Intel® MPI Library
2300 Discussions
WRF compile undefined reference to `__kmpc
MK
i´m triying compile WRF 3.5.1 with option   20.  Linux x86_64 i486 i586 i686, ifort compiler with icc  (dm+sm) and
 Intel(R) Cluster Studio XE 2013 Service Pack 1 (SP1) Update 1 for Linux* OS
and i´m having this errors. Then configure.wrf is below.
../../frame/module_wrf_error.o: In function `wrf_message_':
module_wrf_error.f90:(.text+0x2b): undefined reference to `__kmpc_global_thread_num'
module_wrf_error.f90:(.text+0x48): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x136): undefined reference to `__kmpc_end_master'
../../frame/module_wrf_error.o: In function `wrf_message2_':
module_wrf_error.f90:(.text+0x17a): undefined reference to `__kmpc_global_thread_num'
module_wrf_error.f90:(.text+0x18b): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1de): undefined reference to `__kmpc_end_master'
../../frame/module_wrf_error.o: In function `wrf_check_error_':
module_wrf_error.f90:(.text+0x22b): undefined reference to `__kmpc_global_thread_num'
module_wrf_error.f90:(.text+0x3c9): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x4d7): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x5ba): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x6d6): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x704): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x7ff): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x827): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x92c): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x952): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x9ab): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0xa71): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0xac2): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0xb06): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0xb5a): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0xb72): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0xbcb): undefined reference to `__kmpc_end_master'
../../frame/module_wrf_error.o: In function `wrf_error_fatal_':
module_wrf_error.f90:(.text+0xc7b): undefined reference to `__kmpc_global_thread_num'
module_wrf_error.f90:(.text+0xced): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0xe1c): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0xe42): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0xf67): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0xf8d): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x10bc): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x10e2): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x113b): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x117c): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x11d0): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x11ec): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1245): undefined reference to `__kmpc_end_master'
../../frame/module_wrf_error.o: In function `wrf_error_fatal3_':
module_wrf_error.f90:(.text+0x12fc): undefined reference to `__kmpc_global_thread_num'
module_wrf_error.f90:(.text+0x136c): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1481): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x1563): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x167f): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x16b3): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x17c6): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x17ec): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1901): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x1926): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x197f): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x1a3e): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1a8f): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x1ad6): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1b2a): undefined reference to `__kmpc_end_master'
module_wrf_error.f90:(.text+0x1b42): undefined reference to `__kmpc_master'
module_wrf_error.f90:(.text+0x1b9b): undefined reference to `__kmpc_end_master'
the config file is...
# configure.wrf
# This file was automatically generated by the configure script in the
# top level directory. You may make changes to the settings in this
# file but be aware they will be overwritten each time you run configure.
# Ordinarily, it is necessary to run configure once, when the code is
# first installed.
# To permanently change options, change the settings for your platform
# in the file arch/configure.defaults then rerun configure.
SHELL           =       /bin/sh
DEVTOP          =       `pwd`
LIBINCLUDE      =       .
.SUFFIXES: .F .i .o .f90 .c
#### Get core settings from environment (set in compile script)
#### Note to add a core, this has to be added to.
COREDEFS = -DEM_CORE=$(WRF_EM_CORE) \
           -DNMM_CORE=$(WRF_NMM_CORE) -DNMM_MAX_DIM=2600 \
       -DCOAMPS_CORE=$(WRF_COAMPS_CORE) \
       -DDA_CORE=$(WRF_DA_CORE) \
           -DEXP_CORE=$(WRF_EXP_CORE)
