- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I just installed Intel base&hpc toolkits 2022.1.2 on our HPC cluster. When trying to run a simple MPI hello world example, then it fails on servers having a Mellanox ConnectX-6 infiniband card. Are those infiniband cards from Mellanox not supported?
[sfux@eu-login-46 intelmpi]$ cat hello.c
#include <mpi.h>
#include <stdio.h>
int main(int argc, char** argv) {
// Initialize the MPI environment
MPI_Init(NULL, NULL);
// Get the number of processes
int world_size;
MPI_Comm_size(MPI_COMM_WORLD, &world_size);
// Get the rank of the process
int world_rank;
MPI_Comm_rank(MPI_COMM_WORLD, &world_rank);
// Get the name of the processor
char processor_name[MPI_MAX_PROCESSOR_NAME];
int name_len;
MPI_Get_processor_name(processor_name, &name_len);
// Print off a hello world message
printf("Hello world from processor %s, rank %d out of %d processors\n",
processor_name, world_rank, world_size);
// Finalize the MPI environment.
MPI_Finalize();
[sfux@eu-login-46 intelmpi]$ mpiicc --version
icc (ICC) 2021.5.0 20211109
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
[sfux@eu-login-46 intelmpi]$ mpiicc -o hello hello.c
[sfux@eu-login-46 intelmpi]$ ls
hello hello.c
I try to run the example on 4 cores (2 cores on each server). Since some of our servers have Mellanox ConnectX-6 infiniband cards, I try to run this example with setting
FI_PROVIDER=mlx
I_MPI_FABRICS=shm:ofi
and it fails with a segmentation fault:
Sender: LSF System <lsfadmin@eu-g1-020-1>
Subject: Job 207016280: <FI_PROVIDER=mlx I_MPI_FABRICS=shm:ofi mpirun ./hello> in cluster <euler> Exited
Job <FI_PROVIDER=mlx I_MPI_FABRICS=shm:ofi mpirun ./hello> was submitted from host <eu-login-46> by user <sfux> in cluster <euler> at Thu Mar 3 11:08:14 2022
Job was executed on host(s) <2*eu-g1-020-1>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Thu Mar 3 11:08:49 2022
<2*eu-g1-024-1>
</cluster/home/sfux> was used as the home directory.
</cluster/home/sfux/test/intelmpi> was used as the working directory.
Started at Thu Mar 3 11:08:49 2022
Terminated at Thu Mar 3 11:09:04 2022
Results reported at Thu Mar 3 11:09:04 2022
Your job looked like:
# LSBATCH: User input
Exited with exit code 255.
Resource usage summary:
CPU time : 44.00 sec.
Max Memory : 14061 MB
Average Memory : 365.00 MB
Total Requested Memory : 8000.00 MB
Delta Memory : -6061.00 MB
Max Swap : -
Max Processes : 9
Max Threads : 13
Run time : 34 sec.
Turnaround time : 50 sec.
The output (if any) follows:
[eu-g1-024-1:14947:0:14947] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
[eu-g1-024-1:14948:0:14948] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
[eu-g1-020-1:103094:0:103094] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
[eu-g1-020-1:103095:0:103095] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
==== backtrace (tid: 103095) ====
0 0x000000000004d455 ucs_debug_print_backtrace() ???:0
1 0x0000000000291441 MPIDIG_dequeue_unexp() /build/impi/_buildspace/release/../../src/mpid/ch4/src/intel/ch4r_unexp_hashtable.c:417
2 0x00000000003d3cc0 MPIDIG_do_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/generic/mpidig_recv.h:135
3 0x000000000040356d MPIDIG_mpi_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/generic/mpidig_recv.h:336
4 0x000000000040356d MPIDI_POSIX_mpi_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/shm/src/../src/../posix/posix_recv.h:60
5 0x000000000040356d MPIDI_SHM_mpi_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/shm/src/../src/shm_p2p.h:328
6 0x000000000040356d MPIDI_irecv_unsafe() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_recv.h:235
7 0x000000000040356d MPIDI_irecv_safe() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_recv.h:558
8 0x000000000040356d MPID_Irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_recv.h:791
9 0x000000000040356d MPIC_Irecv() /build/impi/_buildspace/release/../../src/mpi/coll/helper_fns.c:625
10 0x00000000003c1bee recv_nb() /build/impi/_buildspace/release/../../src/mpid/common/hcoll/hcoll_rte.c:233
11 0x000000000001c908 comm_allreduce_hcolrte_generic() common_allreduce.c:0
12 0x000000000001ce0b comm_allreduce_hcolrte() ???:0
13 0x0000000000013a0b hmca_bcol_ucx_p2p_init_query.part.4() bcol_ucx_p2p_component.c:0
14 0x00000000000ca47c hmca_bcol_base_init() ???:0
15 0x0000000000049a08 hmca_coll_ml_init_query() ???:0
16 0x00000000000bf627 hcoll_init_with_opts() ???:0
17 0x00000000003c0493 hcoll_initialize() /build/impi/_buildspace/release/../../src/mpid/common/hcoll/hcoll_init.c:106
18 0x00000000003c0493 hcoll_comm_create() /build/impi/_buildspace/release/../../src/mpid/common/hcoll/hcoll_init.c:144
19 0x00000000006a0b01 MPIDI_OFI_mpi_comm_create_hook() /build/impi/_buildspace/release/../../src/mpid/ch4/netmod/ofi/ofi_comm.c:216
20 0x00000000001ca555 MPID_Comm_create_hook() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_comm.c:198
21 0x0000000000317bdb MPIR_Comm_commit_internal() /build/impi/_buildspace/release/../../src/mpi/comm/commutil.c:353
22 0x0000000000317bdb MPIR_Comm_commit() /build/impi/_buildspace/release/../../src/mpi/comm/commutil.c:530
23 0x0000000000210e4b init_builtin_comms() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_init.c:1113
24 0x0000000000210e4b MPID_Init() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_init.c:1359
"lsf.o207016280" 180L, 14469C
Is this a known problem? Is it wrong to use the MLX FI provider for systems with Mellanox ConnectX-6 infiniband cards?
Any help is appreciated.
Best regards
Sam
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I tried again with
I_MPI_OFI_PROVIDER=mlx mpirun
and with 256 cores on two servers, each having 128 cores. Same result:
Sender: LSF System <lsfadmin@eu-g1-021-3>
Subject: Job 207019623: <I_MPI_FABRICS=shm:ofi I_MPI_OFI_PROVIDER=mlx mpirun ./hello> in cluster <euler> Exited
Job <I_MPI_FABRICS=shm:ofi I_MPI_OFI_PROVIDER=mlx mpirun ./hello> was submitted from host <eu-login-46> by user <sfux> in cluster <euler> at Thu Mar 3 11:52:57 2022
Job was executed on host(s) <128*eu-g1-021-3>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Thu Mar 3 11:53:27 2022
<128*eu-g1-022-2>
Started at Thu Mar 3 11:53:27 2022
Terminated at Thu Mar 3 11:53:33 2022
Results reported at Thu Mar 3 11:53:33 2022
Exited with exit code 143.
CPU time : 320.00 sec.
Max Memory : 9421 MB
Average Memory : -
Total Requested Memory : 25600.00 MB
Delta Memory : 16179.00 MB
Max Swap : -
Max Processes : -
Max Threads : -
Run time : 5 sec.
Turnaround time : 36 sec.
[eu-g1-022-2:5563 :0:5563] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7915ba3006)
[eu-g1-022-2:5572 :0:5572] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b1e07498006)
[eu-g1-022-2:5574 :0:5574] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2aed54929006)
[eu-g1-022-2:5593 :0:5593] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b4357593006)
[eu-g1-022-2:5617 :0:5617] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b910765d006)
[eu-g1-022-2:5637 :0:5637] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad132c02006)
[eu-g1-022-2:5642 :0:5642] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b49a43b5006)
[eu-g1-022-2:5517 :0:5517] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b649d636006)
[eu-g1-022-2:5521 :0:5521] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b34e4ccb006)
[eu-g1-022-2:5523 :0:5523] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad3ba3cc006)
[eu-g1-022-2:5527 :0:5527] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b5fe34c8006)
[eu-g1-022-2:5529 :0:5529] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b0c04006006)
[eu-g1-022-2:5530 :0:5530] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b8a6df1c006)
[eu-g1-022-2:5541 :0:5541] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7c7f4f7006)
[eu-g1-022-2:5544 :0:5544] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b03d1ef9006)
[eu-g1-022-2:5546 :0:5546] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b298e9fc006)
[eu-g1-022-2:5548 :0:5548] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af048dba006)
[eu-g1-022-2:5579 :0:5579] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2aef6b6e7006)
[eu-g1-022-2:5609 :0:5609] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b19263b6006)
[eu-g1-022-2:5618 :0:5618] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b4df1fac006)
[eu-g1-022-2:5627 :0:5627] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b874051a006)
[eu-g1-022-2:5629 :0:5629] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b58a45b2006)
[eu-g1-022-2:5635 :0:5635] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b3d4aa13006)
[eu-g1-022-2:5644 :0:5644] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2aff0bbe0006)
[eu-g1-022-2:5515 :0:5515] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b65ec6c6006)
[eu-g1-022-2:5516 :0:5516] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ab781617006)
[eu-g1-022-2:5519 :0:5519] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae61e7ba006)
[eu-g1-022-2:5522 :0:5522] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b60be873006)
[eu-g1-022-2:5564 :0:5564] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b698e6a6006)
[eu-g1-022-2:5591 :0:5591] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac830af3006)
[eu-g1-022-2:5592 :0:5592] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b9a9b455006)
[eu-g1-022-2:5624 :0:5624] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2afe26569006)
[eu-g1-022-2:5631 :0:5631] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba81af7b006)
[eu-g1-022-2:5632 :0:5632] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad57f8e3006)
[eu-g1-022-2:5643 :0:5643] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2adb9289f006)
[eu-g1-022-2:5645 :0:5645] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b37a72ea006)
[eu-g1-022-2:5518 :0:5518] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b1de38fd006)
[eu-g1-022-2:5520 :0:5520] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b9ddcef2006)
[eu-g1-022-2:5525 :0:5525] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b87906bb006)
[eu-g1-022-2:5526 :0:5526] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b6e36dfe006)
[eu-g1-022-2:5528 :0:5528] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b2214a76006)
[eu-g1-022-2:5533 :0:5533] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae0c435c006)
[eu-g1-022-2:5536 :0:5536] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ab91c9f3006)
[eu-g1-022-2:5542 :0:5542] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b2159a96006)
[eu-g1-022-2:5543 :0:5543] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac7ea0ff006)
[eu-g1-022-2:5577 :0:5577] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ab9266e4006)
[eu-g1-022-2:5582 :0:5582] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b03b567b006)
[eu-g1-022-2:5598 :0:5598] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2aba35f44006)
[eu-g1-022-2:5634 :0:5634] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac31fef9006)
[eu-g1-022-2:5639 :0:5639] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b04ff9db006)
[eu-g1-022-2:5524 :0:5524] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b99d7fc1006)
[eu-g1-022-2:5531 :0:5531] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad5816f3006)
[eu-g1-022-2:5532 :0:5532] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b0835e53006)
[eu-g1-022-2:5534 :0:5534] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b600ae4c006)
[eu-g1-022-2:5537 :0:5537] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b0abf142006)
[eu-g1-022-2:5538 :0:5538] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b32897dd006)
[eu-g1-022-2:5540 :0:5540] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b5efa245006)
[eu-g1-022-2:5547 :0:5547] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b16be69d006)
[eu-g1-022-2:5555 :0:5555] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b8876c6e006)
[eu-g1-022-2:5558 :0:5558] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba8207e8006)
[eu-g1-022-2:5562 :0:5562] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad6f4026006)
[eu-g1-022-2:5565 :0:5565] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac847f46006)
[eu-g1-022-2:5566 :0:5566] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae4f6707006)
[eu-g1-022-2:5568 :0:5568] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b5e0a0d1006)
[eu-g1-022-2:5571 :0:5571] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad5e4114006)
[eu-g1-022-2:5580 :0:5580] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b70a10e3006)
[eu-g1-022-2:5581 :0:5581] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b6e1514f006)
[eu-g1-022-2:5586 :0:5586] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af715206006)
[eu-g1-022-2:5589 :0:5589] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b9a7fd9c006)
[eu-g1-022-2:5604 :0:5604] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae12f9ca006)
[eu-g1-022-2:5605 :0:5605] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ab93a8f1006)
[eu-g1-022-2:5623 :0:5623] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac00b109006)
[eu-g1-022-2:5545 :0:5545] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b0c6bf6c006)
[eu-g1-022-2:5549 :0:5549] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b3542c64006)
[eu-g1-022-2:5550 :0:5550] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ada2d3eb006)
[eu-g1-022-2:5552 :0:5552] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac14a04a006)
[eu-g1-022-2:5554 :0:5554] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b8390672006)
[eu-g1-022-2:5557 :0:5557] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b539bd27006)
[eu-g1-022-2:5559 :0:5559] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2aedbafaf006)
[eu-g1-022-2:5560 :0:5560] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7bece8f006)
[eu-g1-022-2:5561 :0:5561] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b79c0255006)
[eu-g1-022-2:5567 :0:5567] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b4f021ee006)
[eu-g1-022-2:5569 :0:5569] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b5edc12d006)
[eu-g1-022-2:5578 :0:5578] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac40bf16006)
[eu-g1-022-2:5583 :0:5583] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac861ff5006)
[eu-g1-022-2:5584 :0:5584] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b022e546006)
[eu-g1-022-2:5585 :0:5585] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2afaf0062006)
[eu-g1-022-2:5587 :0:5587] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2afabc5d8006)
[eu-g1-022-2:5588 :0:5588] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ab618b4f006)
[eu-g1-022-2:5590 :0:5590] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b425b7a7006)
[eu-g1-022-2:5594 :0:5594] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba36c348006)
[eu-g1-022-2:5595 :0:5595] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b4d2ec22006)
[eu-g1-022-2:5596 :0:5596] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b5b06c33006)
[eu-g1-022-2:5599 :0:5599] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af2161bb006)
[eu-g1-022-2:5600 :0:5600] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b39d7add006)
[eu-g1-022-2:5601 :0:5601] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b93d2e28006)
[eu-g1-022-2:5606 :0:5606] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b9bf7758006)
[eu-g1-022-2:5610 :0:5610] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ad7606f6006)
[eu-g1-022-2:5612 :0:5612] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7899323006)
[eu-g1-022-2:5613 :0:5613] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b16ecc2a006)
[eu-g1-022-2:5630 :0:5630] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ac01944e006)
[eu-g1-022-2:5633 :0:5633] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b379f9db006)
[eu-g1-022-2:5636 :0:5636] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2acf93315006)
[eu-g1-022-2:5638 :0:5638] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b635401f006)
[eu-g1-022-2:5640 :0:5640] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba5e5d1a006)
