Intel® MPI Library
2301 Discussions
Problems installing cluster toolkit under windows server 2008
Igor_Pasichnyk
Hi all,
during the installation of Cluster Toolkit for Windows HPC Server 2008 I had some "noncritical errors":
An error occured in Merge Module SUBST.
Installation will be continued but NOT all of the following files will be configured appropriately:
C:\Program Files (x86)\Intel\ICTCE\3.2.1.015\Compiler\bin\ifortvars.bat
etc.
After installing Cluster Tookit I have checked build environment with the following output:
The system cannot find the file specified.
Copyright (C) 2007-2009 Intel Corporation. All rights reserved.
The filename, directory name, or volume label syntax is incorrect.
Copyright (C) 2009 Intel Corporation. All rights reserved.
After checking .bat files I have seen the following variable:
the meaning of which is not clear for me.
I am triying to install this version of Toolkit:
Package ID: w_ict_p_3.2.1.015
Package Contents: Intel Cluster Toolkit Compiler Edition 3.2.1 for Windows*
Windows version:
Windows Server 2008 HPC Edition with SP2
Any ideas?
Igor
Andrey_L_Intel
Hi Igor,
This is error in the Intel Cluster Toolkit installer.
I believe that you have UAC enabled and your account is not built-in administrator.
Please try the following workaround(s):
- start installer using 'Run as administrator' context menu option from the Windows Explorer
or:
- login under built-in 'administrator' account (if possible) and run installation in the normal way.
Unfortunately, you need to uninstall your existing Instel Cluster Toolkit installation first because it's broken (all *vars.bat files are incorrect).
-- Andrey Lobanov
