Intel® MPI Library
2294 Discussions
Using intel mpi in parallel ANSYS fluent with AMD processors
milad_m_
I set up and use successfully this tutorial (https://goo.gl/Ww6bkM) for clustering 2 machine to run the ansys fluent 17.2 in parallel mode. machine 1 (node1) is win server 2012 R2 64bit and machine 2 (node2) is win 8 64bit. both of them use Intel core i3 3.10 GHZ and 8GB memory. this tutorial use intel mpi for paralleling. Know i set it up for 2 machine with same OS like above, but with quad core AMD opteron processor 2378 2.4GHZ and 16 GB memory. When i run for parallel processing according the tutorial this error appear. https://goo.gl/p3LaLf Is it possible that intel mpi dont compatible with this AMD processors for parallel run or other reason has been caused this? what should i do? thanks.