[eu-g1-022-2:5551 :0:5551] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b718a434006)
[eu-g1-022-2:5553 :0:5553] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b0689a35006)
[eu-g1-022-2:5570 :0:5570] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b006850f006)
[eu-g1-022-2:5575 :0:5575] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af10ee14006)
[eu-g1-022-2:5576 :0:5576] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b8df73b6006)
[eu-g1-022-2:5602 :0:5602] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af2b6b40006)
[eu-g1-022-2:5603 :0:5603] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b6e33161006)
[eu-g1-022-2:5607 :0:5607] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7d9263d006)
[eu-g1-022-2:5608 :0:5608] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae9201a0006)
[eu-g1-022-2:5611 :0:5611] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba86ea0c006)
[eu-g1-022-2:5614 :0:5614] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae3286e6006)
[eu-g1-022-2:5615 :0:5615] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2acbbed0e006)
[eu-g1-022-2:5616 :0:5616] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba407a8d006)
[eu-g1-022-2:5619 :0:5619] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ba61d0ca006)
[eu-g1-022-2:5620 :0:5620] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2ae513304006)
[eu-g1-022-2:5621 :0:5621] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7fa3946006)
[eu-g1-022-2:5622 :0:5622] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af2e9c7f006)
[eu-g1-022-2:5625 :0:5625] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b2a9dd81006)
[eu-g1-022-2:5626 :0:5626] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b5239efb006)
[eu-g1-022-2:5628 :0:5628] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b7efb75b006)
[eu-g1-022-2:5641 :0:5641] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2af3e83f0006)
[eu-g1-022-2:5597 :0:5597] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b75e6475006)
[eu-g1-022-2:5646 :0:5646] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x2b26e9c8f006)
[1646304812.267239] [eu-g1-021-3:35151:0] address.c:988 UCX ERROR address version mismatch: expected 0, actual 15
Abort(1090703) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(143)........:
MPID_Init(1310)..............:
MPIDI_OFI_mpi_init_hook(1974): OFI get address vector map failed
[1646304812.267234] [eu-g1-021-3:35215:0] address.c:988 UCX ERROR address version mismatch: expected 0, actual 15
[1646304812.267353] [eu-g1-021-3:35216:0] address.c:988 UCX ERROR address version mismatch: expected 0, actual 15
[1646304812.269680] [eu-g1-021-3:35248:0] address.c:988 UCX ERROR address version mismatch: expected 0, actual 15
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Was is also surprising is, that the batch system reports a memory usage of 12971 MB for a hello world program on 4 cores. This does not seem right.
Another run with increased loglevel:
[sfux@eu-login-29 intelmpi]$ cat lsf.o207036445
Sender: LSF System <lsfadmin@eu-g1-019-4>
Subject: Job 207036445: <I_MPI_FABRICS=shm:ofi I_MPI_OFI_PROVIDER=mlx I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun ./hello> in cluster <euler> Exited
Job <I_MPI_FABRICS=shm:ofi I_MPI_OFI_PROVIDER=mlx I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun ./hello> was submitted from host <eu-login-29> by user <sfux> in cluster <euler> at Thu Mar 3 15:05:44 2022
Job was executed on host(s) <2*eu-g1-019-4>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Thu Mar 3 15:07:25 2022
<2*eu-g1-021-4>
Started at Thu Mar 3 15:07:25 2022
Terminated at Thu Mar 3 15:07:41 2022
Results reported at Thu Mar 3 15:07:41 2022
Max Memory : 12971 MB
Average Memory : 391.00 MB
Delta Memory : -4971.00 MB
Max Swap : -
Max Processes : 9
Max Threads : 13
Run time : 37 sec.
Turnaround time : 117 sec.
IPL WARN> Not all cpus are available, switch to I_MPI_PIN_ORDER=compact. (Total: 128 Available: 2)
[0] MPI startup(): Intel(R) MPI Library, Version 2021.5 Build 20211102 (id: 9279b7d62)
[0] MPI startup(): Copyright (C) 2003-2021 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
[2] MPI startup(): shm segment size (1068 MB per rank) * (2 local ranks) = 2136 MB total
[0] MPI startup(): shm segment size (1068 MB per rank) * (2 local ranks) = 2136 MB total
libfabric:94329:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:94329:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:94328:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:94328:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
[0] MPI startup(): libfabric version: 1.13.2rc1-impi
libfabric:33997:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:33997:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:33997:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:33997:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:33997:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:33998:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:33998:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:33998:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:33998:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:33998:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:94328:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:94328:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:94328:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:94329:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:94329:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:94329:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:33997:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:33997:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:33997:verbs:fabric:verbs_devs_print():897<info> 10.205.73.96
libfabric:33997:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d1:f13e
libfabric:33998:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:33998:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:33998:verbs:fabric:verbs_devs_print():897<info> 10.205.73.96
libfabric:33998:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d1:f13e
libfabric:94328:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:94328:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:94328:verbs:fabric:verbs_devs_print():897<info> 10.205.73.104
libfabric:94328:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d2:4e2
libfabric:94329:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:94329:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:94329:verbs:fabric:verbs_devs_print():897<info> 10.205.73.104
libfabric:94329:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d2:4e2
libfabric:94328:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:94329:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:94329:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:94328:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:94328:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:94329:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:33997:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:33998:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:94328:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:94329:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:94328:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:94329:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:94328:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:94329:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:94328:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:94328:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:94329:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:94329:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:94328:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:94328:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:94328:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:94329:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:94329:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:94329:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:94328:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:94329:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:33997:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:33997:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:94328:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:94328:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:94329:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:94329:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:94328:mlx:core:mlx_fabric_open():172<info>
libfabric:94328:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:94328:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:94328:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:94329:mlx:core:mlx_fabric_open():172<info>
libfabric:94329:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:94329:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:94329:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:33998:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:33998:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:94328:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:94329:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:33998:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:33998:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:33997:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:33998:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:33997:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:33997:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:33997:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:33997:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:33998:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:33998:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:33997:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:33997:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:33997:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:33998:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:33998:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:33998:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:33997:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:33998:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:33997:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:33997:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:33998:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:33998:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
[0] MPI startup(): libfabric provider: mlx
[0] MPI startup(): detected mlx provider, set device name to "mlx_hcoll"
libfabric:33997:mlx:core:mlx_fabric_open():172<info>
libfabric:33997:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:33997:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:33997:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:33998:mlx:core:mlx_fabric_open():172<info>
libfabric:33998:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:33998:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:33998:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
[0] MPI startup(): max_ch4_vcis: 1, max_reg_eps 64, enable_sep 0, enable_shared_ctxs 0, do_av_insert 1
[0] MPI startup(): addrnamelen: 1024
libfabric:33997:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:33998:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:94328:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x15f8fb0
libfabric:94329:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x2020e00
libfabric:33997:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x1c3bf80
libfabric:33998:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x1d5be00
libfabric:33998:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:33998:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x1d5be00
libfabric:33997:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:33997:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x1c3bf80
libfabric:94328:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:94329:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:94329:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x2020e00
libfabric:94328:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x15f8fb0
libfabric:94328:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x173e190
libfabric:33997:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x19d2da0
libfabric:33997:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x19d2da0
libfabric:94328:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x173e190
[0] MPI startup(): Load tuning file: "/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1/etc/tuning_generic_shm-ofi_mlx_hcoll.dat"
[eu-g1-019-4:33997:0:33997] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
[eu-g1-019-4:33998:0:33998] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
[eu-g1-021-4:94328:0:94328] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
[eu-g1-021-4:94329:0:94329] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x1c0)
==== backtrace (tid: 33997) ====
0 0x0000000000291441 MPIDIG_dequeue_unexp() /build/impi/_buildspace/release/../../src/mpid/ch4/src/intel/ch4r_unexp_hashtable.c:417
1 0x00000000003d3cc0 MPIDIG_do_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/generic/mpidig_recv.h:135
2 0x000000000040356d MPIDIG_mpi_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/generic/mpidig_recv.h:336
3 0x000000000040356d MPIDI_POSIX_mpi_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/shm/src/../src/../posix/posix_recv.h:60
4 0x000000000040356d MPIDI_SHM_mpi_irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/shm/src/../src/shm_p2p.h:328
5 0x000000000040356d MPIDI_irecv_unsafe() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_recv.h:235
6 0x000000000040356d MPIDI_irecv_safe() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_recv.h:558
7 0x000000000040356d MPID_Irecv() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_recv.h:791
8 0x000000000040356d MPIC_Irecv() /build/impi/_buildspace/release/../../src/mpi/coll/helper_fns.c:625
9 0x00000000003c1bee recv_nb() /build/impi/_buildspace/release/../../src/mpid/common/hcoll/hcoll_rte.c:233
10 0x000000000001b544 comm_allreduce_hcolrte_generic() common_allreduce.c:0
11 0x000000000001bd1b comm_allreduce_hcolrte() ???:0
12 0x000000000001a9c1 hmca_bcol_ucx_p2p_init_query() ???:0
13 0x00000000000bd02c hmca_bcol_base_init() ???:0
14 0x0000000000066c88 hmca_coll_ml_init_query() ???:0
15 0x00000000000b3992 hcoll_init_with_opts() ???:0
16 0x00000000003c0493 hcoll_initialize() /build/impi/_buildspace/release/../../src/mpid/common/hcoll/hcoll_init.c:106
17 0x00000000003c0493 hcoll_comm_create() /build/impi/_buildspace/release/../../src/mpid/common/hcoll/hcoll_init.c:144
18 0x00000000006a0b01 MPIDI_OFI_mpi_comm_create_hook() /build/impi/_buildspace/release/../../src/mpid/ch4/netmod/ofi/ofi_comm.c:216
19 0x00000000001ca555 MPID_Comm_create_hook() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_comm.c:198
20 0x0000000000317bdb MPIR_Comm_commit_internal() /build/impi/_buildspace/release/../../src/mpi/comm/commutil.c:353
21 0x0000000000317bdb MPIR_Comm_commit() /build/impi/_buildspace/release/../../src/mpi/comm/commutil.c:530
22 0x0000000000210e4b init_builtin_comms() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_init.c:1113
23 0x0000000000210e4b MPID_Init() /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_init.c:1359
24 0x000000000052a1a3 MPIR_Init_thread() /build/impi/_buildspace/release/../../src/mpi/init/initthread.c:142
25 0x000000000052971b PMPI_Init() /build/impi/_buildspace/release/../../src/mpi/init/init.c:140
26 0x0000000000400eb3 main() ???:0
27 0x0000000000022555 __libc_start_main() ???:0
28 0x0000000000400db9 _start() ???:0
==== backtrace (tid: 33998) ====
==== backtrace (tid: 94328) ====
==== backtrace (tid: 94329) ====
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 33997 RUNNING AT eu-g1-019-4
= KILLED BY SIGNAL: 11 (Segmentation fault)
= RANK 1 PID 33998 RUNNING AT eu-g1-019-4
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
>>"Are those infiniband cards from Mellanox not supported?"
