Intel® MPI Library
2279 Discussions
The calculation results of allreduce in Intel MPI and OpenMPI are different
Xiaoqiang
What parameters can I adjust to make the calculation results consistent.
SantoshY_Intel
Thanks for posting in the Intel communities.
Could you please provide us with the below details to help us investigate your issue?
  1. Sample reproducer code & complete steps to reproduce the issue from our end.
  2. The version of Intel MPI & OpenMPI you are using?
  3. Operating system details.
  4. CPU details
  5. Are you running your program on a single node or a cluster of nodes? If running on multi-nodes, then please provide the Interconnect details & job scheduler being used.
Also, please provide your results obtained from Intel MPI & OpenMPI.
Thanks & Regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Could you please provide us with the complete details to investigate your issue?
Santosh
SantoshY_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Santosh
