpeumet-node01] PMI response: put_ranks2hosts 48 2
16 gotpeumet-node01 0, 16 gotpeumet-node02 1,
[proxy:0:1@gotpeumet-node02] PMI response: cmd=barrier_out
[proxy:0:0@gotpeumet-node01] got pmi command (from 10): get_appnum
[proxy:0:0@gotpeumet-node01] PMI response: cmd=appnum appnum=0
[proxy:0:1@gotpeumet-node02] got pmi command (from 6): get_ranks2hosts
[proxy:0:0@gotpeumet-node01] got pmi command (from 10): get_my_kvsname
[proxy:0:0@gotpeumet-node01] PMI response: cmd=my_kvsname kvsname=kvs_27468_0
[proxy:0:1@gotpeumet-node02] PMI response: put_ranks2hosts 48 2
[proxy:0:1@gotpeumet-node02] got pmi command (from 6): get_appnum
[proxy:0:1@gotpeumet-node02] PMI response: cmd=appnum appnum=0
[proxy:0:1@gotpeumet-node02] got pmi command (from 6): get_my_kvsname
[proxy:0:1@gotpeumet-node02] PMI response: cmd=my_kvsname kvsname=kvs_27468_0
Can you please help me in understanding why i am getting always segmentation fault to run a very simple code that just tests the system?
thanks
What is the output from the following commands?
[plain]which mpirun
ldd ./test/testf90
env | grep I_MPI[/plain]