Mellanox ConnectX-6 infiniband card is supported by Intel MPI.
>>"I try to run the example on 4 cores (2 cores on each server)."
Could you please elaborate on this statement? Do 2 servers refers to 2 nodes?
If you want to run the mpi program on cluster, could you please try with the below command:
$ mpirun -n <number-of-processes> -ppn <processes-per-node> -hosts host1,host2 ./myprog
For the above command, you can use the "-f hostfile" instead of mentioning the "-hosts". For more information refer to the below link:https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/running-applications/running-an-mpi-program.html
Could you please try setting I_MPI_FABRICS=ofi and try to run the application? Please let us know if it works.
Could you please provide the OS & CPU details?
Thanks & Regards,
Hemanth
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for your reply.
Our cluster has around 3000 compute nodes (several different hardware generations). I was requesting 4 CPU cores from the IBM LSF batch system and requested -R "span[ptile=2]" to make sure I get my 4 cores allocated on two compute nodes (two cores on each compute node), since I want to test if internode communication works fine.
The batch system automatically sets the -n <number of processors> option of mpirun and also takes care of providing the hostlist and the number of cores per host automatically to Intel MPI. This works like a charm since more than 10 years among a wide variety of Intel MPI versions. So far it was not necessary to explicitly set
I_MPI_HYDRA_BOOTSTRAP=lsf
I just tried rerunning the example with setting this variable explicitly and get the same result as shown above in my previous post.
Please find below the logs (again with increased loglevel):
Sender: LSF System <lsfadmin@eu-g1-017-2>
Subject: Job 207169474: <I_MPI_FABRICS=ofi I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun ./hello> in cluster <euler> Done
Job <I_MPI_FABRICS=ofi I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun ./hello> was submitted from host <eu-login-12> by user <sfux> in cluster <euler> at Fri Mar 4 14:11:15 2022
Job was executed on host(s) <2*eu-g1-017-2>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Fri Mar 4 14:11:54 2022
<2*eu-g1-015-3>
Started at Fri Mar 4 14:11:54 2022
Terminated at Fri Mar 4 14:12:37 2022
Results reported at Fri Mar 4 14:12:37 2022
Successfully completed.
CPU time : 2.64 sec.
Max Memory : 798 MB
Average Memory : -
Delta Memory : 7202.00 MB
Max Swap : -
Max Processes : -
Max Threads : -
Run time : 23 sec.
Turnaround time : 82 sec.
libfabric:125166:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:125166:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:125167:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:125167:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:19989:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:19989:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:19988:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:19988:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:125166:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:125166:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:125166:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:125167:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:125167:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:125167:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:19988:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:19988:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:19988:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:19989:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:19989:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:19989:core:mr:ofi_default_cache_size():78<info> default cache size=2112943968
libfabric:125166:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:125166:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:125166:verbs:fabric:verbs_devs_print():897<info> 10.205.73.86
libfabric:125166:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d2:346
libfabric:125167:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:125167:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:125167:verbs:fabric:verbs_devs_print():897<info> 10.205.73.86
libfabric:125167:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d2:346
libfabric:19988:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:19988:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:19988:verbs:fabric:verbs_devs_print():897<info> 10.205.73.79
libfabric:19988:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d2:426
libfabric:19989:verbs:fabric:verbs_devs_print():883<info> list of verbs devices found for FI_EP_MSG:
libfabric:19989:verbs:fabric:verbs_devs_print():887<info> #1 mlx5_0 - IPoIB addresses:
libfabric:19989:verbs:fabric:verbs_devs_print():897<info> 10.205.73.79
libfabric:19989:verbs:fabric:verbs_devs_print():897<info> fe80::ba59:9f03:d2:426
libfabric:125166:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:125167:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:19988:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:19989:verbs:fabric:vrb_get_device_attrs():618<info> device mlx5_0: first found active port is 1
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:125166:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:125167:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:19988:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:19989:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:125166:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:125167:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:19988:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:19989:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:125166:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:125166:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:125166:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:125167:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:125167:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:125167:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:125166:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:125167:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:125166:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:125166:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:125166:core:core:fi_getinfo_():1161<info> Since mlx can be used, psm3 has been skipped. To use psm3, please, set FI_PROVIDER=psm3
libfabric:125166:core:core:fi_getinfo_():1161<info> Since mlx can be used, verbs has been skipped. To use verbs, please, set FI_PROVIDER=verbs
libfabric:125166:core:core:fi_getinfo_():1161<info> Since mlx can be used, tcp has been skipped. To use tcp, please, set FI_PROVIDER=tcp
libfabric:125166:core:core:fi_getinfo_():1161<info> Since mlx can be used, sockets has been skipped. To use sockets, please, set FI_PROVIDER=sockets
libfabric:125166:core:core:fi_getinfo_():1161<info> Since mlx can be used, shm has been skipped. To use shm, please, set FI_PROVIDER=shm
libfabric:125167:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:125167:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:125167:core:core:fi_getinfo_():1161<info> Since mlx can be used, psm3 has been skipped. To use psm3, please, set FI_PROVIDER=psm3
libfabric:125167:core:core:fi_getinfo_():1161<info> Since mlx can be used, verbs has been skipped. To use verbs, please, set FI_PROVIDER=verbs
libfabric:125167:core:core:fi_getinfo_():1161<info> Since mlx can be used, tcp has been skipped. To use tcp, please, set FI_PROVIDER=tcp
libfabric:125167:core:core:fi_getinfo_():1161<info> Since mlx can be used, sockets has been skipped. To use sockets, please, set FI_PROVIDER=sockets
libfabric:125167:core:core:fi_getinfo_():1161<info> Since mlx can be used, shm has been skipped. To use shm, please, set FI_PROVIDER=shm
libfabric:125166:mlx:core:mlx_fabric_open():172<info>
libfabric:125166:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:125166:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:125166:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:125167:mlx:core:mlx_fabric_open():172<info>
libfabric:125167:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:125167:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:125167:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:19988:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:19988:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:19988:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:19989:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:19989:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:19989:mlx:core:mlx_getinfo():211<info> primary detected device: mlx5_0
libfabric:19988:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:19989:mlx:core:mlx_getinfo():254<info> used inject size = 1024
libfabric:19988:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:19988:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:19988:core:core:fi_getinfo_():1161<info> Since mlx can be used, psm3 has been skipped. To use psm3, please, set FI_PROVIDER=psm3
libfabric:19988:core:core:fi_getinfo_():1161<info> Since mlx can be used, verbs has been skipped. To use verbs, please, set FI_PROVIDER=verbs
libfabric:19988:core:core:fi_getinfo_():1161<info> Since mlx can be used, tcp has been skipped. To use tcp, please, set FI_PROVIDER=tcp
libfabric:19988:core:core:fi_getinfo_():1161<info> Since mlx can be used, sockets has been skipped. To use sockets, please, set FI_PROVIDER=sockets
libfabric:19988:core:core:fi_getinfo_():1161<info> Since mlx can be used, shm has been skipped. To use shm, please, set FI_PROVIDER=shm
libfabric:19989:mlx:core:mlx_getinfo():301<info> Loaded MLX version 1.11.1
libfabric:19989:mlx:core:mlx_getinfo():348<warn> MLX: spawn support 0
libfabric:19989:core:core:fi_getinfo_():1161<info> Since mlx can be used, psm3 has been skipped. To use psm3, please, set FI_PROVIDER=psm3
libfabric:19989:core:core:fi_getinfo_():1161<info> Since mlx can be used, verbs has been skipped. To use verbs, please, set FI_PROVIDER=verbs
libfabric:19989:core:core:fi_getinfo_():1161<info> Since mlx can be used, tcp has been skipped. To use tcp, please, set FI_PROVIDER=tcp
libfabric:19989:core:core:fi_getinfo_():1161<info> Since mlx can be used, sockets has been skipped. To use sockets, please, set FI_PROVIDER=sockets
libfabric:19989:core:core:fi_getinfo_():1161<info> Since mlx can be used, shm has been skipped. To use shm, please, set FI_PROVIDER=shm
libfabric:19988:mlx:core:mlx_fabric_open():172<info>
libfabric:19988:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:19988:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:19988:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:19989:mlx:core:mlx_fabric_open():172<info>
libfabric:19989:core:core:fi_fabric_():1423<info> Opened fabric: mlx
libfabric:19989:mlx:core:ofi_check_rx_attr():786<info> Tx only caps ignored in Rx caps
libfabric:19989:mlx:core:ofi_check_tx_attr():884<info> Rx only caps ignored in Tx caps
libfabric:125166:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:125167:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:19988:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:19989:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:125166:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x1925720
libfabric:125167:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x2884190
libfabric:19988:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x2a79f70
libfabric:19989:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x2875190
libfabric:19988:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:19988:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x2a79f70
libfabric:19989:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:19989:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x2875190
libfabric:125166:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:125167:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:125167:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x2884190
libfabric:125166:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x1925720
libfabric:125166:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x19b1040
libfabric:125166:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x19b1040
[0] MPI startup(): Load tuning file: "/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1/etc/tuning_generic_ofi_mlx_hcoll.dat"
libfabric:19988:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x2b48a10
libfabric:19988:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x2b48a10
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 125166 eu-g1-017-2 {44}
[0] MPI startup(): 1 125167 eu-g1-017-2 {45}
[0] MPI startup(): 2 19988 eu-g1-015-3 {44}
[0] MPI startup(): 3 19989 eu-g1-015-3 {45}
[0] MPI startup(): I_MPI_ROOT=/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_RMK=lsf
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_FABRICS=ofi
[0] MPI startup(): I_MPI_DEBUG=30
[0] MPI startup(): threading: mode: direct
[0] MPI startup(): threading: vcis: 1
[0] MPI startup(): threading: app_threads: 1
[0] MPI startup(): threading: runtime: generic
[0] MPI startup(): threading: is_threaded: 0
[0] MPI startup(): threading: async_progress: 0
[0] MPI startup(): threading: num_pools: 64
[0] MPI startup(): threading: lock_level: global
[0] MPI startup(): threading: enable_sep: 0
[0] MPI startup(): threading: direct_recv: 1
[0] MPI startup(): threading: zero_op_flags: 1
[0] MPI startup(): threading: num_am_buffers: 1
[0] MPI startup(): threading: library is built with per-vci thread granularity
Hello world from processor eu-g1-017-2, rank 1 out of 4 processors
Hello world from processor eu-g1-017-2, rank 0 out of 4 processors
Hello world from processor eu-g1-015-3, rank 2 out of 4 processors
Hello world from processor eu-g1-015-3, rank 3 out of 4 processors
libfabric:125166:psm3:core:psmx3_fini():643<info>
libfabric:19988:psm3:core:psmx3_fini():643<info>
libfabric:125167:psm3:core:psmx3_fini():643<info>
libfabric:19989:psm3:core:psmx3_fini():643<info>
I also reran the same without increased log level and now the memory consumption looks much better and no error is shown any more:
Subject: Job 207170114: <I_MPI_FABRICS=ofi mpirun ./hello> in cluster <euler> Done
Job <I_MPI_FABRICS=ofi mpirun ./hello> was submitted from host <eu-login-12> by user <sfux> in cluster <euler> at Fri Mar 4 14:16:43 2022
Job was executed on host(s) <2*eu-g1-020-2>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Fri Mar 4 14:17:14 2022
<2*eu-g1-013-4>
</cluster/home/sfux> was used as the home directory.
</cluster/home/sfux/test/intelmpi> was used as the working directory.
Started at Fri Mar 4 14:17:14 2022
Terminated at Fri Mar 4 14:17:52 2022
Results reported at Fri Mar 4 14:17:52 2022
Your job looked like:
# LSBATCH: User input
Resource usage summary:
CPU time : 2.46 sec.
Max Memory : 798 MB
Average Memory : -
Total Requested Memory : 8000.00 MB
Max Swap : -
Max Processes : -
Max Threads : -
Run time : 40 sec.
Turnaround time : 69 sec.
