Intel® MPI Library
2300 Discussions
Redistributable info, missing component
Patrick_L_1
I'm looking at including the intel mpi as part of our software package, this way the end-user do not have to install the MPI components on his system.
We will of course include this in the 3rd party EULA of our software.
However:
  - The "redist.txt" file of the intel MPI folder list the files which are OK to include in our package.  But the file bin/pmi_proxy.exe seems missing from the list.  It is required to run local computations (-localonly)
  - What are the pitfalls of bundling the MPI components with the software distribution?  any environment variables to set-up?
      If it is sufficient, we would end up simply launching mpiexec with a full path   ( C:/Program Files/OurSoftware/MPI/Intel/intel64/bin/mpiexec.exe ...)
Artem_R_Intel1
Hi Patrick,
Regarding to:
Which version of Intel MPI Library do you use? As far as I see pmi_proxy.exe is present in the latest versions.
Patrick_L_1
Hi Artem,
Using impi_5.0.3, was latest when installed in July.
We are in the middle of software build process and upgrading would not be the best time.
If it is indeed a typo / missing item in that release, we could still redistribute this component?
Artem_R_Intel1
Hi Patrick,
Could you please submit a ticket via Intel Premier Support for the issue?
Artem_R_Intel1
Regarding to:
Necessary environment variables can be set with intel64\bin\mpivars.bat script - for correct work it's the recommended way to set the environment. Also you need Hydra service (hydra_service.exe) installed and running on the system.
Patrick_L_1
(For redist.txt, Intel Premier Support is taking care of it, thanks)
Does not need to be installed&running, if using -localonly.  But would be, i guess, for remote-machine execution on windows.
My experience is (so far), in order to redistribute intel-MPI with no installation or user configuration:
  - bundle the files detailed in redist.txt (with the same directory structure)
  - add the mpi bin/ to the front of the environment $PATH, before launching mpirun/mpiexec
  - Linux only:  add the mpi lib/ directory to the front of $LD_LIBRARY_PATH
