Intel® MPI Library
2272 Discussions
Unable to use PSM2 for OmniPath in mpi 2021.9.0
lhcamilo
Hi there,
I have been struggling to get PSM2 enabled in our intel OneAPI installation.  Our nodes are connected with OmniPath, hence why I need to the PSM2 support enabled. Though OPX would also be nice.
In any case I have done:
$ export I_MPI_FABRIC=ofi # and export I_MPI_FABRICS=shm:ofi
$ source vars.sh -i_mpi_ofi_internal=1
$ export I_MPI_OFI_PROVIDER=psm2
$ mpiexec -n 1 IMB-MPI1 -help
[0] MPI startup(): Intel(R) MPI Library, Version 2021.9  Build 20230307 (id: d82b3071db)
[0] MPI startup(): Copyright (C) 2003-2023 Intel Corporation.  All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): libfabric version: 1.13.2rc1-impi
Abort(2139535) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(176)........:
MPID_Init(1546)..............:
MPIDI_OFI_mpi_init_hook(1518):
open_fabric(2572)............:
find_provider(2694)..........: OFI fi_getinfo() failed (ofi_init.c:2694:find_provider:No data available)
 Additionally from fi_info:
fi_info -l
psm2:
    version: 113.20
mlx:
    version: 1.4
psm3:
    version: 1104.1000
ofi_rxm:
    version: 113.20
verbs:
    version: 113.20
tcp:
    version: 113.20
sockets:
    version: 113.20
shm:
    version: 116.10
ofi_hook_noop:
    version: 113.20
 I would really appreciate some guidance.
TobiasK
@lhcamilo Please try again with the latest Intel MPI 2021.13 version included in oneAPI 2024.2.1
Is the Mellanox UCX stack installed?
Why are you using
Do you have another libfabric version installed and is that one present in your path?
Can you please show the output of
which fi_info
lhcamilo
Hello Tobias,
Thank you for your response.
UCX/1.14.1 is installed. It maybe  worth noting that we are using EasyBuild.
> Why are you using
I wanted to force  the use of intel packages libfabric (and psm2) libraries, rather than the ones installed in the system.
$ which fi_info
$APPS/impi/2021.9.0-intel-compilers-2023.1.0/mpi/2021.9.0/libfabric/bin/fi_info
as far as I can tell it is using the correct libfabric
Thanks for the help
