Intel® MPI Library
2300 Discussions
Test program goes Wrong With mpirun
WangWJ
When I want to test whether Intel MPI is installed successful, I find the test program complied from provided code goes wrong with mpirun.
Here is the code provided by Intel. The file is /intel/oneapi/mpi/latest/opt/mpi/test/test.f90
        program main
        use mpi
        implicit none
        integer i, size, rank, namelen, ierr
        character (len=MPI_MAX_PROCESSOR_NAME) :: name
        integer stat(MPI_STATUS_SIZE)
        call MPI_INIT (ierr)
        call MPI_COMM_SIZE (MPI_COMM_WORLD, size, ierr)
        call MPI_COMM_RANK (MPI_COMM_WORLD, rank, ierr)
        call MPI_GET_PROCESSOR_NAME (name, namelen, ierr)
        if (rank.eq.0) then
            print *, 'Hello world: rank ', rank, ' of ', size, ' running on ', name
            do i = 1, size - 1
                call MPI_RECV (rank, 1, MPI_INTEGER, i, 1, MPI_COMM_WORLD, stat, ierr)
                call MPI_RECV (size, 1, MPI_INTEGER, i, 1, MPI_COMM_WORLD, stat, ierr)
                call MPI_RECV (namelen, 1, MPI_INTEGER, i, 1, MPI_COMM_WORLD, stat, ierr)
                name = ''
                call MPI_RECV (name, namelen, MPI_CHARACTER, i, 1, MPI_COMM_WORLD, stat, ierr)
            enddo
        else
            call MPI_SEND (rank, 1, MPI_INTEGER, 0, 1, MPI_COMM_WORLD, ierr)
            call MPI_SEND (size, 1, MPI_INTEGER, 0, 1, MPI_COMM_WORLD, ierr)
            call MPI_SEND (namelen, 1, MPI_INTEGER, 0, 1, MPI_COMM_WORLD, ierr)
            call MPI_SEND (name, namelen, MPI_CHARACTER, 0, 1, MPI_COMM_WORLD, ierr)
        endif
        call MPI_FINALIZE (ierr)
        end
I compile it with following:
source /opt/intel/oneapi/setvars.sh
mpiifx ./test.f90
Then run with following:
mpirun -n 4 ./a.out
and it goes wrong:
Here is more information:
OS : Fedora41
oneapi-base-toolkit:2025.2.0
oneapi-hpc-toolkit:2025.2.0
intel mpi:Version 2021.16 Build 20250513
TobiasK
@WangWJ can you please include more details, including the HW of your system where you get this error?
Can you also please add the output of I_MPI_DEBUG=10 and I_MPI_HYDRA_DEBUG=1?
Best
Tobias
WangWJ
HW:
CPU: Intel(R) Xeon(R) Gold 6248R CPU @ 3.00GHz *32
MEM: 128GB
Output of I_MPI_DEBUG=10 and I_MPI_HYDRA_DEBUG=1:
[mpiexec@host-**bleep**-**bleep**-**bleep**-xx] Launch arguments: /opt/intel/oneapi/mpi/2021.16/bin//hydra_bstrap_proxy --upstream-host host-**bleep**-**bleep**-**bleep**-xx --upstream-port 34519 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/2021.16/bin/ --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /opt/intel/oneapi/mpi/2021.16/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx]
            Topology parameters
 Number of packages     : 2
 Number of NUMA nodes   : 2
 Number of L3 caches    : 2
 Number of L2 caches    : 16
 Number of L1 caches    : 16
 Number of cores        : 16
 Number of threads      : 32
 Number of hwloc groups : 0
 Topology restricted    : no
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=response_to_init pmi_version=1 pmi_subversion=1 rc=0
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=get_maxes
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=maxes kvsname_max=256 keylen_max=64 vallen_max=4096
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=get_maxes
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=get_maxes
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=get_appnum
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=appnum appnum=0
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=get_appnum
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=get_appnum
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=get_my_kvsname
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=my_kvsname kvsname=kvs_13052_0
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=get_my_kvsname
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=get_maxes
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=get_my_kvsname
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=get_appnum
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=get kvsname=kvs_13052_0 key=PMI_process_mapping
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=get_result rc=0 msg=success value=(vector,(0,1,4))
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=get_my_kvsname
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=get kvsname=kvs_13052_0 key=PMI_process_mapping
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=get kvsname=kvs_13052_0 key=PMI_process_mapping
[0] MPI startup(): Intel(R) MPI Library, Version 2021.16  Build 20250513 (id: a7c135c)
[0] MPI startup(): Copyright (C) 2003-2025 Intel Corporation.  All rights reserved.
