Intel® MPI Library
2285 Discussions
Segmentation fault with "flexible" mpi subroutine
Wee_Beng_T_
I have an mpi subroutine which copies different variables into an integer and real array, send to different procs using MPI, and then updates the variables to their new values using the sent integer and real array.
It works and now because I have different cases, I use dynamic allocation instead. But when I use dynamic allocation, it doesn't work anymore, even with the original case. It gives segmentation fault when MPI_ALLGATHERV is called.
My new code is:
subroutine mpi_IIB_I_equal_to_global(IIB_equal_cell_no_global,I_equal_cell_no_global,IIB_equal_cells,I_equal_cells,IIB_global_cells,I_global_cells)
!to copy from equal to global IIB,I
!real and integers
!size dep on interpolation_choice
integer, intent(in) :: IIB_equal_cell_no_global(0:num_procs-1),I_equal_cell_no_global(0:num_procs-1)
integer :: ijk,ijk2,sta_no_int(0:num_procs-1),sta_no_real(0:num_procs-1),ierr,total_IIB_cell_no,plus1_int,plus1_real,IIB_equal_cell_no,total_I_cell_no,I_equal_cell_no,vec_chg_size,vec_chg_size2,vec_chg_size3,vec_chg_size4
!integer :: total_IIB_cell_no,total_I_cell_no,plus1_int,plus1_real
!integer :: tmp_equal_int(IIB_equal_cell_no_global(myid)*19 + I_equal_cell_no_global(myid)*6),tmp_global_int(sum(IIB_equal_cell_no_global)*19 + sum(I_equal_cell_no_global)*6)
integer, allocatable :: tmp_equal_int(:),tmp_global_int(:)
integer :: IIB_I_equal_cell_no_int_elements,IIB_I_equal_cell_no_real_elements,IIB_I_equal_cell_no_global_int_elements(0:num_procs-1),IIB_I_equal_cell_no_global_real_elements(0:num_procs-1),IIB_counter,I_counter
type(IIB_cell), intent(in) :: IIB_equal_cells(IIB_equal_cell_no_global(myid))
type(IIB_cell), intent(inout) :: IIB_global_cells(sum(IIB_equal_cell_no_global))
type(I_cell), intent(in) :: I_equal_cells(I_equal_cell_no_global(myid))
type(I_cell), intent(inout) :: I_global_cells(sum(I_equal_cell_no_global))
!real(8) :: tmp_equal_real(IIB_equal_cell_no_global(myid)*34 + I_equal_cell_no_global(myid)),tmp_global_real(sum(IIB_equal_cell_no_global)*34 + sum(I_equal_cell_no_global))
real(8), allocatable :: tmp_equal_real(:),tmp_global_real(:)
!depending on choice, size of array is different
if (interpolation_choice == 1) then
   vec_chg_size = 19;   vec_chg_size2 = 34; vec_chg_size3 = 18; vec_chg_size4 = 33
else if (interpolation_choice == 2) then
    vec_chg_size = 85;  vec_chg_size2 = 56; vec_chg_size3 = 84; vec_chg_size4 = 55
end if
!allocate suitable real and int array size
allocate (tmp_equal_int(IIB_equal_cell_no_global(myid)*vec_chg_size + I_equal_cell_no_global(myid)*6)); allocate (tmp_global_int(IIB_equal_cell_no_global(myid)*vec_chg_size + I_equal_cell_no_global(myid)*6))
allocate (tmp_equal_real(IIB_equal_cell_no_global(myid)*vec_chg_size2 + I_equal_cell_no_global(myid)),tmp_global_real(sum(IIB_equal_cell_no_global)*vec_chg_size2 + sum(I_equal_cell_no_global)))
total_IIB_cell_no = sum(IIB_equal_cell_no_global);  total_I_cell_no = sum(I_equal_cell_no_global)
IIB_equal_cell_no = IIB_equal_cell_no_global(myid); I_equal_cell_no = I_equal_cell_no_global(myid)
sta_no_int = 0
IIB_I_equal_cell_no_global_int_elements(0) = IIB_equal_cell_no_global(0)*vec_chg_size + I_equal_cell_no_global(0)*6
do ijk = 1,num_procs -1
    sta_no_int(ijk) = sum(IIB_equal_cell_no_global(0:ijk - 1))*vec_chg_size + sum(I_equal_cell_no_global(0:ijk - 1))*6
    IIB_I_equal_cell_no_global_int_elements(ijk) = IIB_equal_cell_no_global(ijk)*vec_chg_size + I_equal_cell_no_global(ijk)*6
