Intel® MPI Library
2293 Discussions
Ubuntu 20.04 WRF CHEM segmentation fault
jsrikish
I was able to compile  wrf 4.2  using
oneapi/compiler/2023.1.0 suite of compilers
./configure (I chose option 15)   15. (dmpar)
export DM_FC="mpiifort -f90=ifort"
export DM_CC="mpiicc -cc=icc -DMPI2_SUPPORT"
export FLEX_LIB_DIR=/usr/lib/x86_64-linux-gnu/
export EM_CORE=1
export WRF_CHEM=1
export WRF_KPP=1
export YACC="/usr/bin/bison -d"
export NETCDF=/home/apps
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH=/home/apps/lib
ulimit -s unlimited
I made a successful simulation on a single node using 38 processors. (total of 40 processors on each node) -- mpirun -np 38 ./wrf.exe  after logging into the node
machines1 has only one node listed (node12)
From the head node, I issue the following command
mpirun -np 38 -f machines1 ./wrf.exe
2-way login set up between the head and compute nodes without prompting for password
It fails right after it starts
d01 2023-12-04_06:00:00 Input data is acceptable to use: wrfbdy_d01
Timing for processing lateral boundary for domain 1: 0.82989 elapsed seconds
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
libpthread-2.31.s 00007F7CAA465420 Unknown Unknown Unknown
wrf.exe 0000000001FE246A Unknown Unknown Unknown
wrf.exe 0000000001DB4198 Unknown Unknown Unknown
wrf.exe 000000000060075F Unknown Unknown Unknown
wrf.exe 0000000000418361 Unknown Unknown Unknown
wrf.exe 000000000041831F Unknown Unknown Unknown
wrf.exe 00000000004182BD Unknown Unknown Unknown
libc-2.31.so 00007F7CAA27B083 __libc_start_main Unknown Unknown
wrf.exe 00000000004181DE Unknown Unknown Unknown
Setting OMP_STACKSIZE 10240000000 didn't help.  Do I need any other MPI env variable  to be set/tweaked for running across nodes?
which mpirun
/ssd/intel/oneapi/mpi/2021.10.0//bin/mpirun
Also, tried with 2021.9.0
Could you please let us know how to run the code across nodes?
Thank you!
Labels (3)
ShivaniK_Intel
Thanks for posting in the Intel forums.
Could you please provide us with the sample reproducer and steps to reproduce the issue at our end?
Could you also please provide us with the processor details by running the below command.
Command: lscpu
Thanks & Regards
Shivani
jsrikish
Thank you for your prompt reply.
Do you need the executable wrf.exe along with all the input files and namelist.input to run at your end?
I will send you the output lscpu.
Cheers
ShivaniK_Intel
>>>"Do you need the executable wrf.exe along with all the input files and namelist.input to run at your end?"
Yes, we need a sample reproducer along with the required input files and steps to reproduce the issue at our end.
Thanks & Regards
Shivani
jsrikish
Executable and binary input files are large.  Where do I upload them?
ShivaniK_Intel
We have internally shared the details to upload the executable and input files. Please share the files through that link.
Thanks & Regards
Shivani
jsrikish
Thanks, Shivani.
I will upload the files tomorrow
jsrikish
I uploaded wrf_fdda, wrf_biochem, wrfbdy files But when I tried to upload wrfinput_d01 & wrfinput_d02, it gave me an error message
and kicked me out.  Tried several times.
Secure Connection Failed
An error occurred during a connection to secureftp.intel.com. PR_CONNECT_RESET_ERROR
Error code: PR_CONNECT_RESET_ERROR
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
How do I get those files across?
ShivaniK_Intel
Sorry for the inconvenience.
We have internally shared the details again to upload the executable and input files. Please share the files through that link.
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you could you share the details through the link which is provided to you internally. The link might expire soon so request you to share the details as early as possible.
Thanks & Regards
Shivani
ShivaniK_Intel
We have not heard back from you. This thread will be no longer monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Shivani
