Intel® MPI Library
2299 Discussions
Should the documentation be updated?
oleotiger
The documentation Intel(R) MPI Library Developer Reference for Linux* OS is last updated at 04/06/2021 and the version is 2021.2, the same to the version of lastest oneapi.
But there is much gap between the documentation and intel mpi library.
For example, I cannot find description of I_MPI_EXTREME_SCALE_THRESHOLD, I_MPI_THREAD_EP_MAX. But both can be shown with impi_info. impi_info -v option shows too little to understand the meaning of the options.
Where could I get the documentation with more details?
ShivaniK_Intel
Thanks for reporting to us. We are working on it and will get back to you soon.
Thanks & Regards
Shivani
clevels
I have filed a ticket with development and will provide updates as soon as development team takes a look.
Mark_L_Intel
If these options are not documented or there are gaps as you indicated, I'd not advise to use them. Also, could you please indicate what problem are trying to solve? In other words, why are you looking into these options?
Mark_L_Intel
Due to lack of responses from the customer the issue won't be tracked by Intel.