The output (if any) follows:
Hello world from processor eu-g1-020-2, rank 1 out of 4 processors
Hello world from processor eu-g1-020-2, rank 0 out of 4 processors
Hello world from processor eu-g1-013-4, rank 2 out of 4 processors
Hello world from processor eu-g1-013-4, rank 3 out of 4 processors
I was using shm:ofi, because
states that this is the default for regular mode. Would you recommend to use I_MPI_FABRICS=ofi in general for such a setup that I am testing? How is then intranode communication handled when one does not specify shm at all?
OS: CentOS Linux release 7.9.2009 (Core)
Kernel: Linux eu-login-12 3.10.0-1160.45.1.el7.x86_64 #1 SMP Wed Oct 13 17:20:51 UTC 2021 x86_64 GNU/Linux
The nodes that I am testing with have two AMD EPYC 7742 CPUs with 64 cores each.
Again Thank you very much for your help.
Best regards
Sam
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Dear Members,
I'm working on the cluster managed by Sam that reported this issue. Setting I_MPI_FABRICS=ofi didn't solve the problem, see attached logs with different level of verbosity. It seems that the problem is erratic because some of our jobs worked fine, as the one reported by Sam above.
Q
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Just a comment regarding the specs of the server where @qumale was running the job that produced lsf_207702449.out.txt and lsf_207705698.err.txt:
Our servers with hostnames eu-a6-* have the following specs:
- Two 12-core Intel Xeon Gold 5118 processors (2.3 GHz nominal, 3.2 GHz peak)
- 96 GB of DDR4 memory clocked at 2400 MHz
And the Infiniband network cards in those servers:
$ ibv_devinfo
hca_id: mlx5_0
transport: InfiniBand (0)
fw_ver: 12.23.1020
node_guid: 9440:c9ff:ff71:48e8
sys_image_guid: 9440:c9ff:ff71:48e8
vendor_id: 0x02c9
vendor_part_id: 4115
hw_ver: 0x0
board_id: HPE2920111032
phys_port_cnt: 1
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
active_mtu: 4096 (5)
sm_lid: 3
port_lid: 297
port_lmc: 0x00
link_layer: InfiniBand
hca_id: mlx5_1
fw_ver: 12.23.1020
node_guid: 9440:c9ff:ff71:48e9
vendor_id: 0x02c9
hw_ver: 0x0
phys_port_cnt: 1
port: 1
state: PORT_DOWN (1)
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 65535
port_lmc: 0x00
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Could you please confirm which CPU you are using (two AMD EPYC 7742 CPUs or Intel Xeon Gold 5118)?
Thanks & Regards,
Hemanth.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
@HemanthCH_Intel Thank you for your reply. We have several different hardware generations in our HPC cluster.
All the logs that I provided above are from jobs ran on servers with two AMD EPYC 7742 CPUs, each of them having 64 cores. The logs that @qumale provided are from jobs ran on servers with two Intel Xeon Gold 5118.
We can also run the same example on other servers with two 18-core Intel Xeon Gold 6150 processors if this helps.
I think the problem is not depending on the CPU but rather on the infiniband network card.
Best regards
Sam
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Sam,
Could you please provide the sample reproducer code and steps to reproduce your issue at our end?
Thanks & Regards,
Hemanth.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Hemanth,
The reproduce code is already given in the initial post of this thread (it is the hello.c code).
We used the following commands:
FI_PROVIDER=mlx I_MPI_FABRICS=shm:ofi mpirun ./hello
-> fails on the node with AMD EPYC 7742 CPUs
I_MPI_FABRICS=shm:ofi I_MPI_OFI_PROVIDER=mlx mpirun ./hello
-> worked when running on 4 AMD EPYC 7742 cores
-> worked when running on 4 Intel Xeon Gold 6150 cores
-> worked when running on 4 Intel Xeon Gold 5118 cores
-> failed when running on 256 AMD EPYC 7742 cores
-> failed when running on 256 Intel Xeon Gold 6150 cores
When repeating some of the tests, the last example listed worked when running on
* 256 AMD EPYC 7742
* 256 AMD EPYC 7H12
* 256 AMD EPYC 7663
But the memory consumption for these 3 examples reported by the IBM LSF batch system is between 70 GB and 100 GB which seems wrong for a 256 cores MPI hello world example.
Is there any general recommendation for the settings for Intel MPI with Mellanox ConnectX-6 Infiniband cards for the variables listed below?
* I_MPI_FABRICS
* I_MPI_OFI_PROVIDER
Can the variable FI_PROVIDER still be used or is it already deprecated?
And is there a similar page for Intel MPI 2021.5 as for Intel MPI 2019?
For the moment we don't put the Intel oneAPI 2022.1.2 installation into production on our cluster unless we can resolve the issues with IntelMPI.
Thank you for your help and best regards
Sam
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Could you please provide the output for the below commands from 256 Intel Xeon Gold 6150 cores :
ucx_info -d | grep Transport
ucx_info -v
Could you please provide the complete debug log using the below command:
I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 2 -ppn 2 ./a.out
Could you please try running the MPI program on:
1. Two nodes containing 2 Intel Xeon Gold 6150 cores &
2. Two nodes containing128 Intel Xeon Gold 6150 cores and let us know if issue exists or not?
Use the below command for launching an MPI program on a cluster:
I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 -f nodefile ./a.out
Thanks & Regards,
Hemanth
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Intel Xeon Gold 6150 has 18 cores and our eu-a6-* compute nodes have two of those CPUs per compute node, i.e., a total of 36 cores per compute node.
Please find below the output of the commands that you asked for:
[sfux@eu-a6-001-01 ~]$ module list
Currently Loaded Modules:
1) StdEnv 2) intel/2022.1.2
[sfux@eu-a6-001-01 ~]$ ucx_info -d | grep Transport
# Transport: posix
# Transport: sysv
# Transport: self
# Transport: tcp
# Transport: tcp
# Transport: tcp
# Transport: rc_verbs
# Transport: rc_mlx5
# Transport: dc_mlx5
# Transport: ud_verbs
# Transport: ud_mlx5
# Transport: cma
# Transport: knem
# Transport: xpmem
[sfux@eu-a6-001-01 ~]$ ucx_info -v
# UCT version=1.11.1 revision c58db6b
# configured with: --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu --program-prefix= --disable-dependency-tracking --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/var/lib --mandir=/usr/share/man --infodir=/usr/share/info --disable-optimizations --disable-logging --disable-debug --disable-assertions --enable-mt --disable-params-check --without-java --enable-cma --with-cuda --with-gdrcopy --with-verbs --with-knem --with-rdmacm --without-rocm --with-xpmem --without-fuse3 --without-ugni --with-cuda=/usr/local/cuda-11.2
As requested, I submitted the job requesting 2 cores on a single node:
[sfux@eu-login-16 intelmpi]$ bsub -n 2 -R "span[ptile=2] select[model==XeonGold_6150] rusage[mem=500]" I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 2 -ppn 2 ./hello
Generic job.
Job <211960558> is submitted to queue <hpc.4h>.
Please find below the corresponding logs:
[sfux@eu-login-16 intelmpi]$ cat lsf.o211960558
Sender: LSF System <lsfadmin@eu-a6-011-11>
Subject: Job 211960558: <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 2 -ppn 2 ./hello> in cluster <euler> Done
Job <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 2 -ppn 2 ./hello> was submitted from host <eu-login-16> by user <sfux> in cluster <euler> at Thu Mar 31 09:42:49 2022
Job was executed on host(s) <2*eu-a6-011-11>, in queue <hpc.4h>, as user <sfux> in cluster <euler> at Thu Mar 31 09:43:07 2022
Started at Thu Mar 31 09:43:07 2022
Terminated at Thu Mar 31 09:43:12 2022
Results reported at Thu Mar 31 09:43:12 2022
CPU time : 1.22 sec.
Max Memory : 200 MB
Average Memory : -
Total Requested Memory : 1000.00 MB
Delta Memory : 800.00 MB
Max Swap : -
Max Processes : -
Max Threads : -
Run time : 12 sec.
Turnaround time : 23 sec.
IPL WARN> Not all cpus are available, switch to I_MPI_PIN_ORDER=compact. (Total: 72 Available: 4)
[0] MPI startup(): shm segment size (1307 MB per rank) * (2 local ranks) = 2615 MB total
libfabric:72159:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:72159:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:72159:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:72159:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:72159:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:72159:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:72159:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:72159:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:72159:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:72159:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:72159:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:72159:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:72159:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
[0] MPI startup(): detected mlx provider, set device name to "mlx"
libfabric:72159:core:core:fi_fabric_():1423<info> Opened fabric: mlx
[0] MPI startup(): File "/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1/etc/tuning_skx_shm-ofi_mlx_10.dat" not found
[0] MPI startup(): Load tuning file: "/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1/etc/tuning_skx_shm-ofi.dat"
Hello world from processor eu-a6-011-11, rank 1 out of 2 processors
[0] MPI startup(): 0 72159 eu-a6-011-11 {0,36}
[0] MPI startup(): 1 72160 eu-a6-011-11 {9,45}
[0] MPI startup(): I_MPI_DEBUG=40
Hello world from processor eu-a6-011-11, rank 0 out of 2 processors
Job on 4 cores (2 per host):
[sfux@eu-login-16 intelmpi]$ bsub -n 4 -R "span[ptile=2] select[model==XeonGold_6150] rusage[mem=500]" I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello
Generic job.
Job <211966082> is submitted to queue <hpc.4h>.
Please find the corresponding logs below:
[sfux@eu-login-16 intelmpi]$ cat lsf.o211966082
Sender: LSF System <lsfadmin@eu-a6-009-20>
Subject: Job 211966082: <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> in cluster <euler> Done
Job <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> was submitted from host <eu-login-16> by user <sfux> in cluster <euler> at Thu Mar 31 10:48:04 2022
Job was executed on host(s) <2*eu-a6-009-20>, in queue <hpc.4h>, as user <sfux> in cluster <euler> at Thu Mar 31 10:48:46 2022
<2*eu-a6-009-22>
Started at Thu Mar 31 10:48:46 2022
Terminated at Thu Mar 31 10:48:52 2022
Results reported at Thu Mar 31 10:48:52 2022
CPU time : 6.00 sec.
Max Memory : 392 MB
Average Memory : 1.00 MB
Total Requested Memory : 2000.00 MB
Delta Memory : 1608.00 MB
Max Swap : -
Max Processes : 1
Max Threads : 1
Run time : 1 sec.
Turnaround time : 48 sec.
[2] MPI startup(): shm segment size (1307 MB per rank) * (2 local ranks) = 2615 MB total
libfabric:54643:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:54643:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:54643:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:54643:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:54643:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:54643:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:54643:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:54643:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:54643:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:54643:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:54643:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:54643:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:54643:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:54643:core:core:fi_fabric_():1423<info> Opened fabric: mlx
Hello world from processor eu-a6-009-20, rank 1 out of 4 processors
Hello world from processor eu-a6-009-22, rank 3 out of 4 processors
[0] MPI startup(): 0 54643 eu-a6-009-20 {16,52}
[0] MPI startup(): 1 54644 eu-a6-009-20 {17,53}
[0] MPI startup(): 2 38880 eu-a6-009-22 {0,36}
[0] MPI startup(): 3 38881 eu-a6-009-22 {1,37}
[0] MPI startup(): I_MPI_ROOT=/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1Hello world from processor eu-a6-009-22, rank 2 out of 4 processors
Hello world from processor eu-a6-009-20, rank 0 out of 4 processors
I submitted the last job with 252 instead of 256 cores (as the nodes have 36 cores per host and I would like to use whole compute nodes):
[sfux@eu-login-16 intelmpi]$ bsub -n 252 -R "span[ptile=36] select[model==XeonGold_6150] rusage[mem=500]" I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 252 -ppn 36 ./hello
Generic job.
Job <211966180> is submitted to queue <hpc.4h>.
[sfux@eu-login-16 intelmpi]$ cat lsf.o211966180
Sender: LSF System <lsfadmin@eu-a6-009-23>
Subject: Job 211966180: <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 252 -ppn 36 ./hello> in cluster <euler> Done
Job <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 252 -ppn 36 ./hello> was submitted from host <eu-login-16> by user <sfux> in cluster <euler> at Thu Mar 31 10:51:04 2022
Job was executed on host(s) <36*eu-a6-009-23>, in queue <hpc.4h>, as user <sfux> in cluster <euler> at Thu Mar 31 10:51:15 2022
<36*eu-a6-006-01>
<36*eu-a6-006-03>
<36*eu-a6-006-19>
<36*eu-a6-005-17>
<36*eu-a6-005-01>
<36*eu-a6-005-21>
Started at Thu Mar 31 10:51:15 2022
Terminated at Thu Mar 31 10:51:26 2022
Results reported at Thu Mar 31 10:51:26 2022
CPU time : 1659.00 sec.
