Intel® MPI Library
Process pinning with intelmpi.
Hongyizhao
Hi here,
On a dual-AMD Epyc 9554 machine, I compiled VASP.6.4.2 with one API 2023.2.0. Then I want to bind the process to core when running vasp with intel mpi. For this purpose, I noticed that there are two possible methods as listed below:
-bind-to core
-genv I_MPI_PIN 1 -genv I_MPI_PIN_DOMAIN core
So, I debugged as follows:
werner@X10DAi:~/Public/hpc/vasp/benchmark/amd/Cr72_3x3x3K_350eV_10DAV$ mpirun -genv I_MPI_DEBUG=4 -bind-to core -np 4 vasp_std
[0] MPI startup(): Intel(R) MPI Library, Version 2021.10 Build 20230619 (id: c2e19c2f3e)
[0] MPI startup(): Copyright (C) 2003-2023 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): libfabric version: 1.18.0-impi
[0] MPI startup(): libfabric provider: tcp
[0] MPI startup(): File "" not found
[0] MPI startup(): Load tuning file: "/opt/intel/oneapi/2023.2.0/mpi/2021.10.0/etc/tuning_skx_shm-ofi.dat"
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 41239 X10DAi {0,1,2,3,4,5,6,7,8,9,10,44,45,46,47,48,49,50,51,52,53,54}
[0] MPI startup(): 1 41240 X10DAi {11,12,13,14,15,16,17,18,19,20,21,55,56,57,58,59,60,61,62,63,64,65}
[0] MPI startup(): 2 41241 X10DAi {22,23,24,25,26,27,28,29,30,31,32,66,67,68,69,70,71,72,73,74,75,76}
[0] MPI startup(): 3 41242 X10DAi {33,34,35,36,37,38,39,40,41,42,43,77,78,79,80,81,82,83,84,85,86,87}
running 4 mpi-ranks, on 1 nodes
distrk: each k-point on 4 cores, 1 groups
distr: one band on 4 cores, 1 groups
vasp.6.4.2 20Jul23 (build Feb 29 2024 20:51:29) complex
werner@X10DAi:~/Public/hpc/vasp/benchmark/amd/Cr72_3x3x3K_350eV_10DAV$ mpirun -genv I_MPI_DEBUG=4 -genv I_MPI_PIN 1 -genv I_MPI_PIN_DOMAIN core -np 4 vasp_std
[0] MPI startup(): 0 42573 X10DAi {0,44}
[0] MPI startup(): 1 42574 X10DAi {1,45}
[0] MPI startup(): 2 42575 X10DAi {22,66}
[0] MPI startup(): 3 42576 X10DAi {23,67}
Does this indicate that they can all be used in conjunction with IntelMPI to accomplish the same task? If they are both correct usage, why do I observe that the second method significantly reduces operating efficiency by half?
See here for the related discussion.
Zhao
TobiasK
Dear @Hongyizhao
As it was discussed in the VASP forum, benchmarking is a highly complex topic way of out scope for this forum, especially since it's about benchmarking non-Intel cpus.
Intel MPI works as expected, if you request binding to "core" it will ping your MPI ranks to specific cores. This may have consequences on available hardware resources such as memory bandwidth or cache since those are shared between cores.
Again for a more detailed analysis of your workload and the optimal pinning patterns for your workload, you may consult your hardware / software vendor.
