Intel® MPI Library
Uninstall Problem
Jayanth_D_
Hi
I have installed Intel Cluster Studio XE 2013 but now I have added a new HDD and want to install it on it. The problem I am facing is when I try to uninstall Intel Cluster Studio XE 2013 from my first HDD it says another installer is running, complete it before running this installer. I have no other installers running. I tried many times and I get the same error.
Thanks and Regards
Jayanth D
James_T_Intel
Hi Jayanth,
Have you tried rebooting?  Please send me the installation logs (you can send them via private message if you'd prefer).  These can be found in %temp% named w_ics_#timestamp_extract.log.  Also, regarding your previous installation issues, did you install as a standard user or as an administrator?
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