Max Memory : 33622 MB
Average Memory : 3322.00 MB
Total Requested Memory : 126000.00 MB
Delta Memory : 92378.00 MB
Max Swap : -
Max Processes : 43
Max Threads : 81
Run time : 18 sec.
Turnaround time : 22 sec.
[72] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
[144] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
[180] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
[0] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
[36] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
[108] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
[216] MPI startup(): shm segment size (125 MB per rank) * (36 local ranks) = 4512 MB total
libfabric:12737:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:12737:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:12737:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:12737:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:12737:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:12737:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:12737:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:12737:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:12737:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:12737:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:12737:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:12737:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:12737:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:12737:core:core:fi_fabric_():1423<info> Opened fabric: mlx
Hello world from processor eu-a6-005-17, rank 161 out of 252 processors
Hello world from processor eu-a6-005-17, rank 167 out of 252 processors
Hello world from processor eu-a6-005-17, rank 175 out of 252 processors
Hello world from processor eu-a6-005-17, rank 177 out of 252 processors
Hello world from processor eu-a6-005-17, rank 179 out of 252 processors
Hello world from processor eu-a6-005-17, rank 147 out of 252 processors
Hello world from processor eu-a6-005-17, rank 149 out of 252 processors
Hello world from processor eu-a6-005-17, rank 151 out of 252 processors
Hello world from processor eu-a6-005-17, rank 153 out of 252 processors
Hello world from processor eu-a6-005-17, rank 155 out of 252 processors
Hello world from processor eu-a6-005-17, rank 157 out of 252 processors
Hello world from processor eu-a6-005-17, rank 159 out of 252 processors
Hello world from processor eu-a6-005-17, rank 163 out of 252 processors
Hello world from processor eu-a6-005-17, rank 165 out of 252 processors
Hello world from processor eu-a6-005-17, rank 169 out of 252 processors
Hello world from processor eu-a6-005-17, rank 173 out of 252 processors
Hello world from processor eu-a6-005-17, rank 145 out of 252 processors
Hello world from processor eu-a6-005-17, rank 171 out of 252 processors
Hello world from processor eu-a6-005-17, rank 158 out of 252 processors
Hello world from processor eu-a6-005-17, rank 150 out of 252 processors
Hello world from processor eu-a6-005-17, rank 170 out of 252 processors
Hello world from processor eu-a6-005-17, rank 174 out of 252 processors
Hello world from processor eu-a6-005-17, rank 162 out of 252 processors
Hello world from processor eu-a6-005-17, rank 178 out of 252 processors
Hello world from processor eu-a6-005-17, rank 164 out of 252 processors
Hello world from processor eu-a6-005-17, rank 166 out of 252 processors
Hello world from processor eu-a6-005-17, rank 148 out of 252 processors
Hello world from processor eu-a6-005-17, rank 172 out of 252 processors
Hello world from processor eu-a6-005-17, rank 168 out of 252 processors
Hello world from processor eu-a6-005-17, rank 154 out of 252 processors
Hello world from processor eu-a6-005-17, rank 146 out of 252 processors
Hello world from processor eu-a6-005-17, rank 156 out of 252 processors
Hello world from processor eu-a6-005-17, rank 152 out of 252 processors
Hello world from processor eu-a6-006-01, rank 43 out of 252 processors
Hello world from processor eu-a6-006-01, rank 45 out of 252 processors
Hello world from processor eu-a6-006-01, rank 49 out of 252 processors
Hello world from processor eu-a6-006-01, rank 53 out of 252 processors
Hello world from processor eu-a6-006-01, rank 55 out of 252 processors
Hello world from processor eu-a6-006-01, rank 59 out of 252 processors
Hello world from processor eu-a6-006-01, rank 61 out of 252 processors
Hello world from processor eu-a6-006-01, rank 65 out of 252 processors
Hello world from processor eu-a6-006-01, rank 67 out of 252 processors
Hello world from processor eu-a6-006-01, rank 69 out of 252 processors
Hello world from processor eu-a6-006-01, rank 39 out of 252 processors
Hello world from processor eu-a6-006-01, rank 41 out of 252 processors
Hello world from processor eu-a6-006-01, rank 47 out of 252 processors
Hello world from processor eu-a6-006-01, rank 51 out of 252 processors
Hello world from processor eu-a6-006-01, rank 57 out of 252 processors
Hello world from processor eu-a6-006-01, rank 63 out of 252 processors
Hello world from processor eu-a6-006-01, rank 71 out of 252 processors
Hello world from processor eu-a6-006-19, rank 109 out of 252 processors
Hello world from processor eu-a6-006-19, rank 111 out of 252 processors
Hello world from processor eu-a6-006-19, rank 123 out of 252 processors
Hello world from processor eu-a6-006-19, rank 127 out of 252 processors
Hello world from processor eu-a6-006-19, rank 129 out of 252 processors
Hello world from processor eu-a6-006-19, rank 131 out of 252 processors
Hello world from processor eu-a6-006-19, rank 133 out of 252 processors
Hello world from processor eu-a6-006-19, rank 135 out of 252 processors
Hello world from processor eu-a6-006-19, rank 137 out of 252 processors
Hello world from processor eu-a6-006-19, rank 139 out of 252 processors
Hello world from processor eu-a6-006-19, rank 141 out of 252 processors
Hello world from processor eu-a6-006-19, rank 143 out of 252 processors
Hello world from processor eu-a6-006-19, rank 113 out of 252 processors
Hello world from processor eu-a6-006-19, rank 115 out of 252 processors
Hello world from processor eu-a6-006-19, rank 117 out of 252 processors
Hello world from processor eu-a6-006-19, rank 119 out of 252 processors
Hello world from processor eu-a6-006-19, rank 121 out of 252 processors
Hello world from processor eu-a6-006-19, rank 125 out of 252 processors
Hello world from processor eu-a6-006-01, rank 37 out of 252 processors
Hello world from processor eu-a6-006-01, rank 50 out of 252 processors
Hello world from processor eu-a6-006-01, rank 42 out of 252 processors
Hello world from processor eu-a6-006-01, rank 70 out of 252 processors
Hello world from processor eu-a6-006-01, rank 62 out of 252 processors
Hello world from processor eu-a6-006-19, rank 126 out of 252 processors
Hello world from processor eu-a6-006-19, rank 124 out of 252 processors
Hello world from processor eu-a6-006-01, rank 58 out of 252 processors
Hello world from processor eu-a6-006-19, rank 114 out of 252 processors
Hello world from processor eu-a6-006-01, rank 60 out of 252 processors
Hello world from processor eu-a6-006-01, rank 68 out of 252 processors
Hello world from processor eu-a6-005-17, rank 144 out of 252 processors
Hello world from processor eu-a6-006-01, rank 38 out of 252 processors
Hello world from processor eu-a6-006-01, rank 36 out of 252 processors
Hello world from processor eu-a6-006-01, rank 66 out of 252 processors
Hello world from processor eu-a6-006-01, rank 54 out of 252 processors
Hello world from processor eu-a6-006-01, rank 52 out of 252 processors
Hello world from processor eu-a6-006-19, rank 130 out of 252 processors
Hello world from processor eu-a6-006-19, rank 118 out of 252 processors
Hello world from processor eu-a6-006-19, rank 132 out of 252 processors
Hello world from processor eu-a6-006-19, rank 134 out of 252 processors
Hello world from processor eu-a6-006-19, rank 110 out of 252 processors
Hello world from processor eu-a6-006-19, rank 138 out of 252 processors
Hello world from processor eu-a6-006-19, rank 122 out of 252 processors
Hello world from processor eu-a6-006-19, rank 142 out of 252 processors
Hello world from processor eu-a6-006-19, rank 136 out of 252 processors
Hello world from processor eu-a6-006-19, rank 140 out of 252 processors
Hello world from processor eu-a6-006-19, rank 120 out of 252 processors
Hello world from processor eu-a6-006-01, rank 46 out of 252 processors
Hello world from processor eu-a6-006-01, rank 44 out of 252 processors
Hello world from processor eu-a6-006-19, rank 116 out of 252 processors
Hello world from processor eu-a6-006-19, rank 112 out of 252 processors
Hello world from processor eu-a6-006-01, rank 56 out of 252 processors
Hello world from processor eu-a6-005-21, rank 223 out of 252 processors
Hello world from processor eu-a6-005-21, rank 235 out of 252 processors
Hello world from processor eu-a6-005-21, rank 247 out of 252 processors
Hello world from processor eu-a6-005-21, rank 231 out of 252 processors
Hello world from processor eu-a6-005-21, rank 227 out of 252 processors
Hello world from processor eu-a6-005-21, rank 245 out of 252 processors
Hello world from processor eu-a6-005-21, rank 241 out of 252 processors
Hello world from processor eu-a6-005-21, rank 251 out of 252 processors
Hello world from processor eu-a6-005-21, rank 225 out of 252 processors
Hello world from processor eu-a6-005-21, rank 219 out of 252 processors
Hello world from processor eu-a6-005-21, rank 233 out of 252 processors
Hello world from processor eu-a6-005-21, rank 243 out of 252 processors
Hello world from processor eu-a6-005-21, rank 221 out of 252 processors
Hello world from processor eu-a6-005-21, rank 249 out of 252 processors
Hello world from processor eu-a6-005-21, rank 237 out of 252 processors
Hello world from processor eu-a6-005-21, rank 239 out of 252 processors
Hello world from processor eu-a6-005-21, rank 229 out of 252 processors
Hello world from processor eu-a6-005-21, rank 217 out of 252 processors
Hello world from processor eu-a6-005-01, rank 195 out of 252 processors
Hello world from processor eu-a6-005-01, rank 197 out of 252 processors
Hello world from processor eu-a6-005-01, rank 201 out of 252 processors
Hello world from processor eu-a6-005-01, rank 213 out of 252 processors
Hello world from processor eu-a6-005-01, rank 183 out of 252 processors
Hello world from processor eu-a6-005-01, rank 185 out of 252 processors
Hello world from processor eu-a6-005-01, rank 187 out of 252 processors
Hello world from processor eu-a6-005-01, rank 189 out of 252 processors
Hello world from processor eu-a6-005-01, rank 191 out of 252 processors
Hello world from processor eu-a6-005-01, rank 193 out of 252 processors
Hello world from processor eu-a6-005-01, rank 199 out of 252 processors
Hello world from processor eu-a6-005-01, rank 203 out of 252 processors
Hello world from processor eu-a6-005-01, rank 205 out of 252 processors
Hello world from processor eu-a6-005-01, rank 207 out of 252 processors
