Intel® MPI Library
2299 Discussions
OpenMP target data to intel GPU segmentation fault when array too large
Sylvain
When testing offload computation to intel GPU with OpenMP, I obtain a segmentation fault at execution with this code :
int main()
    const int N=350000;
    double a;
    double b;
    double c;
//    double *a = new double;
//    double *b = new double;
//    double *c = new double;
    for (int i=0; i<N; i++) {
        a = i;
        b = 1./i;
    #pragma omp target data map(to:a,b) map(from:c)
//    #pragma omp target data map(to:a[0:N],b[0:N]) map(from:c[0:N])
    #pragma omp target teams distribute parallel for simd
        c = a+b;
//    delete[] a;
//    delete[] b;
//    delete[] c;
    return 0;
The error does not happen if I take N=300000 or if I use pointers instead of arrays (use of commented lines). With pointers it works even with N=100000000 (not tested above).
When looking with gdb, segmentation fault happens at line 12, but I cannot access exact value i, even with -O0.
My configuration :
  •     Gentoo Linux
  •     CPU i5-7300U with HD Graphics 620
  •     oneAPI HPC Toolkit 2021.1 beta06
  •     neo-20.16.16582
  •     intel-graphics-compiler-1.0.3826
  •     level-zero-0.91.10
  •     I used "-qnextgen -fiopenmp -fopenmp-targets=spir64" for compilation
Sylvain
AbhishekD_Intel
Hi Sylvain,
We tried the code given by you and it is not giving segfault if I take N=300000. But we observe segfault if we take N>500000, and it is oblivious as it is exceeding maximum stack size for us. Whereas for the pointer (commented part of your code) it will work without segfault for N=100000000 as it is using heap instead of the stack.
If you want to check the stack size you can use ulimit -a command and you will get the reason for segfault.
If you use gdb you will definitely get a segfault on line 12(of your code) but if you try something like below code snippet :
    const int N=600000;
    double a;
    double b;
//    double c;
        a = i;
        b = 1./i;
    std::cout<<"here\n";
    double c;
In the above case, we will see that you will get segfault after "std::cout" as stack size is exceeding after std::cout statement.
So if you have a requirement of large size array then we will recommend you use dynamic memory allocation instead of using stack.
I hope this helps. Do let us know if your issue is resolved.
Warm Regards,
Abhishek
AbhishekD_Intel
Hi Sylvain,
    const int N=600000;
    double a;
    double b;
//    double c;
        a = i;
        b = 1./i;
    double c;
Warm Regards,
Abhishek
Sylvain
Thank you for your answer, I understand it is a limitation of the system. I am learning new things. Nothing to do with GPU computing and oneAPI HPC Toolkit then. Best regards, Sylvain
AbhishekD_Intel
Hi Sylvain,
Please confirm if your issue has been resolved so that we can close the thread.
You can always post a new thread if you face any issue.
Warm Regards,
Abhishek
Sylvain
Yes, it solves the problem, thank you
AbhishekD_Intel
Thank you Sylvain for the conformation we are closing this thread.
Warm Regards,
Abhishek