#### Single location for defining total number of domains.  You need
#### at least 1 + 2*(number of total nests).  For example, 1 coarse
#### grid + three fine grids = 1 + 2(3) = 7, so MAX_DOMAINS=7.
MAX_DOMAINS    =    21
#### DM buffer length for the configuration flags.
CONFIG_BUF_LEN    =    65536
#### Size of bitmasks (in 4byte integers) of stream masks for WRF I/O
MAX_HISTORY = 25
IWORDSIZE = 4
DWORDSIZE = 8
LWORDSIZE = 4
#### The settings in this section are defaults that may be overridden by the
#### architecture-specific settings in the next section.
#### NOTE:  Do not modify these default values here.  To override these
####        values, make changes after "Architecture specific settings".
#### Native size (in bytes) of Fortran REAL data type on this architecture ####
#### Note:  to change real wordsize (for example, to promote REALs from
####        4-byte to 8-byte), modify the definition of RWORDSIZE in the
####        section following "Architecture specific settings".  Do not
####        change NATIVE_RWORDSIZE as is it architecture-specific.
NATIVE_RWORDSIZE = 4
#### Default sed command and script for Fortran source files ####
#SED_FTN = sed -f $(WRF_SRC_ROOT_DIR)/arch/standard.sed
SED_FTN = $(WRF_SRC_ROOT_DIR)/tools/standard.exe
# Hack to work around $(PWD) not changing during OSF1 build.
# $(IO_GRIB_SHARE_DIR) is reset during the OSF1 build only.
IO_GRIB_SHARE_DIR =
#### ESMF switches                 ####
#### These are set up by Config.pl ####
# switch to use separately installed ESMF library for coupling:  1==true
ESMF_COUPLING       = 0
# select dependences on module_utility.o
ESMF_MOD_DEPENDENCE = $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90/module_utility.o
# select -I options for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_INC         = -I$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90
# select -I options for separately installed ESMF library, if present
ESMF_MOD_INC        =  $(ESMF_IO_INC)
# select cpp token for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_DEFS        =
# select build target for external/io_esmf vs. external/esmf_time_f90
ESMF_TARGET         = esmf_time
# ESMFINCLUDEGOESHERE
#### NETCDF4 pieces
NETCDF4_IO_OPTS = -DUSE_NETCDF4_FEATURES -DWRFIO_NCD_LARGE_FILE_SUPPORT
GPFS            =
CURL            =
HDF5            =
ZLIB            =
DEP_LIB_PATH    =
NETCDF4_DEP_LIB = $(DEP_LIB_PATH) $(HDF5) $(ZLIB) $(GPFS) $(CURL)
