Intel® MPI Library
Performance Comparasons between 2 multi-core computers
dingjun_chencmgl_ca
HI, All,
I have tested a software product IMEX 2012.10 on two muti-core computers and the performance are surprise to me. Please see below:
1. the 1st Computer:
Processor: Intel(R) Xeon(R)CPU X5680 @ 3.33GHz 3.33GHz(2 processors)
Installed memory(RAM): 48.0 GB
System type: 64-bit OS
2. the 2nd computer:
Processor: Intel(R) Xeon(R)CPU X7560 @ 2.27GHz 2.26GHz(4 processors)
Installed memory(RAM): 256.0 GB
The test results are given below:
Elapsed Time:  27733.59 seconds (OpenMP parallel IMEX 2012.10 running on the 2nd computer with 32 cores)
Elapsed Time:  23831.27 seconds (OpenMP parallel IMEX 2012 .10 running on the 1st computer  with 12 cores)
Could someone give me some advices on how to improve the performance on the 2nd computer with 32 cores? what caused the differences?  I am surprise there is such a big difference in performance between these 2 computers.  Thanks inadvance.
Dingjun
TimP
You don't provide enough information to guess how your question might be topical on this forum. As no one has answered, I'll jump in and point out that multi-core software becomes more dependent on affinity settings as the number of CPUs increase. If your application doesn't scale beyond 2 CPUs (not an unusual situation) it will not be entirely surprising if CPU clock speed is important.
