Intel® MPI Library
2302 Discussions
OneAPI compilers cannot find MPI libraries
Fernandez__Arturo
I'm trying to test the new oneAPI version but even simple compilations produce errors. The installation includes BaseKit & HPCKit, and everything looks fine once completed. However, compiling even a simple HelloWorld code with mpicc (installed at /opt/intel/oneapi/mpi/2021.1-beta10/bin) returns:
/usr/bin/ld: cannot find -lmpifort
collect2: error: ld returned 1 exit status
However, at least the first library is there:
ldconfig -p | grep libmpi
libmpijava.so.1 (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpijava.so.1
libmpijava.so (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpijava.so
libmpifort.so.12 (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpifort.so.12
libmpifort.so (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpifort.so
libmpicxx.so.12 (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpicxx.so.12
libmpicxx.so (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpicxx.so
libmpi_shm_heap_proxy.so (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/libmpi_shm_heap_proxy.so
The system is running Ubuntu 20.04 and oneAPI was built with gnu 9.3.0. The error doesn't make sense to me so either something is wrong or I'm missing something (probably the latter).
GouthamK_Intel
As mentioned by you, we can see that you are running on Ubuntu 20.04. But as per the oneAPI HPC toolkit system requirements documentation currently Ubuntu* 18.04.3 LTS is the supported Target OS in Ubuntu.
Please refer the below link for more information about the System requirements for oneAPI HPC Toolkit.
https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-hpc-toolkit-system-requirements.html
However, Could you please let us know whether you have sourced the setvars.sh script file before running the code?
If not, please source the setvars.sh file located at /opt/opt/intel/oneapi/mpi/2021.1-beta10/ and run the sample code.
If you still face the issue could you please try reinstalling the HPCkit and try running the code again?
Please refer the below guides for more information
Installation guide:
https://software.intel.com/content/www/us/en/develop/articles/installation-guide-for-intel-oneapi-toolkits.html
Get Started with the Intel® oneAPI HPC Toolkit:
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-hpc-linux/top.html
Have a Good day!
Goutham
GouthamK_Intel
Installation guide:
Have a Good day!
Goutham
Fernandez__Arturo
Hi Goutham,
Sourcing setvars.sh partially solves the problem. [In the documentation, this step is not discussed until the FPGA section, not during the general installation; however, it is mentioned in the requirement guide and it could also be that the script said something that I didn't pay attention to, cannot recall]. Anyway, I was able to compile a simple code but building larger apps fails at linking. The message is /usr/bin/ld: cannot find -lmpi. I manually expanded the linking options to include libmpi so that the system now sees:
libmpi_ilp64.so.4.1 (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/release/libmpi_ilp64.so.4.1
libmpi_ilp64.so.4 (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/release/libmpi_ilp64.so.4
libmpi_ilp64.so (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/release/libmpi_ilp64.so
libmpi.so.12 (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/release/libmpi.so.12
libmpi.so (libc6,x86-64) => /opt/intel/oneapi/mpi/2021.1-beta10/lib/release/libmpi.so
So the library is there but the compiler just cannot use it (similarly to what was happening with libmpifort yesterday). My understanding is that to configure the system, IntelMPI sometimes requires to source $.<installdir>/bin64/mpivars.sh [option] but this script is not in the distribution. The closest thing is /opt/intel/oneapi/mpi/2021.1-beta10/env/vars.sh but sourcing it didn't make any difference.
Arturo
Fernandez__Arturo
Jervie
I also met this error although I sourced setvars.sh file. I solved this by adding
export MPIPATH=/oneapi/mpi/2021.2.0
export PATH=$MPIPATH/bin:$PATH
export LD_LIBRARY_PATH=$MPIPATH/lib:$LD_LIBRARY_PATH
GouthamK_Intel
Glad to know that your issue is resolved!
Thanks for the confirmation.
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Goutham