# NETCDF4INCLUDEGOESHERE
LIBWRFLIB = libwrflib.a
#### Architecture specific settings ####
# Settings for Linux x86_64 i486 i586 i686, ifort compiler with icc  (dm+sm)
#        By default, some files are compiled without optimizations to speed up compilation. Removing
#        respective makefile rules in the end of this file will result in longer compilation time, and, possibly
#        Out Of Memory messages, but might produce binaries which are substantially faster.
#        Please visit http://www.intel.com/support/performancetools/sb/cs-028607.htm ;
#        for latest info on how to build WRF with Intel compilers.
#        If you got Out Of Memory message, there are several options:
#          1. Check your memory limits (ulimit -a), possibly increasing swap partitions size.
#          2. Remove any debugging flags (-g, -check, -traceback).
#          3. Force the problematic file to be compiled with less optimizations (see examples at the
#             end of this file), try -no-ip compiler flag.
#        This configuration is aimed at accuracy. To improve performance (at the expence of accuracy) you might
#        consider removing '-fp-model precise' flag from FCBASEOPTS. This enables non value-safe optimizations.
#        Another option is to add '-ftz' flag, which flushes denormal results to zero when the application is in
#        the gradual underflow mode. It may improve performance if the denormal values are not critical to the
#        behavior of your workload. To further improve performance, add suitable vectorization options for your
#        processor to FCOPTIM (see ifort manpage).
#        If you have Intel MPI installed and wish to use instead, make the
#        following changes to settings below:
#        DM_FC  = mpiifort
#        DM_CC  = mpiicc
#        and source bin64/mpivars.sh file from your Intel MPI installation
#        before the build.
#        Suggestions for timing improvements from Craig Mattocks
#CFLAGS_LOCAL    =       -w -O3 -ip -fp-model precise -w -ftz -align all -fno-alias $(FORMAT_FREE) $(BYTESWAPIO) #-xHost -fp-model fast=2 -no-prec-div -no-prec-sqrt -ftz -no-multibyte-chars
#LDFLAGS_LOCAL   =       -ip -fp-model precise -w -ftz -align all -fno-alias $(FORMAT_FREE) $(BYTESWAPIO) #-xHost -fp-model fast=2 -no-prec-div -no-prec-sqrt -ftz -align all -fno-alias -fno-common
#FCBASEOPTS_NO_G =       -w -ip -fp-model precise -w -ftz -align all -fno-alias $(FORMAT_FREE) $(BYTESWAPIO) #-xHost -fp-model fast=2 -no-heap-arrays -no-prec-div -no-prec-sqrt -ftz -align all -fno-alias -fno-common $(FORMAT_FREE) $(BYTESWAPIO)
DMPARALLEL      =        1
OMPCPP          =        -D_OPENMP
OMP             =        -openmp -fpp -auto
OMPCC           =        -openmp -fpp -auto
SFC             =       ifort
SCC             =       icc
CCOMP           =       icc
DM_FC           =       mpif90 -f90=$(SFC)
DM_CC           =       mpicc -cc=$(SCC) -DMPI2_SUPPORT -DMPI2_THREAD_SUPPORT
FC              =        $(DM_FC)
CC              =       $(DM_CC) -DFSEEKO64_OK
LD              =       $(FC)
RWORDSIZE       =       $(NATIVE_RWORDSIZE)
PROMOTION       =       -i4
ARCH_LOCAL      =       -DNONSTANDARD_SYSTEM_FUNC -DWRF_USE_CLM
CFLAGS_LOCAL    =       -w -O2 -ip #-xHost -fp-model fast=2 -no-prec-div -no-prec-sqrt -ftz -no-multibyte-chars
LDFLAGS_LOCAL   =       -ip #-xHost -fp-model fast=2 -no-prec-div -no-prec-sqrt -ftz -align all -fno-alias -fno-common
CPLUSPLUSLIB    =
ESMF_LDFLAG     =       $(CPLUSPLUSLIB)
FCOPTIM         =       -O2
FCREDUCEDOPT    =       $(FCOPTIM)
FCNOOPT        =       -O0 -fno-inline -fno-ip
FCDEBUG         =       # -g $(FCNOOPT) -traceback # -fpe0 -check all -ftrapuv -unroll0 -u
FORMAT_FIXED    =       -FI
FORMAT_FREE     =       -FR
FCSUFFIX        =
