Intel® MPI Library
2302 Discussions
Nested MPI process failed with GetParentPort error
CALUGARU_D_
we are trying to execute a tricky code with intel mpi 5.0.2.044.
We have a main program executed via
mpirun -n 1 Exec_main
This main program makes system call to an external shell script that does
mpirun -genv I_MPI_DEBUG 5 -n 4 ExecSub
When executing the external shell manually, everything is fine.
When launching the shell from the main executable, we have the following error :
[0] MPI startup(): Multi-threaded optimized library
[2] MPI startup(): shm and tcp data transfer modes
[3] MPI startup(): shm and tcp data transfer modes
[0] MPI startup(): shm and tcp data transfer modes
[1] MPI startup(): shm and tcp data transfer modes
Fatal error in PMPI_Init_thread: Other MPI error, error stack:
MPIR_Init_thread(784).......:
MPID_Init(1452).............: spawn process group was unable to obtain parent port name from the channel
MPIDI_CH3_GetParentPort(369):  PMI2 KVS_Get failed: -1
Do you have any clue on how to understand and solve this issue ?
Best regards
Dmitry_S_Intel
Version 5.0.2 is pretty old, can you try with released 2017 Update 2.
Dmitry
