Intel® MPI Library
2301 Discussions
Program froze when using MPICH_ASYNC_PROGRESS
black__edgar
Hi all,
I am having a problem when the MPICH_ASYNC_PROGRESS  (or I_MPI_ASYNC_PROGRESS) environment variable is set on; the program freeze and I have to kill it.
Have anyone experience this problem.
This is the version of the Intel compiler and Intel MPI library producing the problem:
icc (ICC) 2021.1 Beta 20201112
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
Intel(R) MPI Library for Linux* OS, Version 2021.1 Build 20201112 (id: b9c9d2fc5)
Copyright 2003-2020, Intel Corporation.
I have experienced this problem ever since I updated from:
icc (ICC) 19.1.3.304 20200925
Intel(R) MPI Library for Linux* OS, Version 2019 Update 9 Build 20200923 (id: abd58e492)
Thanks in advance.
PrasanthD_intel
Hi Edgar,
Thanks for the confirmation.
As the issue has been resolved, we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Prasanth
PrasanthD_intel
Hi Edgar,
The additional features like multiple-endpoints and async threads are supported in release_mt and debug_mt versions only, as mentioned in the developer reference (Asynchronous Progress Control (intel.com)).
To enable those two library configurations, use this command:
source <install-dir>/env/vars.sh release
For more information on selecting library configuration please refer : Selecting a Library Configuration (intel.com)
If you are already enabled those configurations and still facing issues, please provide the log info you will get after setting I_MPI_DEBUG=10.
eg: export I_MPI_DEBUG=10
Prasanth
black__edgar
Hi Prasanth,
Thank you for your advice. It fixed the problem.
I was using the wrong configuration script;
Instead of using: /opt/intel/oneapi/compiler/2021.1.1/env/vars.sh
I was using : /opt/intel/oneapi/setvars.sh
I also notice that you do not actually need the "release" parameter. Could this be correct?
Thank you again.
Edgar
black__edgar
Hi Prasanth,
Here is an update of my previous post. The problem is not fixed just by changing the configuration script.
I was fooled by cmake mixing the Intel compiler and the gcc mpich library. That is what worked for me before.
After further exploration, I also set the mpi configuration script (/opt/intel/oneapi/mpi/2021.1.1/env/vars.sh) with the release_mt  parameter you suggested before as shown here:
/opt/intel/oneapi/mpi/2021.1.1/env/vars.sh -i_mpi_library_kind=release_mt
if "release" is used instead of "release_mt" the program freeze.
Thanks again,
Edgar
PrasanthD_intel
Hi Edgar,
In the command i mentioned, I have given release as an example. To use async progress we have either set the library configuration to release_mt or debug_mt.
source <install-dir>/env/vars.sh release_mt
If this doesn't fix your problem, please let us know.
Prasanth
black__edgar
Hi Prasanth,
Yes. The problem is gone.
The problem was produced by a bad setting of the configuration scripts.
Edgar
PrasanthD_intel
Hi Edgar,
Prasanth
