Intel® MPI Library
2301 Discussions
SLURM and oneAPI cluster installation problems PMI library
j0e
I just update my cluster from cluster studio to the latest release of the oneAPI version (2021.4). The installation went fine, and ifort and mpiexec work as expected. However, when I try to use SLURM (which worked fine with cluster studio), I get errors such as:
Abort(1091087) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(138):
MPID_Init(996).......:
MPIR_pmi_init(168)...: PMI2_Job_GetId returned 14
srun: error: node3: tasks 30-49: Exited with exit code 1
srun: error: node5: tasks 70-89: Exited with exit code 1
srun: error: node4: tasks 50-69: Exited with exit code 1
srun: error: node2: tasks 10-29: Exited with exit code 1
The environment variable is set,
I_MPI_PMI_LIBRARY=/usr/lib64/libpmi.so
and I've also tried libpmi2.so, but same issue. I'm runniing SLURM 17.02.7
Any ideas?
ShivaniK_Intel
Could you please provide us the libfabric provider you have been using?
To investigate more on your issue, could you please provide us the command line you have been using?
Thanks & Regards
Shivani
ShivaniK_Intel
1. Could you please provide the complete debug log with I_MPI_DEBUG=100?
2. Could you also provide the output of the below command?
lscpu
>>>However when I try to use SLURM (which worked fine with cluster studio)
  As you have said that using slurm worked fine with cluster studio, could you please confirm the mpi version of cluster studio you have used?
Thanks & Regards
Shivani
ShivaniK_Intel
As we didn't hear back from you, could you please provide the details that have been asked in my previous post?
Thanks & Regards
Shivani
ShivaniK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel.
If you need further assistance please raise a new question.
Thanks & Regards
Shivani
