Intel® MPI Library
2300 Discussions
Questions about intel Cluster pack compiler
Sungho_L_1
Dear a good man;
I use cluster pack compiler of evaluation editon.
When i type  "mpirun -np 2 -machinefile machinefile a program"
I got a messgae following that
bash: /export/apps/intel/impi/4.1.0.024/intel64/bin/pmi_proxy :No such file or directory
I already added the path on my own path on master and each nodes
but it was not working properly
please give me any adivce
Thanks in advance
Sungho Lee
James_T_Intel
Hi Sungho,
Is the folder /export/apps/intel/impi/4.1.0.024 available on all of your nodes?  What is the value of I_MPI_ROOT?
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Sungho_L_1
Thanks you for your reply in advance.
Sadly, I am really beginer about cluster.
I can answer only first one. It is available, but node** can access that directory by different Path like that /share/apps/intel/impi ~~~~
I think different path do not make problems...
Unfortunately, I don't know how to answer your second I_MPI_ROOT.....
If you dont mind, tell me how I can check the value of I_MPI_ROOT
James_T_Intel
Hi Sungho,
Yes, a different path will cause a problem.
I_MPI_ROOT is an environment variable set to define the path to the Intel® MPI Library.  It is set by the mpivars.sh script, which can be loaded by using
[plain]source /export/apps/intel/impi/4.1.0.024/intel64/bin/mpivars.sh[/plain]
To check its value, you can use
[plain]echo $I_MPI_ROOT[/plain]
If you cannot install to a folder with the same name on every node, try making a symlink:
[plain]ln -s /share /export[/plain]
This will make the /export folder on the node point to the /share folder, which should make the paths look the same.
Sincerely,
James Tullos
Sungho_L_1
I try "source /export/apps/intel/impi/4.1.0.024/intel64/bin/mpivars.sh", "echo $I_MPI_ROOT"
except for "ln -s /share /export" a calcluating node dose not have /export directory. I mean; on master node, on calculating node, respectively /export and /share
so I cant do " ln -s /share /export"
Sungho_L_1
And I re-compile all things with your recommand with  "source /export/apps/intel/impi/4.1.0.024/intel64/bin/mpivars.sh and
source /export/apps/intel/bin/compiler.sh intel64"
It was working on only master before I recompile.
After re-compile, howerver, it is not working on even matster node...
when i tpye "mpirun -np 2 tough2_mp"
erorr is like that "PMGR_COLLECTIVE ERROR: unitialized MPI task: Missing required environment variable: MPIRUN_RANKK "
when i type "tough2_mp"
do I miss something when I recompeil?
And how do I go on....?
I am really sorry... I am really beginer...
Sungho_L_1
Dear a good man;
I tried what you said... (see my attached picture)
what is wrong....?
James_T_Intel
Hi Sungho,
Ok, it looks like the compute nodes are unable to see the Intel® MPI Library installation.  Let me make sure I've got everything straight about how you have your system configured.  On the master node, you have the Intel® MPI Library installed in:
[plain]/export/apps/intel/impi/4.1.0.024[/plain]
This folder is available for NFS share and the compute nodes have mounted it at
[plain]/share/apps/intel/impi/4.1.0.024[/plain]
If this is correct, then running
on the compute node will create a folder /export.  This folder will be a link to /share.  So when the compute node looks for /export/apps/intel/impi/4.1.0.024, it will be found.
Have you tried the ln command yet?
Sincerely,
James Tullos
Sungho_L_1
I tried "ln -s /share /export"
erorr it that "ln: creating symbolic link 'export/share' :File exists"
Maybe because of "export -> /state/partition1"
 /export is already linked to /state/partition1
So, I have attached my master node's directory construction
and the compute node's directory constiction
(attached picture 1, 2; master) (attached picture 3, 4; node)
James_T_Intel
Hi Sungho,
You need to run the ln command on the nodes, not on the master.
Sincerely,
James Tullos