Hello world from processor eu-a6-005-01, rank 209 out of 252 processors
Hello world from processor eu-a6-005-01, rank 211 out of 252 processors
Hello world from processor eu-a6-005-01, rank 215 out of 252 processors
Hello world from processor eu-a6-005-01, rank 181 out of 252 processors
Hello world from processor eu-a6-005-21, rank 250 out of 252 processors
Hello world from processor eu-a6-005-21, rank 238 out of 252 processors
Hello world from processor eu-a6-005-21, rank 246 out of 252 processors
Hello world from processor eu-a6-005-21, rank 244 out of 252 processors
Hello world from processor eu-a6-005-21, rank 248 out of 252 processors
Hello world from processor eu-a6-005-21, rank 234 out of 252 processors
Hello world from processor eu-a6-005-21, rank 218 out of 252 processors
Hello world from processor eu-a6-005-21, rank 222 out of 252 processors
Hello world from processor eu-a6-005-21, rank 240 out of 252 processors
Hello world from processor eu-a6-005-21, rank 242 out of 252 processors
Hello world from processor eu-a6-005-21, rank 220 out of 252 processors
Hello world from processor eu-a6-005-21, rank 226 out of 252 processors
Hello world from processor eu-a6-005-21, rank 232 out of 252 processors
Hello world from processor eu-a6-005-21, rank 236 out of 252 processors
Hello world from processor eu-a6-005-01, rank 186 out of 252 processors
Hello world from processor eu-a6-005-01, rank 210 out of 252 processors
Hello world from processor eu-a6-005-01, rank 182 out of 252 processors
Hello world from processor eu-a6-005-01, rank 180 out of 252 processors
Hello world from processor eu-a6-005-21, rank 230 out of 252 processors
Hello world from processor eu-a6-005-21, rank 224 out of 252 processors
Hello world from processor eu-a6-005-21, rank 228 out of 252 processors
Hello world from processor eu-a6-005-21, rank 216 out of 252 processors
Hello world from processor eu-a6-005-01, rank 194 out of 252 processors
Hello world from processor eu-a6-005-01, rank 204 out of 252 processors
Hello world from processor eu-a6-005-01, rank 206 out of 252 processors
Hello world from processor eu-a6-005-01, rank 202 out of 252 processors
Hello world from processor eu-a6-005-01, rank 190 out of 252 processors
Hello world from processor eu-a6-005-01, rank 188 out of 252 processors
Hello world from processor eu-a6-005-17, rank 176 out of 252 processors
Hello world from processor eu-a6-005-01, rank 184 out of 252 processors
Hello world from processor eu-a6-005-17, rank 160 out of 252 processors
Hello world from processor eu-a6-005-01, rank 212 out of 252 processors
Hello world from processor eu-a6-005-01, rank 214 out of 252 processors
Hello world from processor eu-a6-005-01, rank 208 out of 252 processors
Hello world from processor eu-a6-005-01, rank 200 out of 252 processors
Hello world from processor eu-a6-005-01, rank 196 out of 252 processors
Hello world from processor eu-a6-005-01, rank 198 out of 252 processors
Hello world from processor eu-a6-005-01, rank 192 out of 252 processors
Hello world from processor eu-a6-006-19, rank 128 out of 252 processors
Hello world from processor eu-a6-009-23, rank 1 out of 252 processors
Hello world from processor eu-a6-009-23, rank 7 out of 252 processors
Hello world from processor eu-a6-009-23, rank 9 out of 252 processors
Hello world from processor eu-a6-009-23, rank 13 out of 252 processors
Hello world from processor eu-a6-009-23, rank 15 out of 252 processors
Hello world from processor eu-a6-009-23, rank 17 out of 252 processors
Hello world from processor eu-a6-009-23, rank 21 out of 252 processors
Hello world from processor eu-a6-009-23, rank 23 out of 252 processors
Hello world from processor eu-a6-009-23, rank 25 out of 252 processors
Hello world from processor eu-a6-009-23, rank 27 out of 252 processors
Hello world from processor eu-a6-009-23, rank 29 out of 252 processors
Hello world from processor eu-a6-009-23, rank 31 out of 252 processors
Hello world from processor eu-a6-009-23, rank 33 out of 252 processors
Hello world from processor eu-a6-009-23, rank 35 out of 252 processors
Hello world from processor eu-a6-009-23, rank 3 out of 252 processors
Hello world from processor eu-a6-009-23, rank 5 out of 252 processors
Hello world from processor eu-a6-009-23, rank 11 out of 252 processors
Hello world from processor eu-a6-009-23, rank 19 out of 252 processors
Hello world from processor eu-a6-006-03, rank 77 out of 252 processors
Hello world from processor eu-a6-006-03, rank 87 out of 252 processors
Hello world from processor eu-a6-006-03, rank 75 out of 252 processors
Hello world from processor eu-a6-006-03, rank 79 out of 252 processors
Hello world from processor eu-a6-006-03, rank 81 out of 252 processors
Hello world from processor eu-a6-006-03, rank 83 out of 252 processors
Hello world from processor eu-a6-006-03, rank 89 out of 252 processors
Hello world from processor eu-a6-006-03, rank 91 out of 252 processors
Hello world from processor eu-a6-006-03, rank 93 out of 252 processors
Hello world from processor eu-a6-006-03, rank 95 out of 252 processors
Hello world from processor eu-a6-006-03, rank 99 out of 252 processors
Hello world from processor eu-a6-006-03, rank 101 out of 252 processors
Hello world from processor eu-a6-006-03, rank 103 out of 252 processors
Hello world from processor eu-a6-006-03, rank 105 out of 252 processors
Hello world from processor eu-a6-006-03, rank 107 out of 252 processors
Hello world from processor eu-a6-006-03, rank 73 out of 252 processors
Hello world from processor eu-a6-006-03, rank 85 out of 252 processors
Hello world from processor eu-a6-006-03, rank 97 out of 252 processors
Hello world from processor eu-a6-009-23, rank 6 out of 252 processors
Hello world from processor eu-a6-006-19, rank 108 out of 252 processors
Hello world from processor eu-a6-006-03, rank 90 out of 252 processors
Hello world from processor eu-a6-006-03, rank 78 out of 252 processors
Hello world from processor eu-a6-009-23, rank 34 out of 252 processors
Hello world from processor eu-a6-006-03, rank 104 out of 252 processors
Hello world from processor eu-a6-006-03, rank 106 out of 252 processors
Hello world from processor eu-a6-006-03, rank 98 out of 252 processors
Hello world from processor eu-a6-006-01, rank 40 out of 252 processors
Hello world from processor eu-a6-006-01, rank 48 out of 252 processors
Hello world from processor eu-a6-006-03, rank 76 out of 252 processors
Hello world from processor eu-a6-009-23, rank 18 out of 252 processors
Hello world from processor eu-a6-009-23, rank 10 out of 252 processors
Hello world from processor eu-a6-006-03, rank 86 out of 252 processors
Hello world from processor eu-a6-006-03, rank 100 out of 252 processors
Hello world from processor eu-a6-006-03, rank 102 out of 252 processors
Hello world from processor eu-a6-006-03, rank 96 out of 252 processors
Hello world from processor eu-a6-009-23, rank 32 out of 252 processors
Hello world from processor eu-a6-006-03, rank 74 out of 252 processors
Hello world from processor eu-a6-006-03, rank 72 out of 252 processors
Hello world from processor eu-a6-006-03, rank 94 out of 252 processors
Hello world from processor eu-a6-006-03, rank 92 out of 252 processors
Hello world from processor eu-a6-006-03, rank 88 out of 252 processors
Hello world from processor eu-a6-009-23, rank 22 out of 252 processors
Hello world from processor eu-a6-009-23, rank 20 out of 252 processors
Hello world from processor eu-a6-006-03, rank 82 out of 252 processors
Hello world from processor eu-a6-009-23, rank 26 out of 252 processors
Hello world from processor eu-a6-006-03, rank 84 out of 252 processors
Hello world from processor eu-a6-006-03, rank 80 out of 252 processors
Hello world from processor eu-a6-006-01, rank 64 out of 252 processors
Hello world from processor eu-a6-009-23, rank 30 out of 252 processors
Hello world from processor eu-a6-009-23, rank 28 out of 252 processors
Hello world from processor eu-a6-009-23, rank 24 out of 252 processors
Hello world from processor eu-a6-009-23, rank 16 out of 252 processors
Hello world from processor eu-a6-009-23, rank 4 out of 252 processors
Hello world from processor eu-a6-009-23, rank 2 out of 252 processors
Hello world from processor eu-a6-009-23, rank 14 out of 252 processors
[0] MPI startup(): 0 12737 eu-a6-009-23 {0,36}
Hello world from processor eu-a6-009-23, rank 8 out of 252 processors
Hello world from processor eu-a6-009-23, rank 12 out of 252 processors
[0] MPI startup(): 1 12738 eu-a6-009-23 {1,37}
[0] MPI startup(): 2 12739 eu-a6-009-23 {2,38}
[0] MPI startup(): 3 12740 eu-a6-009-23 {3,39}
[0] MPI startup(): 4 12741 eu-a6-009-23 {4,40}
[0] MPI startup(): 5 12742 eu-a6-009-23 {5,41}
[0] MPI startup(): 6 12743 eu-a6-009-23 {6,42}
[0] MPI startup(): 7 12744 eu-a6-009-23 {7,43}
[0] MPI startup(): 8 12745 eu-a6-009-23 {8,44}
[0] MPI startup(): 9 12746 eu-a6-009-23 {9,45}
[0] MPI startup(): 10 12747 eu-a6-009-23 {10,46}
[0] MPI startup(): 11 12748 eu-a6-009-23 {11,47}
[0] MPI startup(): 12 12749 eu-a6-009-23 {12,48}
[0] MPI startup(): 13 12750 eu-a6-009-23 {13,49}
[0] MPI startup(): 14 12751 eu-a6-009-23 {14,50}
[0] MPI startup(): 15 12752 eu-a6-009-23 {15,51}
[0] MPI startup(): 16 12753 eu-a6-009-23 {16,52}
[0] MPI startup(): 17 12754 eu-a6-009-23 {17,53}
[0] MPI startup(): 18 12755 eu-a6-009-23 {18,54}
[0] MPI startup(): 19 12756 eu-a6-009-23 {19,55}
[0] MPI startup(): 20 12757 eu-a6-009-23 {20,56}
[0] MPI startup(): 21 12758 eu-a6-009-23 {21,57}
[0] MPI startup(): 22 12759 eu-a6-009-23 {22,58}
[0] MPI startup(): 23 12760 eu-a6-009-23 {23,59}
[0] MPI startup(): 24 12761 eu-a6-009-23 {24,60}
[0] MPI startup(): 25 12762 eu-a6-009-23 {25,61}
[0] MPI startup(): 26 12763 eu-a6-009-23 {26,62}
[0] MPI startup(): 27 12764 eu-a6-009-23 {27,63}
[0] MPI startup(): 28 12765 eu-a6-009-23 {28,64}
[0] MPI startup(): 29 12766 eu-a6-009-23 {29,65}
[0] MPI startup(): 30 12767 eu-a6-009-23 {30,66}
[0] MPI startup(): 31 12768 eu-a6-009-23 {31,67}
[0] MPI startup(): 32 12769 eu-a6-009-23 {32,68}
[0] MPI startup(): 33 12770 eu-a6-009-23 {33,69}
[0] MPI startup(): 34 12771 eu-a6-009-23 {34,70}
[0] MPI startup(): 35 12772 eu-a6-009-23 {35,71}
[0] MPI startup(): 36 73584 eu-a6-006-01 {0,36}
[0] MPI startup(): 37 73585 eu-a6-006-01 {1,37}
[0] MPI startup(): 38 73586 eu-a6-006-01 {2,38}
[0] MPI startup(): 39 73587 eu-a6-006-01 {3,39}
[0] MPI startup(): 40 73588 eu-a6-006-01 {4,40}
[0] MPI startup(): 41 73589 eu-a6-006-01 {5,41}
[0] MPI startup(): 42 73590 eu-a6-006-01 {6,42}
[0] MPI startup(): 43 73591 eu-a6-006-01 {7,43}
[0] MPI startup(): 44 73592 eu-a6-006-01 {8,44}
[0] MPI startup(): 45 73593 eu-a6-006-01 {9,45}
[0] MPI startup(): 46 73594 eu-a6-006-01 {10,46}
[0] MPI startup(): 47 73595 eu-a6-006-01 {11,47}
[0] MPI startup(): 48 73596 eu-a6-006-01 {12,48}
[0] MPI startup(): 49 73597 eu-a6-006-01 {13,49}
[0] MPI startup(): 50 73598 eu-a6-006-01 {14,50}
[0] MPI startup(): 51 73599 eu-a6-006-01 {15,51}
[0] MPI startup(): 52 73600 eu-a6-006-01 {16,52}
[0] MPI startup(): 53 73601 eu-a6-006-01 {17,53}
[0] MPI startup(): 54 73602 eu-a6-006-01 {18,54}