end do
sta_no_real = 0
IIB_I_equal_cell_no_global_real_elements(0) = IIB_equal_cell_no_global(0)*vec_chg_size2 + I_equal_cell_no_global(0)
    sta_no_real(ijk) = sum(IIB_equal_cell_no_global(0:ijk - 1))*vec_chg_size2 + sum(I_equal_cell_no_global(0:ijk - 1))
    IIB_I_equal_cell_no_global_real_elements(ijk) = IIB_equal_cell_no_global(ijk)*vec_chg_size2 + I_equal_cell_no_global(ijk)
end do
plus1_int = 1;  plus1_real = 1
do ijk = 1,IIB_equal_cell_no
!copy local variables to int array
    tmp_equal_int(plus1_int:plus1_int + 2) = IIB_equal_cells(ijk)%ijk
    !tmp_equal_int(plus1_int + 3:plus1_int + 11) = IIB_equal_cells(ijk)%int_template_ijk
    tmp_equal_int(plus1_int + 3) = IIB_equal_cells(ijk)%v_no
    tmp_equal_int(plus1_int + 4) = IIB_equal_cells(ijk)%s_no
    tmp_equal_int(plus1_int + 5) = IIB_equal_cells(ijk)%v_no2
    tmp_equal_int(plus1_int + 6) = IIB_equal_cells(ijk)%s_no2
    tmp_equal_int(plus1_int + 7) = IIB_equal_cells(ijk)%stencil_no
    tmp_equal_int(plus1_int + 8) = IIB_equal_cells(ijk)%e_no
    tmp_equal_int(plus1_int + 9) = IIB_equal_cells(ijk)%near_2_body
    tmp_equal_int(plus1_int + 10:plus1_int + vec_chg_size3) = IIB_equal_cells(ijk)%int_template_ijk
!copy local variables to real array
    tmp_equal_real(plus1_real:plus1_real + 2) = IIB_equal_cells(ijk)%xyz
    tmp_equal_real(plus1_real + 3:plus1_real + 5) = IIB_equal_cells(ijk)%IB_xyz
    tmp_equal_real(plus1_real + 6:plus1_real + 8) = IIB_equal_cells(ijk)%IB_xyz_old
    tmp_equal_real(plus1_real + 9:plus1_real + 11) = IIB_equal_cells(ijk)%IB_xyz2
    !tmp_equal_real(plus1_real + 12:plus1_real + 15) = IIB_equal_cells(ijk)%int_template_coef
    tmp_equal_real(plus1_real + 12) = IIB_equal_cells(ijk)%vel_b
    tmp_equal_real(plus1_real + 13) = IIB_equal_cells(ijk)%vel_b2
    tmp_equal_real(plus1_real + 14:plus1_real + 17) = IIB_equal_cells(ijk)%int_template_coef_matrix(1,:)
    tmp_equal_real(plus1_real + 18:plus1_real + 21) = IIB_equal_cells(ijk)%int_template_coef_matrix(2,:)
    tmp_equal_real(plus1_real + 22:plus1_real + 25) = IIB_equal_cells(ijk)%int_template_coef_matrix(3,:)
    tmp_equal_real(plus1_real + 26:plus1_real + 29) = IIB_equal_cells(ijk)%int_template_coef_matrix(4,:)
    tmp_equal_real(plus1_real + 30:plus1_real + vec_chg_size4) = IIB_equal_cells(ijk)%int_template_coef
    plus1_int = plus1_int + vec_chg_size;     plus1_real = plus1_real + vec_chg_size2
end do
do ijk = 1,I_equal_cell_no
    tmp_equal_int(plus1_int:plus1_int + 2) = I_equal_cells(ijk)%ijk
    tmp_equal_int(plus1_int + 3) = I_equal_cells(ijk)%v_no
    tmp_equal_int(plus1_int + 4) = I_equal_cells(ijk)%s_no
    tmp_equal_int(plus1_int + 5) = I_equal_cells(ijk)%e_no
    tmp_equal_real(plus1_real) = I_equal_cells(ijk)%vel
    plus1_int = plus1_int + 6;     plus1_real = plus1_real + 1
end do
IIB_I_equal_cell_no_int_elements = IIB_equal_cell_no*vec_chg_size + I_equal_cell_no*6
IIB_I_equal_cell_no_real_elements = IIB_equal_cell_no*vec_chg_size2 + I_equal_cell_no
!mpi communication
CALL MPI_ALLGATHERV(tmp_equal_int,IIB_I_equal_cell_no_int_elements,MPI_INTEGER,tmp_global_int,IIB_I_equal_cell_no_global_int_elements,sta_no_int,MPI_INTEGER,MPI_COMM_WORLD,ierr)
CALL MPI_ALLGATHERV(tmp_equal_real,IIB_I_equal_cell_no_real_elements,MPI_DOUBLE_PRECISION,tmp_global_real,IIB_I_equal_cell_no_global_real_elements,sta_no_real,MPI_DOUBLE_PRECISION,MPI_COMM_WORLD,ierr)
plus1_int = 1;  plus1_real = 1;  IIB_counter = 1;  I_counter = 1