BYTESWAPIO      =       -convert big_endian
FCBASEOPTS_NO_G =       -ip -fp-model precise -w -ftz -align all -fno-alias $(FORMAT_FREE) $(BYTESWAPIO) #-xHost -fp-model fast=2 -no-heap-arrays -no-prec-div -no-prec-sqrt -fno-common
FCBASEOPTS      =       $(FCBASEOPTS_NO_G) $(FCDEBUG)
MODULE_SRCH_FLAG =
TRADFLAG        =      -traditional
CPP             =      /lib/cpp -C -P
AR              =      ar
ARFLAGS         =      ru
M4              =      m4
RANLIB          =      ranlib
CC_TOOLS        =      $(SCC)
# POSTAMBLE
FGREP = fgrep -iq
ARCHFLAGS       =    $(COREDEFS) -DIWORDSIZE=$(IWORDSIZE) -DDWORDSIZE=$(DWORDSIZE) -DRWORDSIZE=$(RWORDSIZE) -DLWORDSIZE=$(LWORDSIZE) \
                     $(ARCH_LOCAL) \
                     $(DA_ARCHFLAGS) \
                      -DDM_PARALLEL \
                      -DNETCDF \
                      -DUSE_ALLOCATABLES \
                      -DGRIB1 \
                      -DINTIO \
                      -DLIMIT_ARGS \
                      -DCONFIG_BUF_LEN=$(CONFIG_BUF_LEN) \
                      -DMAX_DOMAINS_F=$(MAX_DOMAINS) \
                      -DMAX_HISTORY=$(MAX_HISTORY) \
              -DNMM_NEST=$(WRF_NMM_NEST)
CFLAGS          =    $(CFLAGS_LOCAL) -DDM_PARALLEL  \
                      -DMAX_HISTORY=$(MAX_HISTORY) -DNMM_CORE=$(WRF_NMM_CORE)
FCFLAGS         =    $(FCOPTIM) $(FCBASEOPTS)
ESMF_LIB_FLAGS  =
# ESMF 5 -- these are defined in esmf.mk, included above
 ESMF_IO_LIB     =    -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
ESMF_IO_LIB_EXT =    -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
INCLUDE_MODULES =    $(MODULE_SRCH_FLAG) \
                     $(ESMF_MOD_INC) $(ESMF_LIB_FLAGS) \
                      -I$(WRF_SRC_ROOT_DIR)/main \
                      -I$(WRF_SRC_ROOT_DIR)/external/io_netcdf \
                      -I$(WRF_SRC_ROOT_DIR)/external/io_int \
                      -I$(WRF_SRC_ROOT_DIR)/frame \
                      -I$(WRF_SRC_ROOT_DIR)/share \
                      -I$(WRF_SRC_ROOT_DIR)/phys \
                      -I$(WRF_SRC_ROOT_DIR)/chem -I$(WRF_SRC_ROOT_DIR)/inc \
                      -I$(NETCDFPATH)/include \
REGISTRY        =    Registry
CC_TOOLS_CFLAGS = -DNMM_CORE=$(WRF_NMM_CORE)
 LIB_BUNDLED     = \
                      $(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5/libfftpack.a \
                      $(WRF_SRC_ROOT_DIR)/external/io_grib1/libio_grib1.a \
                      $(WRF_SRC_ROOT_DIR)/external/io_grib_share/libio_grib_share.a \
                      $(WRF_SRC_ROOT_DIR)/external/io_int/libwrfio_int.a \
                      $(ESMF_IO_LIB) \
                      $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a \
                      $(WRF_SRC_ROOT_DIR)/frame/module_internal_header_util.o \
                      $(WRF_SRC_ROOT_DIR)/frame/pack_utils.o
 LIB_EXTERNAL    = \
                      -L$(WRF_SRC_ROOT_DIR)/external/io_netcdf -lwrfio_nf -L/opt/netcdf/host/lib  -lnetcdf
LIB             =    $(LIB_BUNDLED) $(LIB_EXTERNAL) $(LIB_LOCAL) $(LIB_WRF_HYDRO)
LDFLAGS         =    $(OMP) $(FCFLAGS) $(LDFLAGS_LOCAL)
ENVCOMPDEFS     =
WRF_CHEM    =    0
CPPFLAGS        =    $(ARCHFLAGS) $(ENVCOMPDEFS) -I$(LIBINCLUDE) $(TRADFLAG)
NETCDFPATH      =    /opt/netcdf/host
PNETCDFPATH     =
bundled:  io_only fftpack
external: io_only $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a gen_comms_rsllite module_dm_rsllite $(ESMF_TARGET)
io_only:  esmf_time wrfio_nf   wrf_ioapi_includes wrfio_grib_share wrfio_grib1 wrfio_int
externals: io_only bundled external
gen_comms_serial :
    ( /bin/rm -f $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c )
module_dm_serial :
    ( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; cat module_dm_stubs.F >> module_dm.F ; fi )
gen_comms_rsllite :
