Intel® MPI Library
2296 Discussions
Resetting credentials for MPI project
Vlad_L_
I am trying to run my first MPI project and have a problem with credentials. Long story short, I have entered credentials and then realised I didn`t actually registered. Now, every time I`m starting the project prompt says: Credentials for <username> rejected connecting to <PCname>.
I wonder, how do I change the credentials I`ve entered and should have I registered with some specific name and password depending on PC name, windows username, etc. ?
Thank you.
Mark_L_Intel
Hello Vlad,
    Just double checking -- you obviously work with Windows. I'd suggest to look for starters at this post (you can search inside for credentials)
   https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/279300
  I hope you registered your credentials with
> mpiexec -register
you can Type "mpiexec -remove" to remove the registered username/password
Try not specifying username when running mpiexec -register. Just password for your current user
This link might help too:
https://trac.mpich.org/projects/mpich/ticket/1151
Mark
