Intel® MPI Library
2284 Discussions
Treatment of COMPUTERNAME environment variable on Windows with the -envexcl option
ManOfKent
It looks as if the treatment of the COMPUTERNAME environment variable has changed between Intel MPI versions 2018.3 and 2021.8 on Windows.
With version 2018.3 we used the mpiexec option -envexel COMPUTERNAME to prevent COMPUTERNAME from being propagated from the launch host to the ranks on remote hosts. With this setting COMPUTERNAME is set to the correct value on each rank.
With version 2021.8, using -envexel COMPUTERNAME causes COMPUTERNAME to be unset on all ranks. If we remove this option, the variable is set to the correct value on each rank.
Is this an intentional change?
Many thanks for your help.
AishwaryaCV_Intel
We have informed the team concerned regarding your issue and we are working on it internally.
Thanks And Regards,
Aishwarya
AishwaryaCV_Intel
Apologies for the delay in my response and thank you for your patience.
Could you please try to run on latest Intel MPI (2021.10) version and let us know if you still persist the issue?
Thanks And Regards,
Aishwarya
ManOfKent
Hi Aishwarya,
Thanks for your response.
I have repeated the test using Intel MPI version 2021.10 and the COMPUTERNAME variable is handled the same as in version 2021.8
AishwaryaCV_Intel
We are working on your issue internally and we will get back to you soon.
Thanks and regards,
Aishwarya
