Intel® MPI Library
Oneapi compability issue
hikaruseven
Dear Developer and Users,
I used the intel compiler for the mpi implementation in the SERPENT2 parallel
calculation. However, per 2021 the whole intel compiler is integrated into
one single software, which is called oneapi. Since then, whenever i tried to
do the serpent2 calculation with multiple nodes in my cluster the calculation
will be stopped and error at sharing input to the mpi task. While it work properly
with one node.
Have you guys ever experience this issue and would possibly offer some
solution?
Thank you So much for the help
SantoshY_Intel
Could you please share with us the OS details along with the result of the below command:
mpirun --version
Can you specify whether the application consists of C or Fortran-specific MPI code?
Could you please try using "verbs" as libfabric provider as mentioned below before running the serpent 2 calculation & share with us the complete log by keeping I_MPI_DEBUG=10?
export I_MPI_OFI_PROVIDER=verbs
Thanks & Regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Is your issue resolved? If not, Could you please respond to the questions asked in the previous post?
Thanks & Regards,
Santosh
SantoshY_Intel
As we have not heard back from you, we are considering that your issue has been resolved. So we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Santosh