[0] MPI startup(): 55 73603 eu-a6-006-01 {19,55}
[0] MPI startup(): 56 73604 eu-a6-006-01 {20,56}
[0] MPI startup(): 57 73605 eu-a6-006-01 {21,57}
[0] MPI startup(): 58 73606 eu-a6-006-01 {22,58}
[0] MPI startup(): 59 73607 eu-a6-006-01 {23,59}
[0] MPI startup(): 60 73608 eu-a6-006-01 {24,60}
[0] MPI startup(): 61 73609 eu-a6-006-01 {25,61}
[0] MPI startup(): 62 73611 eu-a6-006-01 {26,62}
[0] MPI startup(): 63 73612 eu-a6-006-01 {27,63}
[0] MPI startup(): 64 73613 eu-a6-006-01 {28,64}
[0] MPI startup(): 65 73614 eu-a6-006-01 {29,65}
[0] MPI startup(): 66 73615 eu-a6-006-01 {30,66}
[0] MPI startup(): 67 73616 eu-a6-006-01 {31,67}
[0] MPI startup(): 68 73617 eu-a6-006-01 {32,68}
[0] MPI startup(): 69 73618 eu-a6-006-01 {33,69}
[0] MPI startup(): 70 73619 eu-a6-006-01 {34,70}
[0] MPI startup(): 71 73620 eu-a6-006-01 {35,71}
[0] MPI startup(): 72 54076 eu-a6-006-03 {0,36}
[0] MPI startup(): 73 54077 eu-a6-006-03 {1,37}
[0] MPI startup(): 74 54078 eu-a6-006-03 {2,38}
[0] MPI startup(): 75 54079 eu-a6-006-03 {3,39}
[0] MPI startup(): 76 54080 eu-a6-006-03 {4,40}
[0] MPI startup(): 77 54081 eu-a6-006-03 {5,41}
[0] MPI startup(): 78 54082 eu-a6-006-03 {6,42}
[0] MPI startup(): 79 54083 eu-a6-006-03 {7,43}
[0] MPI startup(): 80 54084 eu-a6-006-03 {8,44}
[0] MPI startup(): 81 54085 eu-a6-006-03 {9,45}
[0] MPI startup(): 82 54086 eu-a6-006-03 {10,46}
[0] MPI startup(): 83 54087 eu-a6-006-03 {11,47}
[0] MPI startup(): 84 54088 eu-a6-006-03 {12,48}
[0] MPI startup(): 85 54089 eu-a6-006-03 {13,49}
[0] MPI startup(): 86 54090 eu-a6-006-03 {14,50}
[0] MPI startup(): 87 54091 eu-a6-006-03 {15,51}
[0] MPI startup(): 88 54092 eu-a6-006-03 {16,52}
[0] MPI startup(): 89 54093 eu-a6-006-03 {17,53}
[0] MPI startup(): 90 54094 eu-a6-006-03 {18,54}
[0] MPI startup(): 91 54095 eu-a6-006-03 {19,55}
[0] MPI startup(): 92 54096 eu-a6-006-03 {20,56}
[0] MPI startup(): 93 54097 eu-a6-006-03 {21,57}
[0] MPI startup(): 94 54099 eu-a6-006-03 {22,58}
[0] MPI startup(): 95 54100 eu-a6-006-03 {23,59}
[0] MPI startup(): 96 54101 eu-a6-006-03 {24,60}
[0] MPI startup(): 97 54103 eu-a6-006-03 {25,61}
[0] MPI startup(): 98 54104 eu-a6-006-03 {26,62}
[0] MPI startup(): 99 54105 eu-a6-006-03 {27,63}
[0] MPI startup(): 100 54106 eu-a6-006-03 {28,64}
[0] MPI startup(): 101 54107 eu-a6-006-03 {29,65}
[0] MPI startup(): 102 54108 eu-a6-006-03 {30,66}
[0] MPI startup(): 103 54109 eu-a6-006-03 {31,67}
[0] MPI startup(): 104 54110 eu-a6-006-03 {32,68}
[0] MPI startup(): 105 54111 eu-a6-006-03 {33,69}
[0] MPI startup(): 106 54112 eu-a6-006-03 {34,70}
[0] MPI startup(): 107 54113 eu-a6-006-03 {35,71}
[0] MPI startup(): 108 62164 eu-a6-006-19 {0,36}
[0] MPI startup(): 109 62165 eu-a6-006-19 {1,37}
[0] MPI startup(): 110 62166 eu-a6-006-19 {2,38}
[0] MPI startup(): 111 62167 eu-a6-006-19 {3,39}
[0] MPI startup(): 112 62168 eu-a6-006-19 {4,40}
[0] MPI startup(): 113 62169 eu-a6-006-19 {5,41}
[0] MPI startup(): 114 62170 eu-a6-006-19 {6,42}
[0] MPI startup(): 115 62171 eu-a6-006-19 {7,43}
[0] MPI startup(): 116 62172 eu-a6-006-19 {8,44}
[0] MPI startup(): 117 62173 eu-a6-006-19 {9,45}
[0] MPI startup(): 118 62174 eu-a6-006-19 {10,46}
[0] MPI startup(): 119 62175 eu-a6-006-19 {11,47}
[0] MPI startup(): 120 62176 eu-a6-006-19 {12,48}
[0] MPI startup(): 121 62177 eu-a6-006-19 {13,49}
[0] MPI startup(): 122 62178 eu-a6-006-19 {14,50}
[0] MPI startup(): 123 62179 eu-a6-006-19 {15,51}
[0] MPI startup(): 124 62180 eu-a6-006-19 {16,52}
[0] MPI startup(): 125 62181 eu-a6-006-19 {17,53}
[0] MPI startup(): 126 62182 eu-a6-006-19 {18,54}
[0] MPI startup(): 127 62183 eu-a6-006-19 {19,55}
[0] MPI startup(): 128 62184 eu-a6-006-19 {20,56}
[0] MPI startup(): 129 62185 eu-a6-006-19 {21,57}
[0] MPI startup(): 130 62186 eu-a6-006-19 {22,58}
[0] MPI startup(): 131 62187 eu-a6-006-19 {23,59}
[0] MPI startup(): 132 62188 eu-a6-006-19 {24,60}
[0] MPI startup(): 133 62189 eu-a6-006-19 {25,61}
[0] MPI startup(): 134 62190 eu-a6-006-19 {26,62}
[0] MPI startup(): 135 62191 eu-a6-006-19 {27,63}
[0] MPI startup(): 136 62192 eu-a6-006-19 {28,64}
[0] MPI startup(): 137 62194 eu-a6-006-19 {29,65}
[0] MPI startup(): 138 62195 eu-a6-006-19 {30,66}
[0] MPI startup(): 139 62196 eu-a6-006-19 {31,67}
[0] MPI startup(): 140 62197 eu-a6-006-19 {32,68}
[0] MPI startup(): 141 62198 eu-a6-006-19 {33,69}
[0] MPI startup(): 142 62199 eu-a6-006-19 {34,70}
[0] MPI startup(): 143 62200 eu-a6-006-19 {35,71}
[0] MPI startup(): 144 24096 eu-a6-005-17 {0,36}
[0] MPI startup(): 145 24097 eu-a6-005-17 {1,37}
[0] MPI startup(): 146 24098 eu-a6-005-17 {2,38}
[0] MPI startup(): 147 24099 eu-a6-005-17 {3,39}
[0] MPI startup(): 148 24100 eu-a6-005-17 {4,40}
[0] MPI startup(): 149 24101 eu-a6-005-17 {5,41}
[0] MPI startup(): 150 24102 eu-a6-005-17 {6,42}
[0] MPI startup(): 151 24103 eu-a6-005-17 {7,43}
[0] MPI startup(): 152 24104 eu-a6-005-17 {8,44}
[0] MPI startup(): 153 24105 eu-a6-005-17 {9,45}
[0] MPI startup(): 154 24106 eu-a6-005-17 {10,46}
[0] MPI startup(): 155 24107 eu-a6-005-17 {11,47}
[0] MPI startup(): 156 24108 eu-a6-005-17 {12,48}
[0] MPI startup(): 157 24109 eu-a6-005-17 {13,49}
[0] MPI startup(): 158 24110 eu-a6-005-17 {14,50}
[0] MPI startup(): 159 24111 eu-a6-005-17 {15,51}
[0] MPI startup(): 160 24112 eu-a6-005-17 {16,52}
[0] MPI startup(): 161 24113 eu-a6-005-17 {17,53}
[0] MPI startup(): 162 24114 eu-a6-005-17 {18,54}
[0] MPI startup(): 163 24115 eu-a6-005-17 {19,55}
[0] MPI startup(): 164 24116 eu-a6-005-17 {20,56}
[0] MPI startup(): 165 24117 eu-a6-005-17 {21,57}
[0] MPI startup(): 166 24118 eu-a6-005-17 {22,58}
[0] MPI startup(): 167 24119 eu-a6-005-17 {23,59}
[0] MPI startup(): 168 24120 eu-a6-005-17 {24,60}
[0] MPI startup(): 169 24121 eu-a6-005-17 {25,61}
[0] MPI startup(): 170 24122 eu-a6-005-17 {26,62}
[0] MPI startup(): 171 24123 eu-a6-005-17 {27,63}
[0] MPI startup(): 172 24124 eu-a6-005-17 {28,64}
[0] MPI startup(): 173 24125 eu-a6-005-17 {29,65}
[0] MPI startup(): 174 24126 eu-a6-005-17 {30,66}
[0] MPI startup(): 175 24127 eu-a6-005-17 {31,67}
[0] MPI startup(): 176 24128 eu-a6-005-17 {32,68}
[0] MPI startup(): 177 24129 eu-a6-005-17 {33,69}
[0] MPI startup(): 178 24130 eu-a6-005-17 {34,70}
[0] MPI startup(): 179 24131 eu-a6-005-17 {35,71}
[0] MPI startup(): 180 31407 eu-a6-005-01 {0,36}
[0] MPI startup(): 181 31408 eu-a6-005-01 {1,37}
[0] MPI startup(): 182 31409 eu-a6-005-01 {2,38}
[0] MPI startup(): 183 31410 eu-a6-005-01 {3,39}
[0] MPI startup(): 184 31411 eu-a6-005-01 {4,40}
[0] MPI startup(): 185 31412 eu-a6-005-01 {5,41}
[0] MPI startup(): 186 31413 eu-a6-005-01 {6,42}
[0] MPI startup(): 187 31414 eu-a6-005-01 {7,43}
[0] MPI startup(): 188 31415 eu-a6-005-01 {8,44}
[0] MPI startup(): 189 31416 eu-a6-005-01 {9,45}
[0] MPI startup(): 190 31417 eu-a6-005-01 {10,46}
[0] MPI startup(): 191 31418 eu-a6-005-01 {11,47}
[0] MPI startup(): 192 31419 eu-a6-005-01 {12,48}
[0] MPI startup(): 193 31420 eu-a6-005-01 {13,49}
[0] MPI startup(): 194 31421 eu-a6-005-01 {14,50}
[0] MPI startup(): 195 31422 eu-a6-005-01 {15,51}
[0] MPI startup(): 196 31423 eu-a6-005-01 {16,52}
[0] MPI startup(): 197 31424 eu-a6-005-01 {17,53}
[0] MPI startup(): 198 31425 eu-a6-005-01 {18,54}
[0] MPI startup(): 199 31426 eu-a6-005-01 {19,55}
[0] MPI startup(): 200 31427 eu-a6-005-01 {20,56}
[0] MPI startup(): 201 31429 eu-a6-005-01 {21,57}
[0] MPI startup(): 202 31430 eu-a6-005-01 {22,58}
[0] MPI startup(): 203 31431 eu-a6-005-01 {23,59}
[0] MPI startup(): 204 31432 eu-a6-005-01 {24,60}
[0] MPI startup(): 205 31433 eu-a6-005-01 {25,61}
[0] MPI startup(): 206 31435 eu-a6-005-01 {26,62}
[0] MPI startup(): 207 31436 eu-a6-005-01 {27,63}
[0] MPI startup(): 208 31437 eu-a6-005-01 {28,64}
[0] MPI startup(): 209 31438 eu-a6-005-01 {29,65}
[0] MPI startup(): 210 31439 eu-a6-005-01 {30,66}
[0] MPI startup(): 211 31440 eu-a6-005-01 {31,67}
[0] MPI startup(): 212 31441 eu-a6-005-01 {32,68}
[0] MPI startup(): 213 31442 eu-a6-005-01 {33,69}
[0] MPI startup(): 214 31443 eu-a6-005-01 {34,70}
[0] MPI startup(): 215 31444 eu-a6-005-01 {35,71}
[0] MPI startup(): 216 11802 eu-a6-005-21 {0,36}
[0] MPI startup(): 217 11803 eu-a6-005-21 {1,37}
[0] MPI startup(): 218 11804 eu-a6-005-21 {2,38}
[0] MPI startup(): 219 11805 eu-a6-005-21 {3,39}
[0] MPI startup(): 220 11806 eu-a6-005-21 {4,40}
[0] MPI startup(): 221 11807 eu-a6-005-21 {5,41}
[0] MPI startup(): 222 11808 eu-a6-005-21 {6,42}
[0] MPI startup(): 223 11809 eu-a6-005-21 {7,43}
[0] MPI startup(): 224 11810 eu-a6-005-21 {8,44}
[0] MPI startup(): 225 11811 eu-a6-005-21 {9,45}
[0] MPI startup(): 226 11813 eu-a6-005-21 {10,46}
[0] MPI startup(): 227 11814 eu-a6-005-21 {11,47}
[0] MPI startup(): 228 11815 eu-a6-005-21 {12,48}
[0] MPI startup(): 229 11816 eu-a6-005-21 {13,49}
[0] MPI startup(): 230 11817 eu-a6-005-21 {14,50}
[0] MPI startup(): 231 11818 eu-a6-005-21 {15,51}
[0] MPI startup(): 232 11819 eu-a6-005-21 {16,52}
[0] MPI startup(): 233 11820 eu-a6-005-21 {17,53}
[0] MPI startup(): 234 11821 eu-a6-005-21 {18,54}
[0] MPI startup(): 235 11822 eu-a6-005-21 {19,55}
[0] MPI startup(): 236 11823 eu-a6-005-21 {20,56}
[0] MPI startup(): 237 11825 eu-a6-005-21 {21,57}
[0] MPI startup(): 238 11826 eu-a6-005-21 {22,58}
[0] MPI startup(): 239 11827 eu-a6-005-21 {23,59}
[0] MPI startup(): 240 11828 eu-a6-005-21 {24,60}
[0] MPI startup(): 241 11829 eu-a6-005-21 {25,61}
[0] MPI startup(): 242 11830 eu-a6-005-21 {26,62}
[0] MPI startup(): 243 11831 eu-a6-005-21 {27,63}
[0] MPI startup(): 244 11832 eu-a6-005-21 {28,64}
[0] MPI startup(): 245 11833 eu-a6-005-21 {29,65}
[0] MPI startup(): 246 11834 eu-a6-005-21 {30,66}
[0] MPI startup(): 247 11835 eu-a6-005-21 {31,67}
[0] MPI startup(): 248 11836 eu-a6-005-21 {32,68}
[0] MPI startup(): 249 11837 eu-a6-005-21 {33,69}
[0] MPI startup(): 250 11838 eu-a6-005-21 {34,70}
[0] MPI startup(): 251 11839 eu-a6-005-21 {35,71}
Hello world from processor eu-a6-009-23, rank 0 out of 252 processors
It seems that just setting FI_PROVIDER=mlx works fine on nodes with Intel Xeon Gold 6150 CPUs. I will test the same command also on our nodes with AMD EPYC 7742, 7H12 and 7763 and provide some logs.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I repeated the 4 cores job (2 cores per host) on our nodes with AMD CPUs. Please find below the results:
EPYC 7742:
[sfux@eu-g1-001-1 ~]$ ucx_info -d | grep Transport
# Transport: posix
# Transport: sysv
# Transport: self
# Transport: tcp
# Transport: tcp
# Transport: tcp
# Transport: cma
# Transport: knem
# Transport: xpmem
[sfux@eu-g1-001-1 ~]$ ucx_info -v
Job logs:
[sfux@eu-login-16 intelmpi]$ cat lsf.o211967271
Sender: LSF System <lsfadmin@eu-g1-018-1>
Subject: Job 211967271: <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> in cluster <euler> Exited
Job <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> was submitted from host <eu-login-16> by user <sfux> in cluster <euler> at Thu Mar 31 11:11:13 2022
Job was executed on host(s) <2*eu-g1-018-1>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Thu Mar 31 11:11:52 2022
<2*eu-g1-017-1>
Started at Thu Mar 31 11:11:52 2022
Terminated at Thu Mar 31 11:11:56 2022
Results reported at Thu Mar 31 11:11:56 2022
Exited with exit code 143.
