Intel® MPI Library
2292 Discussions
Setting up Visual Studio for C++ MPI in WSL2
flgilbert
I know Intel does not support OneAPI on Windows Subsystem for Linux, but I almost managed to setup Visual Studio 2022 to develop with MPI. The only remaining thing is the debugging, which should work but I get a segmentation error on MPI::Init()
Here's the recipe so far:
1) setup Visual Studio for WSL2 as instructed by Microsoft https://docs.microsoft.com/en-us/cpp/linux/download-install-and-setup-the-linux-development-workload
2) Install OneAPI base and HPC toolkits on the WSL instance (mine uses Ubuntu 20.04LTS)
3) setup a CMAKE project in visual studio
4) In CMakeLists.txt, add the MPI directives:
find_package(MPI REQUIRED)
target_link_libraries(myTestProgram MPI::MPI_CXX)
5) in CMakePresets.json, modify the "Linux Debug" preset by adding the following settings:
"environment": {
"PATH": "$penv{PATH}:/opt/intel/oneapi/compiler/latest/linux/bin/intel64/:/opt/intel/oneapi/mpi/latest/bin/",
"I_MPI_ROOT": "/opt/intel/oneapi/mpi/latest"
And replacing the cacheVariables with this:
"cacheVariables": {
"CMAKE_BUILD_TYPE": "Debug",
"CMAKE_INSTALL_PREFIX": "${sourceDir}/out/install/${presetName}",
"CMAKE_C_COMPILER": "icc", // Optional: use the Intel compiler.
"CMAKE_CXX_COMPILER": "icpc" //Optional: use the Intel compiler.
With these steps, Visual Studio compiles the example test.cpp without errors and Intellisense "sees" the MPI header file.
When I use the WSL2 shell to run the resulting executable, I get no errors and it works as expected. I also can use gdb on it this way without problem.
The problem comes when I try to start the debugging session in Visual Studio: I systematically get a Segmentation fault on the MPI::Init line.
Did anybody make this work? What did I miss?
Labels (2)
VarshaS_Intel
Could you please let us know the Intel oneAPI and MPI versions you are using?
Could you please provide us with the complete CMAKE File, complete sample reproducer(test.cpp mentioned in the post) along with the steps and commands to reproduce the issue at our end?
And also, could you please provide us with the screenshot of the error you are facing?
Thanks & Regards,
Varsha
flgilbert
The versions of software installed on Ubuntu are the following:
  • mpiexec --version replies Intel(R) MPI Library for Linux* OS, Version 2021.5 Build 20211102 (id: 9279b7d62)
  • icpc (ICC) 2021.5.0 20211109
  • GNU gdb (Ubuntu 9.2-0ubuntu1~20.04.1) 9.2
flgilbert
I am still working on this, and now I can launch the MPI program without problem.
I believe the problem was using the basic gdb instead of the gdb distributed with OneAPI.
To make Visual Studio use gdb-oneapi, I added a debug configuration to my project.  Visual Studio keeps these in launch.vs.json.  The new configuration sources setvars.sh, then starts the OneAPI debugger.  The SEGFAULT is no more, and I can do all the normal debugging actions (single-stepping, inspecting vars, etc.)
Here is the configuration:
"version": "0.2.1",
"defaults": {},
"configurations": [
"type": "cppgdb",
"name": "testMPI",
"project": "CMakeLists.txt",
"projectTarget": "testMPI",
"debuggerConfiguration": "gdb",
"gdbPath": "/opt/intel/oneapi/debugger/latest/gdb/intel64/bin/gdb-oneapi",
"preDebugCommand": "source /opt/intel/oneapi/setvars.sh",
"args": [],
"env": {}
The last thing that is still missing is starting the program with mpiexec and setting the number of processors and threads.
flgilbert
The other option is launching the program with mpiexec, but then Visual Studio can't seem to set the breakpoints.
"version": "0.2.1",
"defaults": {},
"configurations": [
"type": "cppgdb",
"name": "testMPI",
"program": "mpiexec",
"args": [ "-n", "3", "${debugInfo.fullTargetPath}" ], //Launches 3 threads. VS can't debug with this :(
"env": {}
VarshaS_Intel
Thanks for providing the information.
Could you please let us know the detailed steps that you have followed to set up WSL2 with Intel oneAPI, Ubuntu, and Visual Studio?
>> The SEGFAULT is no more, and I can do all the normal debugging actions(single-stepping, inspecting vars, etc.)
Glad to know that one of your issues is resolved. Could you please confirm if it works with the -n(number of processes) is 1?
Could you please elaborate on the above statement?
Could you please provide us with a screenshot of the error you are facing?
Thanks & Regards,
Varsha
flgilbert
I'll start with the questions, which are quick.
I just checked, and it works even with -n 1.
This is the last remaining hole in this setup:  if I use mpiexec, the Visual Studio debugger does not seem to be able to attach to the process:  any breakpoints I set are never triggered.  I tried adding the "-gdb" option to the arguments of mpiexec, but I get a weird output in the console;  you will find a screenshot with this message.
As for the setup instructions, I do not remember doing anything more than outlined in my first post.  I do see I have skipped one detail in my first post:  in step (2), I used the apt package manager inside the WSL console, following the instructions outlined here:  https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/install-using-package-managers/apt.html
VarshaS_Intel
We are able to reproduce it. We are in discussion with the development team and will get back to you soon.
Thanks & Regards,
Varsha
VarshaS_Intel
We are working on your issue and will get back to you soon.
Thanks & Regards,
Varsha
VarshaS_Intel
We are able to get the expected results using the gdb-oneapi debugger with breakpoints in WSL2(Ubuntu 20.04 LTS). Please find the below screenshot while running the Sample Hello World MPI code:
Hence, the error seems to be with Visual Studio IDE and not with Intel oneAPI gdb- debugger & this forum is intended to support the queries related to Intel OneAPI. Please let us know if we can go ahead and close this thread.
Thanks & Regards,
Varsha
flgilbert
Do you at least plan to integrate this function in the Visual Studio integration for OneAPI?
VarshaS_Intel
We have reported this issue to the concerned development team. They are looking into your issue.
Thanks & Regards,
Varsha