[0] MPI startup(): library kind: release
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=get kvsname=kvs_13052_0 key=PMI_process_mapping
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=put kvsname=kvs_13052_0 key=-bcast-1-0 value=2F6465762F73686D2F496E74656C5F4D50495F4D6D6376584E
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=put_result rc=0 msg=success
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=barrier_in
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=barrier_in
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=barrier_in
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=barrier_in
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=barrier_out
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 9: cmd=get kvsname=kvs_13052_0 key=-bcast-1-0
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=get_result rc=0 msg=success value=2F6465762F73686D2F496E74656C5F4D50495F4D6D6376584E
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 10: cmd=get kvsname=kvs_13052_0 key=-bcast-1-0
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=get kvsname=kvs_13052_0 key=-bcast-1-0
[0] MPI startup(): libfabric loaded: libfabric.so.1
[0] MPI startup(): libfabric version: 2.1.0-impi
[0] MPI startup(): max number of MPI_Request per vci: 67108864 (pools: 1)
[0] MPI startup(): libfabric provider: tcp
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 6: cmd=put kvsname=kvs_13052_0 key=bc-0 value=mpi#020093CFC0A8CD2A0000000000000000$
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] pmi cmd from fd 15: cmd=get kvsname=kvs_13052_0 key=bc-0
[proxy:0:0@host-**bleep**-**bleep**-**bleep**-xx] PMI response: cmd=get_result rc=0 msg=success value=mpi#020093CFC0A8CD2A0000000000000000$
[0] MPI startup(): shm segment size (801 MB per rank) * (4 local ranks) = 3207 MB total
forrtl: severe (168): Program Exception - illegal instruction
Image              PC                Routine            Line        Source
libc.so.6          00007F1291426490  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F12924E5BA2  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F12922F444D  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F129235A4E6  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F1291F692B1  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F129225E611  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F129225E47E  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F1291DCAFD0  MPI_Init              Unknown  Unknown
libmpifort.so.12.  00007F129BF2857F  MPI_INIT              Unknown  Unknown
a.out              00000000004022F4  Unknown               Unknown  Unknown
a.out              000000000040229D  Unknown               Unknown  Unknown
libc.so.6          00007F129140F488  Unknown               Unknown  Unknown
libc.so.6          00007F129140F54B  __libc_start_main     Unknown  Unknown
a.out              00000000004021B5  Unknown               Unknown  Unknown
libc.so.6          00007F5047626490  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F50486E5BA2  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F50484F444D  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F504855A4E6  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F50481692B1  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F504845E611  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F504845E47E  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F5047FCAFD0  MPI_Init              Unknown  Unknown
libmpifort.so.12.  00007F505212857F  MPI_INIT              Unknown  Unknown
libc.so.6          00007F504760F488  Unknown               Unknown  Unknown
libc.so.6          00007F504760F54B  __libc_start_main     Unknown  Unknown
libc.so.6          00007F7004826490  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F70058E5BA2  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F70056F444D  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F700575A4E6  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F70053692B1  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F700565E611  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F700565E47E  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F70051CAFD0  MPI_Init              Unknown  Unknown
libmpifort.so.12.  00007F700F32857F  MPI_INIT              Unknown  Unknown
libc.so.6          00007F700480F488  Unknown               Unknown  Unknown
libc.so.6          00007F700480F54B  __libc_start_main     Unknown  Unknown
libc.so.6          00007F3BCD226490  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCE2E5BA2  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCE0F444D  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCE15A4E6  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCDD692B1  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCE05E611  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCE05E47E  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007F3BCDBCAFD0  MPI_Init              Unknown  Unknown
libmpifort.so.12.  00007F3BD7D2857F  MPI_INIT              Unknown  Unknown
libc.so.6          00007F3BCD20F488  Unknown               Unknown  Unknown
libc.so.6          00007F3BCD20F54B  __libc_start_main     Unknown  Unknown
TobiasK
Can you please also check if "IMB-MPI1" works? what kind of network is installed on the system? Can you please run with I_MPI_FABRICS=shm ?