CPU time : 2.00 sec.
Max Memory : 111 MB
Average Memory : -
Delta Memory : 1889.00 MB
Max Swap : -
Max Processes : -
Max Threads : -
Run time : 25 sec.
Turnaround time : 43 sec.
IPL WARN> Not all cpus are available, switch to I_MPI_PIN_ORDER=compact. (Total: 128 Available: 2)
[0] MPI startup(): Intel(R) MPI Library, Version 2021.5 Build 20211102 (id: 9279b7d62)
[0] MPI startup(): Copyright (C) 2003-2021 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): libfabric version: 1.13.2rc1-impi
libfabric:57679:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:57679:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:57679:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:57679:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:57679:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:57679:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:57679:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:57679:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:57679:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:57679:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:57679:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:57679:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:57679:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
[0] MPI startup(): libfabric provider: mlx
[0] MPI startup(): detected mlx provider, set device name to "mlx_hcoll"
libfabric:57679:core:core:fi_fabric_():1423<info> Opened fabric: mlx
[0] MPI startup(): max_ch4_vcis: 1, max_reg_eps 64, enable_sep 0, enable_shared_ctxs 0, do_av_insert 1
[0] MPI startup(): addrnamelen: 1024
[1648717915.161174] [eu-g1-017-1:56545:0] address.c:988 UCX ERROR address version mismatch: expected 0, actual 12
Abort(1090703) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(143)........:
MPID_Init(1310)..............:
MPIDI_OFI_mpi_init_hook(1974): OFI get address vector map failed
[1648717915.161174] [eu-g1-017-1:56546:0] address.c:988 UCX ERROR address version mismatch: expected 0, actual 12
-> Job failed
EPYC 7H12:
[sfux@eu-a2p-001 ~]$ module list
[sfux@eu-a2p-001 ~]$ ucx_info -d | grep Transport
# Transport: posix
# Transport: sysv
# Transport: self
# Transport: tcp
# Transport: tcp
# Transport: tcp
# Transport: cma
# Transport: knem
# Transport: xpmem
[sfux@eu-a2p-001 ~]$ ucx_info -v
Job logs:
[sfux@eu-login-16 intelmpi]$ cat lsf.o211967323
Sender: LSF System <lsfadmin@eu-a2p-077>
Subject: Job 211967323: <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> in cluster <euler> Done
Job <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> was submitted from host <eu-login-16> by user <sfux> in cluster <euler> at Thu Mar 31 11:11:31 2022
Job was executed on host(s) <2*eu-a2p-077>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Thu Mar 31 11:11:52 2022
<2*eu-a2p-083>
Terminated at Thu Mar 31 11:11:58 2022
Results reported at Thu Mar 31 11:11:58 2022
Successfully completed.
CPU time : 7.00 sec.
Max Memory : 1166 MB
Average Memory : 594.00 MB
Delta Memory : 834.00 MB
Max Swap : -
Max Processes : 9
Max Threads : 13
Run time : 5 sec.
Turnaround time : 27 sec.
libfabric:65567:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:65567:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:65567:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:65567:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:65567:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:65567:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:65567:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:65567:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:65567:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:65567:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:65567:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:65567:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:65567:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:65567:core:core:fi_fabric_():1423<info> Opened fabric: mlx
[0] MPI startup(): Load tuning file: "/cluster/apps/nss/intel/oneapi/2022.1.2/mpi/2021.5.1/etc/tuning_generic_shm-ofi_mlx_hcoll.dat"
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 65567 eu-a2p-077 {54}
[0] MPI startup(): 1 65568 eu-a2p-077 {55}
[0] MPI startup(): 2 64165 eu-a2p-083 {7}
[0] MPI startup(): 3 64166 eu-a2p-083 {11}
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_RMK=lsf
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): threading: mode: direct
[0] MPI startup(): threading: vcis: 1
[0] MPI startup(): threading: app_threads: 1
[0] MPI startup(): threading: runtime: generic
[0] MPI startup(): threading: is_threaded: 0
[0] MPI startup(): threading: async_progress: 0
[0] MPI startup(): threading: num_pools: 64
[0] MPI startup(): threading: lock_level: global
[0] MPI startup(): threading: enable_sep: 0
[0] MPI startup(): threading: direct_recv: 1
[0] MPI startup(): threading: zero_op_flags: 1
[0] MPI startup(): threading: num_am_buffers: 1
[0] MPI startup(): threading: library is built with per-vci thread granularity
Hello world from processor eu-a2p-077, rank 1 out of 4 processors
Hello world from processor eu-a2p-077, rank 0 out of 4 processors
Hello world from processor eu-a2p-083, rank 2 out of 4 processors
Hello world from processor eu-a2p-083, rank 3 out of 4 processors
-> Job did not fail
EPYC 7763:
[sfux@eu-a2p-400 ~]$ ucx_info -d | grep Transport
# Transport: posix
# Transport: sysv
# Transport: self
# Transport: tcp
# Transport: tcp
# Transport: tcp
# Transport: cma
# Transport: knem
# Transport: xpmem
[sfux@eu-a2p-400 ~]$ ucx_info -v
Job logs:
[sfux@eu-login-16 intelmpi]$ cat lsf.o211967427
Sender: LSF System <lsfadmin@eu-a2p-512>
Subject: Job 211967427: <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> in cluster <euler> Done
Job <I_MPI_DEBUG=40 FI_PROVIDER=mlx mpirun -n 4 -ppn 2 ./hello> was submitted from host <eu-login-16> by user <sfux> in cluster <euler> at Thu Mar 31 11:11:44 2022
Job was executed on host(s) <2*eu-a2p-512>, in queue <normal.4h>, as user <sfux> in cluster <euler> at Thu Mar 31 11:12:18 2022
<2*eu-a2p-482>
</cluster/home/sfux> was used as the home directory.
</cluster/home/sfux/test/intelmpi> was used as the working directory.
Started at Thu Mar 31 11:12:18 2022
Terminated at Thu Mar 31 11:12:22 2022
Results reported at Thu Mar 31 11:12:22 2022
Your job looked like:
# LSBATCH: User input
Resource usage summary:
CPU time : 4.00 sec.
Max Memory : 1136 MB
Average Memory : -
Delta Memory : 864.00 MB
Max Swap : -
Max Processes : -
Max Threads : -
Run time : 16 sec.
Turnaround time : 38 sec.
The output (if any) follows:
libfabric:87550:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:87550:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:87550:core:core:ze_hmem_dl_init():422<warn> Failed to dlopen libze_loader.so
libfabric:87550:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: No data available
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: verbs (113.20)
libfabric:87550:core:core:ofi_register_provider():502<info> "verbs" filtered by provider include/exclude list, skipping
libfabric:87550:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:87550:core:core:ofi_register_provider():502<info> "tcp" filtered by provider include/exclude list, skipping
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:87550:core:core:ofi_register_provider():502<info> "sockets" filtered by provider include/exclude list, skipping
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:87550:core:core:ofi_register_provider():502<info> "shm" filtered by provider include/exclude list, skipping
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: ofi_rxm (113.20)
libfabric:87550:psm3:core:fi_prov_ini():680<info> build options: VERSION=1101.0=11.1.0.0, HAVE_PSM3_src=1, PSM3_CUDA=0
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: psm3 (1101.0)
libfabric:87550:core:core:ofi_register_provider():502<info> "psm3" filtered by provider include/exclude list, skipping
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: mlx (1.4)
libfabric:87550:core:core:ofi_register_provider():474<info> registering provider: ofi_hook_noop (113.20)
libfabric:87550:core:core:fi_getinfo_():1138<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:87550:core:core:fi_fabric_():1423<info> Opened fabric: mlx
[0] MPI startup(): 0 87550 eu-a2p-512 {120}
[0] MPI startup(): 1 87551 eu-a2p-512 {121}
[0] MPI startup(): 2 80139 eu-a2p-482 {120}
[0] MPI startup(): 3 80140 eu-a2p-482 {121}
Hello world from processor eu-a2p-512, rank 1 out of 4 processors
Hello world from processor eu-a2p-512, rank 0 out of 4 processors
Hello world from processor eu-a2p-482, rank 2 out of 4 processors
Hello world from processor eu-a2p-482, rank 3 out of 4 processors
-> Job did not fail
The jobs failed on EPYC 7742, but not on EPYC 7H12 and EPYC 7763. Is it somehow possible to have setting (e.g. and environment variable) which allows to get consistent results for nodes with the same interconnect (Mellanox ConnectX-6) but different CPUs?
Best regards
Sam
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi Sam,
Thank you for your inquiry. We offer support for hardware platforms that the Intel® oneAPI product supports. These platforms include those that are part of the Intel® Core™ processor family or higher, the Intel® Xeon® processor family, the Intel® Xeon® Scalable processor family, and others which can be found here – Intel® oneAPI Base Toolkit System Requirements, Intel® oneAPI HPC Toolkit System Requirements, Intel® oneAPI IoT Toolkit System Requirements
If you wish to use oneAPI on hardware that is not listed at one of the sites above, we encourage you to visit and contribute to the open oneAPI specification - https://www.oneapi.io/spec/
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Dear JyotsnaK_Intel,
please note that the attached logs have been produced running on Intel Xeon Gold 6150 processors, listed in the supported device on the webpage Intel® oneAPI HPC Toolkit System Requirements
Q
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
In the above post, Sam confirmed as "It seems that just setting FI_PROVIDER=mlx works fine on nodes with Intel Xeon Gold 6150 CPUs." Could you please confirm whether this issue is resolved or not? If the issue is not resolved, Could you please provide the scenario where it gives the error?
Thanks & Regards,
Hemanth
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
We haven't heard back from you. Could you please provide any updates on your issue?
Thanks & Regards,
Hemanth
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Dear @HemanthCH_Intel ,
Thank you for your reply.
Please keep the issue open for some more time. I will ask @qumale to rerun the computations for which he provided the logs above, to check if he still gets the same errors. If this is the case, then we would have to investigate this issue further.
I can also fully understand that you don't support other CPUs than Intel for Intel OneAPI. It looks like there is no setting which consistently results in non-crashing computations on different AMD CPU types. I think we will then ask our users to switch from IntelMPI to OpenMPI as OpenMPI runs fine on Intel and on AMD CPUs.
Best regards
Sam
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Sam,
I am going ahead and closing this thread due to inactivity. As conveyed before please reach us through the priority support channel once you have all the details.
Intel will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Amar
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
