Intel® MPI Library
2293 Discussions
Trace Collector with ILP64 MKL and MPI libraries
John_Young
Is it possible to use the Intel Trace Collector (on linux) with the ILP64 MKL and MPI libraries?  I see on the MPI page
          https://software.intel.com/en-us/mpi-developer-reference-linux-ilp64-support
the statement
"If you want to use the Intel® Trace Collector with the Intel MPI Library ILP64 executable files, you must use a special Intel Trace Collector library. If necessary, the mpiifort compiler wrapper will select the correct Intel Trace Collector library automatically."
I don't really understand whether this means 1) there are special Trace Collector Libraries available or 2) you somehow have to generate your own special library.  I can find no information in the Trace Collector documentation itself concerning ILP64 support.
John