    ( if [ ! -e $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ] ; then \
          /bin/cp $(WRF_SRC_ROOT_DIR)/tools/gen_comms_warning $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; \
          cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/gen_comms.c >> $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; fi )
module_dm_rsllite :
    ( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; \
          cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/module_dm.F >> module_dm.F ; fi )
wrfio_nf :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_netcdf ; \
          make $(J) NETCDFPATH="$(NETCDFPATH)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
          CC="$(SCC)" CFLAGS="$(CFLAGS)" \
          FC="$(SFC) $(PROMOTION) $(OMP) $(FCFLAGS)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_pnf :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_pnetcdf ; \
          make $(J) NETCDFPATH="$(PNETCDFPATH)" RANLIB="$(RANLIB)" CPP="$(CPP) $(ARCHFLAGS)" \
          FC="$(FC) $(PROMOTION) $(OMP) $(FCFLAGS)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_grib_share :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_grib_share ; \
          make $(J) CC="$(SCC)" CFLAGS="$(CFLAGS)" RM="$(RM)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
          FC="$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" archive)
wrfio_grib1 :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_grib1 ; \
wrfio_grib2 :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_grib2 ; \
          make $(J) CC="$(SCC)" CFLAGS="$(CFLAGS) " RM="$(RM)" RANLIB="$(RANLIB)" \
          CPP="$(CPP)" \
          FC="$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="-traditional" AR="$(AR)" ARFLAGS="$(ARFLAGS)" \
          FIXED="$(FORMAT_FIXED)" archive)
wrfio_int :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_int ; \
          make $(J) CC="$(CC)" RM="$(RM)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
          FC="$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(OMP)" FGREP="$(FGREP)" \
          TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" ARCHFLAGS="$(ARCHFLAGS)" all )
esmf_time :
    ( cd $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 ; \
          make $(J) FC="$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)" RANLIB="$(RANLIB)" \
          CPP="$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc -I. $(ARCHFLAGS) $(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
fftpack :
    ( cd $(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5 ; \
          make $(J) FC="$(SFC)" FFLAGS="$(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)" RANLIB="$(RANLIB)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
atm_ocn :
    ( cd $(WRF_SRC_ROOT_DIR)/external/atm_ocn ; \
          CPP="$(CPP)" \
          FC="$(DM_FC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="-traditional" AR="$(AR)" ARFLAGS="$(ARFLAGS)" \
          FIXED="$(FORMAT_FIXED)" )
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a :
    ( cd $(WRF_SRC_ROOT_DIR)/external/RSL_LITE ; make $(J) CC="$(CC) $(CFLAGS)" \
          FC="$(FC) $(FCFLAGS) $(OMP) $(PROMOTION) $(BYTESWAPIO)" \
          CPP="$(CPP) -I. $(ARCHFLAGS) $(OMPCPP) $(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" ;\
          $(RANLIB) $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a )
#    Macros, these should be generic for all machines
LN    =    ln -sf
MAKE    =    make -i -r
RM    =     rm -f
# These sub-directory builds are identical across all architectures
wrf_ioapi_includes :
    ( cd $(WRF_SRC_ROOT_DIR)/external/ioapi_share ; \
          $(MAKE) NATIVE_RWORDSIZE="$(NATIVE_RWORDSIZE)" RWORDSIZE="$(RWORDSIZE)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_esmf :
