Intel® MPI Library
Problem with MPI
e_ustimenko
Hello, my name is Evgeny. I wonder your MPI-library. I use Linux-system. When I installed your library, I have a problem with different mpi-commands, such as mpiboot. At the terminal I see the same error
mpdboot_e.ustimenko (handle_mpd_output 420): from mpd on e.ustimenko, invalid port info:
no_port
Where I can write the information about port. And how it should be?
Thanks a lot.
Dmitry_K_Intel2
Hi Evgeny,
You probably don't have password-less ssh connection between nodes which is required for the Intel MPI Library.
For you convenience you could create a new topic in this forum: http://software.intel.com/ru-ru/forums/95/ and ask in Russian. I'll provide you support in Russian in this case.
Regards!
Dmitry