WangWJ
"IMB-MPI1" does not work whether with I_MPI_FABRICS=shm or not. The test is the same. I dont know much about netmork. Here is the result of ifconfig:
ens3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet ???.???.???.??  netmask 255.255.255.192  broadcast ???.???.???.??
        inet6 ????::????:????:????:???  prefixlen 64  scopeid 0x20<link>
        ether ??:??:??:??:??:??  txqueuelen 1000  (Ethernet)
        RX packets 366825  bytes 5153590704 (4.7 GiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 242822  bytes 15576592 (14.8 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 12  bytes 720 (720.0 B)
        TX packets 12  bytes 720 (720.0 B)
 If you need more Information,please tell me how to get those information.
Here is the output of IMB-MPI1 with I_MPI_FABRICS=shm:
 mpirun -n 2 ./IMB-MPI1
[mpiexec@host-???-???-???-??] Launch arguments: /opt/intel/oneapi/mpi/2021.16/bin//hydra_bstrap_proxy --upstream-host host-???-???-???-?? --upstream-port 39167 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/2021.16/bin/ --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /opt/intel/oneapi/mpi/2021.16/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[proxy:0:0@host-???-???-???-??]
            Topology parameters
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@host-???-???-???-??] PMI response: cmd=response_to_init pmi_version=1 pmi_subversion=1 rc=0
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get_maxes
[proxy:0:0@host-???-???-???-??] PMI response: cmd=maxes kvsname_max=256 keylen_max=64 vallen_max=4096
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get_appnum
[proxy:0:0@host-???-???-???-??] PMI response: cmd=appnum appnum=0
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get_my_kvsname
[proxy:0:0@host-???-???-???-??] PMI response: cmd=my_kvsname kvsname=kvs_21578_0
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get kvsname=kvs_21578_0 key=PMI_process_mapping
[proxy:0:0@host-???-???-???-??] PMI response: cmd=get_result rc=0 msg=success value=(vector,(0,1,2))
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=get_maxes
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=get_appnum
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=get_my_kvsname
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=get kvsname=kvs_21578_0 key=PMI_process_mapping
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=barrier_in
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=put kvsname=kvs_21578_0 key=-bcast-1-0 value=2F6465762F73686D2F496E74656C5F4D50495F75563463644A
[proxy:0:0@host-???-???-???-??] PMI response: cmd=put_result rc=0 msg=success
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=barrier_in
[proxy:0:0@host-???-???-???-??] PMI response: cmd=barrier_out
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get kvsname=kvs_21578_0 key=-bcast-1-0
[proxy:0:0@host-???-???-???-??] PMI response: cmd=get_result rc=0 msg=success value=2F6465762F73686D2F496E74656C5F4D50495F75563463644A
[0] MPI startup(): shm segment size (1819 MB per rank) * (2 local ranks) = 3639 MB total
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 0 PID 21582 RUNNING AT host-???-???-???-??
=   KILLED BY SIGNAL: 4 (Illegal instruction)
=   RANK 1 PID 21583 RUNNING AT host-???-???-???-??
Here is the output of IMB-MPI1 without I_MPI_FABRICS=shm:
[mpiexec@host-???-???-???-??] Launch arguments: /opt/intel/oneapi/mpi/2021.16/bin//hydra_bstrap_proxy --upstream-host host-???-???-???-?? --upstream-port 40281 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/2021.16/bin/ --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /opt/intel/oneapi/mpi/2021.16/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
            Topology parameters
[proxy:0:0@host-???-???-???-??] PMI response: cmd=my_kvsname kvsname=kvs_22313_0
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get kvsname=kvs_22313_0 key=PMI_process_mapping
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=get kvsname=kvs_22313_0 key=PMI_process_mapping
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=put kvsname=kvs_22313_0 key=-bcast-1-0 value=2F6465762F73686D2F496E74656C5F4D50495F437438344252
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get kvsname=kvs_22313_0 key=-bcast-1-0
[proxy:0:0@host-???-???-???-??] PMI response: cmd=get_result rc=0 msg=success value=2F6465762F73686D2F496E74656C5F4D50495F437438344252
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 6: cmd=put kvsname=kvs_22313_0 key=bc-0 value=mpi#0200A7D7C0A8CD2A0000000000000000$
[proxy:0:0@host-???-???-???-??] pmi cmd from fd 9: cmd=get kvsname=kvs_22313_0 key=bc-0
[proxy:0:0@host-???-???-???-??] PMI response: cmd=get_result rc=0 msg=success value=mpi#0200A7D7C0A8CD2A0000000000000000$
=   RANK 0 PID 22317 RUNNING AT host-???-???-???-??
=   KILLED BY SIGNAL: 9 (Killed)
=   RANK 1 PID 22318 RUNNING AT host-???-???-???-??
