Intel® MPI Library
2285 Discussions
Segmentation fault with ifort -openmp
inkant
Processor info : Intel dual processor, quad code
Memory : 16GB
I have been able to compile and run my code in the serial mode. However, after including 'omp_lib.h' and with Openmp worksharing constructs, I get Segementation fault, which happens even if I remove the worksharing constructs. i.e
The program runs with ifort < > -o <>
failes with ifort -openmp <> -o <> (Even after commenting(removing) the OMP pragmas)
I have tried increasing environment variable KMP_STACKSIZE, but that is not help ful.
Inkant
inkant
Quoting - inkant
I am replying to my thread Since I found the solution
It was a stack overflow.
I could remedy it by using
ulimit -s 2048000 (you can choose an appropriarte) number ... then changing the same in /etc/security/limits.conf (to have it changed permanently).
then export KMP_STACKSIZE=2048000000 (i chose very high value, since it is only a limit)
Memory : 16GB
Inkant
dan0112
That solved my problem, thanks so much!
Running Intel Fortran Composer XE 2011 Update 1 on an Ubuntu 10.10 32bit system with 4 GB Ram.