do ijk = 0,num_procs - 1
    do ijk2 = 1,IIB_equal_cell_no_global(ijk)
!copy array back to local variables
        IIB_global_cells(IIB_counter)%ijk = tmp_global_int(plus1_int:plus1_int + 2)
        !IIB_global_cells(IIB_counter)%int_template_ijk = tmp_global_int(plus1_int + 3:plus1_int + 11)
        IIB_global_cells(IIB_counter)%v_no = tmp_global_int(plus1_int + 3)
        IIB_global_cells(IIB_counter)%s_no = tmp_global_int(plus1_int + 4)
        IIB_global_cells(IIB_counter)%v_no2 = tmp_global_int(plus1_int + 5)
        IIB_global_cells(IIB_counter)%s_no2 = tmp_global_int(plus1_int + 6)
        IIB_global_cells(IIB_counter)%stencil_no = tmp_global_int(plus1_int + 7)
        IIB_global_cells(IIB_counter)%e_no = tmp_global_int(plus1_int + 8)
        IIB_global_cells(IIB_counter)%near_2_body = tmp_global_int(plus1_int + 9)
        IIB_global_cells(IIB_counter)%int_template_ijk = tmp_global_int(plus1_int + 10:plus1_int + vec_chg_size3)
        IIB_global_cells(IIB_counter)%xyz = tmp_global_real(plus1_real:plus1_real + 2)
        IIB_global_cells(IIB_counter)%IB_xyz = tmp_global_real(plus1_real + 3:plus1_real + 5)
        IIB_global_cells(IIB_counter)%IB_xyz_old = tmp_global_real(plus1_real + 6:plus1_real + 8)
        IIB_global_cells(IIB_counter)%IB_xyz2 = tmp_global_real(plus1_real + 9:plus1_real + 11)
        !IIB_global_cells(IIB_counter)%int_template_coef = tmp_global_real(plus1_real + 12:plus1_real + 15)
        IIB_global_cells(IIB_counter)%vel_b = tmp_global_real(plus1_real + 12)
        IIB_global_cells(IIB_counter)%vel_b2 = tmp_global_real(plus1_real + 13)
        IIB_global_cells(IIB_counter)%int_template_coef_matrix(1,:) = tmp_global_real(plus1_real + 14:plus1_real + 17)
        IIB_global_cells(IIB_counter)%int_template_coef_matrix(2,:) = tmp_global_real(plus1_real + 18:plus1_real + 21)
        IIB_global_cells(IIB_counter)%int_template_coef_matrix(3,:) = tmp_global_real(plus1_real + 22:plus1_real + 25)
        IIB_global_cells(IIB_counter)%int_template_coef_matrix(4,:) = tmp_global_real(plus1_real + 26:plus1_real + 29)
        IIB_global_cells(IIB_counter)%int_template_coef = tmp_global_real(plus1_real + 30:plus1_real + vec_chg_size4)
        plus1_int = plus1_int + vec_chg_size; plus1_real = plus1_real + vec_chg_size2; IIB_counter = IIB_counter + 1
    end do
    do ijk2 = 1,I_equal_cell_no_global(ijk)
        I_global_cells(I_counter)%ijk = tmp_global_int(plus1_int:plus1_int + 2)
        I_global_cells(I_counter)%v_no = tmp_global_int(plus1_int + 3)
        I_global_cells(I_counter)%s_no = tmp_global_int(plus1_int + 4)
        I_global_cells(I_counter)%e_no = tmp_global_int(plus1_int + 5)
        I_global_cells(I_counter)%vel = tmp_global_real(plus1_real)
        plus1_int = plus1_int + 6;     plus1_real = plus1_real + 1; I_counter = I_counter + 1
    end do
end do
!call MPI_Barrier(MPI_COMM_WORLD,ierr)
deallocate (tmp_equal_int); deallocate(tmp_global_int)
deallocate (tmp_equal_real); deallocate(tmp_global_real)
end subroutine mpi_IIB_I_equal_to_global
James_T_Intel
Look at how you are allocating tmp_global_int.  When you were using static allocation, you used
With dynamic allocation, you are using
In your first MPI_Allgatherv, you are collecting into tmp_global_int.  Your dynamic allocation doesn't appear to have enough space for everything you are gathering.
James.
Wee_Beng_T_
Oh, that's really careless of me.
Thank you so much for pointing it out.