    ( cd $(WRF_SRC_ROOT_DIR)/external/io_esmf ; \
          make FC="$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(ESMF_MOD_INC)" \
          RANLIB="$(RANLIB)" CPP="$(CPP) $(POUND_DEF) " AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
#    There is probably no reason to modify these rules
.F.i:
    $(RM) $@
    $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.F > $@
    mv $*.i $(DEVTOP)/pick/$*.f90
    cp $*.F $(DEVTOP)/pick
.F.o:
    $(RM) $@
    $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.F  > $*.bb
    $(SED_FTN) $*.bb | $(CPP) > $*.f90
    $(RM) $*.b $*.bb
    @ if echo $(ARCHFLAGS) | $(FGREP) 'DVAR4D'; then \
          echo COMPILING $*.F for 4DVAR ; \
          $(WRF_SRC_ROOT_DIR)/var/build/da_name_space.pl $*.f90 > $*.f90.tmp ; \
          mv $*.f90.tmp $*.f90 ; \
        fi
    $(FC) -o $@ -c $(FCFLAGS) $(OMP) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $*.f90
.F.f90:
    $(RM) $@
    $(SED_FTN) $*.F > $*.b
    $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.b  > $@
    $(RM) $*.b
.f90.o:
    $(RM) $@
    $(FC) -o $@ -c $(FCFLAGS) $(PROMOTION) $(FCSUFFIX) $*.f90
setfeenv.o : setfeenv.c
    $(RM) $@
    $(CCOMP) -o $@ -c $(CFLAGS) $(OMPCC) $*.c
.c.o:
    $(RM) $@
    $(CC) -o $@ -c $(CFLAGS) $*.c
# A little more adventurous.  Allow full opt on
# mediation_integrate.o \
# shift_domain_em.o \
# solve_em.o  <-- gets a little kick from SOLVE_EM_SPECIAL too, if defined
# mediation_feedback_domain.o : mediation_feedback_domain.F
# mediation_force_domain.o : mediation_force_domain.F
# mediation_interp_domain.o : mediation_interp_domain.F
# compile these without high optimization to speed compile
mediation_integrate.o : mediation_integrate.F
track_driver.o : track_driver.F
convert_nmm.o : convert_nmm.F
init_modules_em.o : init_modules_em.F
input_wrf.o : input_wrf.F
module_io.o : module_io.F
module_comm_dm.o : module_comm_dm.F
module_comm_dm_0.o : module_comm_dm_0.F
module_comm_dm_1.o : module_comm_dm_1.F
module_comm_dm_2.o : module_comm_dm_2.F
module_comm_dm_3.o : module_comm_dm_3.F
module_comm_nesting_dm.o : module_comm_nesting_dm.F
module_configure.o : module_configure.F
module_dm.o : module_dm.F
module_domain.o : module_domain.F
module_domain_type.o : module_domain_type.F
module_alloc_space_0.o : module_alloc_space_0.F
module_alloc_space_1.o : module_alloc_space_1.F
module_alloc_space_2.o : module_alloc_space_2.F
module_alloc_space_3.o : module_alloc_space_3.F
module_alloc_space_4.o : module_alloc_space_4.F
module_alloc_space_5.o : module_alloc_space_5.F
module_alloc_space_6.o : module_alloc_space_6.F
module_alloc_space_7.o : module_alloc_space_7.F
module_alloc_space_8.o : module_alloc_space_8.F
module_alloc_space_9.o : module_alloc_space_9.F
module_tiles.o : module_tiles.F
module_fddaobs_rtfdda.o : module_fddaobs_rtfdda.F
module_initialize.o : module_initialize.F
module_physics_init.o : module_physics_init.F
module_initialize_b_wave.o : module_initialize_b_wave.F
module_initialize_hill2d_x.o : module_initialize_hill2d_x.F
module_initialize_quarter_ss.o : module_initialize_quarter_ss.F
module_initialize_real.o : module_initialize_real.F
module_initialize_real.o: module_initialize_real.F
module_initialize_squall2d_x.o : module_initialize_squall2d_x.F
module_initialize_squall2d_y.o : module_initialize_squall2d_y.F
module_initialize_scm_xy.o : module_initialize_scm_xy.F
module_integrate.o : module_integrate.F
module_io_mm5.o : module_io_mm5.F
module_io_wrf.o : module_io_wrf.F
module_si_io.o : module_si_io.F
module_wps_io_arw.o : module_wps_io_arw.F
module_state_description.o : module_state_description.F
output_wrf.o : output_wrf.F
solve_interface.o : solve_interface.F
start_domain.o : start_domain.F
start_em.o : start_em.F
wrf_bdyin.o : wrf_bdyin.F
wrf_bdyout.o : wrf_bdyout.F
