Intel® MPI Library
2293 Discussions
Problem with the use of Intel MPI DAPL fabric
dingjun_chencmgl_ca
Hi, on our Windows PCs cluster, when I tried to test Intel MPI benchmark 4.0 with the use of DAPL fabric, the following error always occurred. Could you tell me the reasons? Thanks in advance.
By the way, both   WinOFED 3.2 and Mellanox WinOF Rev 4.4 are installed on our Windows PCs cluster.
C:\Users\dingjun\mpi5tests>mpiexec -n 4 -env I_MPI_FABRICS shm:dapl IMB-MPI1
dapls_ib_init() NdStartup failed with NTStatus: The specified module could not be found.
job aborted:
rank: node: exit code[: error message]
0: drmswc4-1.cgy.cmgl.ca: 291: process 0 exited without calling finalize
1: drmswc4-1.cgy.cmgl.ca: 291: process 1 exited without calling finalize
2: drmswc4-1.cgy.cmgl.ca: 291: process 2 exited without calling finalize
3: drmswc4-1.cgy.cmgl.ca: 291: process 3 exited without calling finalize
James_T_Intel
I'm closing this thread as a duplicate of http://software.intel.com/en-us/forums/topic/498808.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
