Intel® MPI Library
2300 Discussions
Problem with IntelIB-Basic, Intel MPI and I_MPI_FABRICS=tmi
Guillaume_De_Nayer
We have a small cluster (head node + 4 nodes with 16 cores) using Intel infiniband. This cluster is under CentOS 6.6 (with the kernel of CentOS 6.5).
On this cluster Intel Parallel Studio XE 2015 is installed. I_MPI_FABRICS is set per default to "tmi" only.
When I start a job (using torque+maui) on several nodes, for example this one:
#!/bin/bash
#PBS -N IMB-MPI1_intelmpi
#PBS -l walltime=2:00:00
#PBS -l nodes=3:ppn=4
cd $PBS_O_WORKDIR
export I_MPI_FABRICS=tmi
mpirun IMB-MPI1
The job is running fine without any problem.
Now I start a job on a node:
#!/bin/bash
#PBS -l nodes=1:ppn=16
cd $PBS_O_WORKDIR
mpirun IMB-MPI1
This job does not start and I get this message:
can't open /dev/ipath, network down
tmi fabric is not available and fallback fabric is not enabled
Is it normal?
If I set as default I_MPI_FABRICS=dapl, I don't have this problem at all.
How can I solve that?
Guillaume
Guillaume_De_Nayer
If I set export I_MPI_FABRICS=tmi:tmi the problem appear too.
If I set export I_MPI_FABRICS=shm:tmi the problem appear.
If I set export I_MPI_FABRICS=dapl:tmi the problem does not appear.
Any ideas?
