Intel® MPI Library
2301 Discussions
Problem calling MPI with GPU arrays (use_device_ptr, use_device_addr)
caplanr
New Contributor II
I am trying to compile and run our code (github.com/predsci/pot3d) on Stampede3 on the MAX 1550 GPUs.
The code uses "GPU-aware" MPI calls using OpenMP target's "use_device_ptr()".
(This works with the NVIDIA compiler with the HPC-X MPI library across NVIDA GPUs).
On the Intel GPUs, I am getting a seg fault at the MPI calls.
The compiler mentions that the "use_device_ptr()" can only be used with C pointers in Fortran, so I switched them to "use_device_addr()", but that also seg faults.
Are GPU-aware MPI calls supported in ifx+impi (I am using 2025.0.0)?
If so, what do I need to do to get it to work?
Can you clarify the difference between use_device_ptr() and use_device_addr()?
From here, it seems the difference is not clear?
https://forums.developer.nvidia.com/t/omp-target-data-use-device-ptr-vs-use-device-addr/290317
Thanks!
 - Ron
Labels (2)
TobiasK
@caplanr when passing GPU pointer to Intel MPI you have to set
export I_MPI_OFFLOAD=1
before running the application
TobiasK
caplanr
New Contributor II
Thanks!
It is now working!
Another tip for someone with the same issue:
I also had to set:
export LIBOMPTARGET_DEVICES=SUBDEVICE
in order for the MPI to see all 8 tiles of the 4 MAX 1550 GPUs.
The default was only seeing 1 GPU device (on Stampede3).
 - Ron
