Intel® MPI Library
2285 Discussions
Problems building C application for linux-HPC with mpiicc and Python.h
JPWC
Hello Intel community,
I'm using intel's mpi compiler (mpiicc) to build a custom program on C for linux HPC cluster. Currently, the program compiles well on it's own, but I'm running into problems in the process of embedding python functionality with the intent of deploying a machine learning framework. Specifically, I'm calling Python.h (and associated libraries) from a carefully curated conda environment that contains PyTorch libraries).
The mpiicc version is:
/cm/shared/apps/intel/compilers_and_libraries/2017.0.098/mpi/intel64
The python version is:
~/.conda/envs/NeTS/bin/python3.9
The build command is: ( the program.c sources Python.h )
mpiicc -DOPEN_MP -qopenmp -Wall -ansi -DMPI -DNO_GFX_MODE -O3 -c program.c -I~/.conda/envs/NeTS/include/python3.9 -L~/.conda/envs/NeTS/lib/python3.9 -no-pie -lpython3.9
And the output of the unsuccessful build is attached in a document to this thread.
Thank you!
AishwaryaCV_Intel
Thank you for reaching out to the Intel communities.
We have noticed that you are currently utilizing an unsupported version of Intel MPI. In order to resolve this issue, we kindly ask that you upgrade to the latest version of Intel MPI and execute your code once again.
To check which versions of Intel MPI are supported, please refer to the following link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-parallel-studio-xe-supported-and-unsupported-product-versions.html
If the problem persists even after upgrading to the latest Intel MPI 2021.8, please provide us with a sample reproducer code and the specifications of the hardware and operating system that you are currently using.
Thank you and best regards,
Aishwarya
JPWC
Thanks for the reply! Unfortunately, I'm working on a complex HPC without admin privileges and I'll have to check with admin before installing new Intel software.
AishwaryaCV_Intel
Sorry, we no longer support this version(2017). Please download the latest version to get further assistance.
So please try to check with admin and upgrade to the latest version.
And if you face any issues with the latest version , please post a new thread, as this thread will no longer be available.
Thanks And Regards,
Aishwarya
