Intel® MPI Library
Trace Analyzer Segmentation Fault
sandek
Whenever I run my code with 2 or 4 processes, the trace analyzer works fine. However, if I run my code on 6 or more processors, when I run the trace analyzer gui with the created .stf file, it works for a few seconds but soon after crashes with a segmentation fault. Are there limitations associated with the trace analyzer? Or is it more likely a limitation caused my system?
Thanks in advance!
KS
Dmitry_K_Intel2
Hi KS,
Could you please attach the trace file for further investigation? It's rather TraceAnalyzer's issue but we need to check it. BTW, Linux or Windows version? And good to know ITAC version as well.
Regards!
---Dmitry
sandek
Thanks for the response!
I'm running the linux version, here's the build #:l_itac_p_8.0.3.04_intel64
I attached the trace files associated with with one of the runs causing the GUI to seg fault.
-Kevin
Dmitry_K_Intel2
Sorry, Kevin,
I don't see any attachment.
Regards!
---Dmitry
sandek
Ah, I uploaded but didn't attach, should be there now! Sorry for the inconvenience!
Dmitry_K_Intel2
Hi Kevin,
Thanks for the trace! I could reproduce the issue with ITAC 8.0 Update 3.
I've tested the same scenario with version 8.1 and there was no crash. Hopefully the issue has been fixed.
Version 8.1 is not available for download yet, but I hope that it will be some time this Fall.
Best wishes!
---Dmitry
