Hi, I found that the performance difference is significant when running
I_MPI_DEBUG=1 mpirun -PSM2 -host node1 -n 1 ./IMB-MPI1 Sendrecv : -host node2 -n 1 ./IMB-MPI1
#bytes #repetitions t_min[usec] t_max[usec] t_avg[usec] Mbytes/sec
4194304 10 364.40 364.52 364.46 23012.87
and
I_MPI_DEBUG=1 mpirun -OFI -host node1 -n 1 ./IMB-MPI1 Sendrecv : -host node2 -n 1 ./IMB-MPI1
4194304 10 487.40 487.80 487.60 17196.66
Output of the latter seems to indicate that it uses psm2 backend too.
[0] MPID_nem_ofi_init(): used OFI provider: psm2 [0] MPID_nem_ofi_init(): max_buffered_send 64 [0] MPID_nem_ofi_init(): max_msg_size 64 [0] MPID_nem_ofi_init(): rcd switchover 32768 [0] MPID_nem_ofi_init(): cq entries count 8 [0] MPID_nem_ofi_init(): MPID_REQUEST_PREALLOC 128 #------------------------------------------------------------ # Intel (R) MPI Benchmarks 2018 Update 1, MPI-1 part #------------------------------------------------------------ # Date : Tue Sep 10 17:36:59 2019 # Machine : x86_64 # System : Linux # Release : 4.4.175-89-default # Version : #1 SMP Thu Feb 21 16:05:09 UTC 2019 (585633c) # MPI Version : 3.1 # MPI Thread Environment: .......
It's getting more wired when I run with I_MPI_FABRICS set, I get only an error.
I_MPI_DEBUG=1 I_MPI_FABRICS=shm,psm2 mpirun -host node81 -n 1 ./IMB-MPI1 Sendrecv : -host node82 -n 1 ./IMB-MPI1 [1] MPI startup: syntax error in intranode path of I_MPI_FABRICS = shm,psm2 and fallback is disabled, allowed value(s) shm,ofi,tmi,dapl,ofa,tcp [0] MPI startup: syntax error in intranode path of I_MPI_FABRICS = shm,psm2 and fallback is disabled, allowed value(s) shm,ofi,tmi,dapl,ofa,tcp
Is the performance difference expected results? If so, can I make mpirun defaults to use -PSM2 by changing environment or configurations? (except aliasing mpirun to "mpirun -PSM2" of course)
