Intel® MPI Library
2287 Discussions
Openmpi 1.10.3 and Intel parallel studio XE
Stepha_France
or is the error in my installation Intel parallel studio XE and of openmpi.
I install intel parallel studio XE cluster édition 16 under ubuntu 14.04 32bit
export LD_LIBRARY_ PATH= ''/opt/intel/lib ''
export DYLD_LIBRARY_ PATH= ''/opt/intel/lib ''
export MANPATH= ''/opt/intel/man''
export PATH= /opt/intel/bin:$PATH
I added in .bashrc export PATH=$PATH : /opt/intel/bin
can I install openmpi 1.10.3
with sudo ./configure - -prefix=/home/math/openmpi F77=/opt/intel/compilers_and_libraries_2016.3.210/linux/bin/ia32/ifort FC=/opt/intel/compilers_and_libraries_2016.3 .210/linux/bin/ia32/ifort
then sudo make all and sudo make install
export PATH=$PATH:/home/math/openmpi/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/math/openmpi/bin
I also added these two lines in the file .bashrc
 but when compiling a program in FORTRAN I have my errors:
ld: warning: libifport.so.5, needed by /openmpi/lib/libmpi_usempif08.so, not found (try using -rpath or -rpath-link)
ld: warning: libifcore.so.5, needed by /openmpi/lib/libmpi_usempif08.so, not found (try using -rpath or -rpath-link)
ld: warning: libimf.so, needed by /openmpi/lib/libmpi_usempif08.so, not found (try using -rpath or -rpath-link)
ld: warning: libsvml.so, needed by /openmpi/lib/libmpi_usempif08.so, not found (try using -rpath or -rpath-link)
ld: warning: libifcoremt.so.5, needed by /openmpi/lib/libmpi_usempif08.so, not found (try using -rpath or -rpath-link)
Thanks in advance for your help
Stepha_France
the problem is solved:
export LD_LIBRARY_ PATH= ''/opt/intel/lib/ia32 ''