wrf_ext_read_field.o : wrf_ext_read_field.F
wrf_ext_write_field.o : wrf_ext_write_field.F
wrf_fddaobs_in.o : wrf_fddaobs_in.F
wrf_histin.o : wrf_histin.F
wrf_histout.o : wrf_histout.F
wrf_inputin.o : wrf_inputin.F
wrf_inputout.o : wrf_inputout.F
wrf_restartin.o : wrf_restartin.F
wrf_restartout.o : wrf_restartout.F
wrf_tsin.o : wrf_tsin.F
nl_get_0_routines.o : nl_get_0_routines.F
nl_get_1_routines.o : nl_get_1_routines.F
nl_set_0_routines.o : nl_set_0_routines.F
nl_set_1_routines.o : nl_set_1_routines.F
track_driver.o \
convert_nmm.o \
init_modules_em.o \
module_dm.o \
module_fddaobs_rtfdda.o \
module_initialize.o \
module_initialize_b_wave.o \
module_initialize_hill2d_x.o \
module_initialize_quarter_ss.o \
module_initialize_real.o \
module_initialize_squall2d_x.o \
module_initialize_squall2d_y.o \
module_initialize_scm_xy.o \
module_integrate.o \
module_io_mm5.o \
module_io_wrf.o \
module_si_io.o \
module_wps_io_arw.o \
module_tiles.o \
output_wrf.o \
solve_interface.o \
start_domain.o \
start_em.o \
wrf_fddaobs_in.o \
wrf_tsin.o :
    $(RM) $@
    $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.b  > $*.f90
    $(RM) $*.b
        fi
    if $(FGREP) '!$$OMP' $*.f90 ; then \
          if [ -n "$(OMP)" ] ; then echo COMPILING $*.F WITH OMP ; fi ; \
      $(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $*.f90 ; \
        else \
          if [ -n "$(OMP)" ] ; then echo COMPILING $*.F WITHOUT OMP ; fi ; \
      $(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ; \
        fi
#solve_em.o :
#    $(RM) $@
#    $(SED_FTN) $*.F > $*.b
#    $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.b  > $*.f90
#    $(RM) $*.b
#    $(FC) -o $@ -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $(SOLVE_EM_SPECIAL) $(OMP) $*.f90
module_sf_ruclsm.o : module_sf_ruclsm.F
    $(RM) $@
    $(RM) $*.b
          echo COMPILING $*.F WITH OMP ; \
      $(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $*.f90 ; \
        else \
      $(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ; \
        fi
# compile without OMP
input_wrf.o \
module_domain.o \
module_domain_type.o \
module_physics_init.o \
module_io.o \
wrf_bdyin.o \
wrf_bdyout.o \
wrf_ext_read_field.o \
wrf_ext_write_field.o \
wrf_histin.o \
wrf_histout.o \
wrf_inputin.o \
wrf_inputout.o \
wrf_restartin.o \
wrf_restartout.o \
module_state_description.o \
module_alloc_space.o \
module_alloc_space_0.o \
module_alloc_space_1.o \
module_alloc_space_2.o \
module_alloc_space_3.o \
module_alloc_space_4.o \
module_alloc_space_5.o \
module_alloc_space_6.o \
module_alloc_space_7.o \
module_alloc_space_8.o \
module_alloc_space_9.o \
module_comm_dm.o \
module_comm_dm_0.o \
module_comm_dm_1.o \
module_comm_dm_2.o \
module_comm_dm_3.o \
module_comm_nesting_dm.o \
    $(RM) $@
        fi
    $(RM) $*.b $*.bb
    $(FC) -c $(PROMOTION) $(FCSUFFIX) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $*.f90
MK
im using SLES 11 sp3
TimP
Your link step (assuming it is driven by ifort or icc) needs -openmp flag to include the libiomp5 in the library search path.  It looks like you compiled for hybrid MPI/OpenMP but linked for MPI alone.
The stuff you posted is rather confusing.  It might help if you would post the parts you actually want to use, and explain any deviations from the specific advice about WRF posted by Intel.  Admittedly, the advice seems to be over 3 years old.
It's correct that mpif90 -fc=ifort is the same as mpiifort and so on, provided that you don't have some other mpif90 on your PATH.
If your reference to SLES11 means that you aren't using Intel MPI, a forum specific to WRF might be more helpful.
An_Yang
I met the same problem too, and rerun ./compile wrf could link wrf.exe, but it could not work fine, core dump, do you think it's a bug in openmp libs?
