Intel® MPI Library
2280 Discussions
Please help me for th MPI problem(delayed start of the pmi_proxy process)
YoungWoong_K_
Hi, HPC Developers
S/W Enviroment Setting :
 CentOS 6.6 x64
 Intel® Parallel Studio XE 2015
 Intel MPI Library 5.0.3
 NFS share
In the following cases, operate normally.
1. If you run mpirun from the Terminal Console
2. If you perform a bash mpirun to child processes in a single-threaded program
3. If you perform a bash mpirun in the child process via a Thread in multi-threaded program
However, the operation is delayed in the following cases:
If you perform a bash mpirun in the child process at TCP service hosting program
Attach a reference document to help you understand the above.
Ask for advice on troubleshooting.
Dmitry_S_Intel
Can you make sure that the problem with pmi_proxy - try to run another bash script with just
echo "Test"
instead of mpirun. Is the delay here?
Dmitry
